Old 05-09-2013, 06:17 PM   #76471
sunthechip
Oddometer: 126
Originally Posted by Emmbeedee View Post
Why not just use an expansion drain plug to seal it up until you have time to do it properly?
isn't a thread insert doing it "properly" ? one of those plugs would be nice, but I will have to drain the oil twice if I do that. Its only a 2 mile walk to work, so I'll wait.
should I order a new magneto gasket as well?
sunthechip is offline   Reply With Quote
Old 05-09-2013, 06:47 PM   #76472
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,684
Yes, a thread insert is 'doing it properly'. If you're within walking distance to work, then you might as well do it right the first time.
And yes, get the magneto gasket. You might not need it, but that only happens if you have a new one waiting.
Old 05-09-2013, 06:54 PM   #76473
NJ-Brett
Brett
Oddometer: 6,454
On most bikes, its bolted in a fixed spot, or part of the stator assembly.
Originally Posted by andruboz View Post
In all the posts of fiddling with the Dr, I haven't seen anything about ignition timing. Is it just that good from the factory, or is it virtually unadjustable. I thought most cars/bikes were sold with the ignition on the retarded side to run on cheap gas without pinging .
NJ-Brett is offline   Reply With Quote
Old 05-09-2013, 06:55 PM   #76474
sunthechip
Oddometer: 126
cool! thanks man.
Old 05-09-2013, 07:15 PM   #76475
8gv
Oddometer: 2,463
Gaskets are like rain gear, get them so you won't need them.
8gv is offline   Reply With Quote
Old 05-09-2013, 08:08 PM   #76476
procycle
procycle's Avatar
Oddometer: 2,321
It is not adjustable but The few who have done some experimenting report that changing from the stock setting doesn't have any performance advantage.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle screwed with this post 05-09-2013 at 08:30 PM
procycle is offline   Reply With Quote
Old 05-10-2013, 01:37 AM   #76477
Chill
Chill's Avatar
Oddometer: 321
Originally Posted by blackcap View Post
Anyone else got some suggestions on where to look for problems?
+1 My first thought was oil seeping up past the scraper rings and fouling the plugs. I imagine it would only take a light coating and they'll not fire cleanly enough to start.
Chill is offline   Reply With Quote
Old 05-10-2013, 01:54 AM   #76478
considermichael
Oddometer: 62
Laugh Bought this '92 DR650 Dakar about 20 minutes ago...
Hey guys,
Instead of making a new thread I thought I would try it here first. I just got a wonderful '92 DR650 for 500.- Chf which is about 500$. Thing is it was outside for two years with the rain snow sun etc. 16'000 Miles
I am going to pick it up and hopefully I can get it runnig soon. The battery is completely dead and I was forced to buy it withought ever starting it!
Can anyone let me know if I am forgetting anything before I start her for the first time? Keeping in mind its been sitting there like that for two years. (The dent in the tank was from a wind gust that knocked it onto a stone.)
1. Replace Fuel.
2. Charge Battery.
3. Replace Engine Oil.
4. Clean Carbs? <-- (Is that necessary?)
considermichael is offline   Reply With Quote
Old 05-10-2013, 02:59 AM   #76479
greer
Oddometer: 3,808
One thing's for sure, you need the pre-'96 thread; here you go:
http://www.advrider.com/forums/showt...61568&page=246
I think there's also a forum at drriders.com
Good luck!
Sarah
'08 DR650
greer is offline   Reply With Quote
Old 05-10-2013, 03:27 AM   #76480
Thumper Dan
Oddometer: 325
Mojave Shock
Ok, I just installed the Mojave shock.
I thought I was going to be wrestling getting it out and putting the new on in. It was suprising how easy it was to install; even with the airbox etc seemed reletively easy.
I need to test tomorrow but I'm not 100% sure about setting the sag. The preferred measurement, according to Cogent is 85mm (rear wheel fully extended, to when I'm sitting on my bike in riding gear), but I'm not sure which way to turn the "bling ring" to increase or decrease the mm??
Also, I may have to put my daughter (adult) on the bike with a bag of concrete which, would then equal my weight and take measurements, otherwise I can't see the measurements whilst I'm sitting on the bike.
Currently riding DR650 (2011)
Mods: Manrack, ebay 48 litre top box, grind header pipe; B&B bash plate; bigger/better tool compartment (pvc pipe) - Screens For Bikes Windscreen, TM40 Pumper Carb, Safari Tank, Seat Concepts, Oxford Heater Grips, Highway Pegs, Wolfman Expidition bags and racks, HDB handguards, Cogent Mojave rear shock, intiminators, GSX muffler/mod
Thumper Dan is offline   Reply With Quote
Old 05-10-2013, 03:55 AM   #76481
blackcap
blackcap's Avatar
Oddometer: 538
if you can afford it and find them go for a Timesert. http://www.timesert.com/html/mtrcsert.html
install it properly and youll never have to think about it ever again. helicoils sometimes dont last.
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 05-10-2013, 04:08 AM   #76482
blackcap
blackcap's Avatar
Oddometer: 538
Originally Posted by barko1 View Post
Gas in airbox?
we have a winner! checked it this morning and there was fresh fuel on the ground under the bike. pulled the drain plug and a whole heap more cam flowing out. battery had a good charge and after clearing her throat a little the old girl fired right up. thanks for the lesson on that one.
as for oil fouling the plugs, with the angle the DR sits on when resting on the bars on its side and the amount of oil and the size of the engine cavity i cant imagine there would be much chance of actually getting any oil even onto the bottom of the piston, late alone past the rings unless it was sitting upside down. but i guess stranger things have happened.
Originally Posted by Adv Grifter View Post
Both of those are good ideas. I'd just pull the plugs and let things sit. Do not clean a modern spark plug.
I never, ever do any work on my bike with the fuel tank ON. With the IMS it's off in less than 3 minutes. I set it aside and then have clear access to everything. YMMV.
Did you happen so soak your new clutch plates in oil before installation?
from now on ill be turning the fuel taps off at the very least, the safari is a little more than 3 minutes work to get back on so i prefer to leave it in place but definitely something worth noting in the future. i did give the plates a dip in oil before installing but not a soaking. whats the danger of not applying any oil? i would imagine the oil circuit would coat them all pretty quickly anyway.
Old 05-10-2013, 05:24 AM   #76483
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by considermichael View Post
i LOVE that paint job!
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 05-10-2013, 06:26 AM   #76484
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 734
Hey guys,
But before you head over to the pre-96 thread gotta say that looks sweet in red! My first DR 650 was a brand new 92 in blue my current ones my third.....wish the 96 and later had kept the kicker on top of having electric start.
New Mexico, not really new, not really Mexico.
Carl Childers is online now   Reply With Quote
Old 05-10-2013, 06:30 AM   #76485
deathu
deathu's Avatar
Oddometer: 77
Originally Posted by deathu View Post
On another topic, I need urgent help with the following issue. During my latest 6-mile commute to work the bike was constantly dying during normal driving. It seems the bike cuts out the ignition when in gear, and the engine dies immediately. At this point it also won't crank unless it's in neutral. The problem was intermittent until I actually had to stop on the side of road, took the seat off and started checking the wires.
Apart from the sidestand safety switch, is there anything else that can cause this? I eventually managed to resume my commute and get to work after playing with the wires but I deffinitely need to recheck everything in the morning before heading back home (it's 11PM now). The sidestand safety switch was elliminated by one of the previous owners, now I have a little green connector with two wires soldered together. I need to know if there is anything else I need to re-check, any obvious sub-systems that can cause the described behavior.
Originally Posted by Kommando View Post
Clutch safety switch. I would also check the wiring for the removed sidestand safety switch with a multi-meter. The solder may have cracked or something.
Well it turns out I could not replicate the problem any longer this morning, the bike just ran without issue no matter how i played with the wires. I guess it must have been the green connector itself (that was intended for the sidestand switch), as I did un-plug and re-plug it. the wires and solder seem ok..
The clutch switch if I understand correctly can definitely prevent me from starting the engine while in gear, but I guess it won't kill an already running engine if it fails.
Gonna spray some contact cleaner in all the connectors today... and hope to not have any further nasty surprises
deathu is offline   Reply With Quote
Times are GMT -7.   It's 01:15 AM.
