Old 08-09-2006, 03:20 AM   #751
Stackator
F800GS goodness
Stackator's Avatar
Oddometer: 1,343
Very nice
I like the shiny black look it even makes the mighty big tank look normal in size. That looks like a stock header with the FMF Q, where did you get it?
Originally Posted by jamodu-fishbulb
after......
its a bit dark... ill post a better one when i get a lighter pic...
swish!!
Golf courses are Enduro parks waiting to be discovered
Refresher for the Australian forum: http://www.deakin.edu.au/current-stu...outs/apost.php
Stackator is offline   Reply With Quote
Old 08-09-2006, 03:23 AM   #752
David_S
David_S's Avatar
Oddometer: 1,130
Originally Posted by Stackator
I like the shiny black look it even makes the mighty big tank look normal in size. SNIP
That's why "smart" fat chicks wear black
bikeless
David_S is offline   Reply With Quote
Old 08-09-2006, 03:39 AM   #753
Pickled Amnesiac
ex Fishbulb....
Pickled Amnesiac's Avatar
Oddometer: 1,236
Thumb
it was on it when i got it..... the Q pipe gets louder and quieter by the day, like in my 15 km commute the noise will chenge drastically..... not always louder at the start or in anykindpattern.sure does sound nice tho!
Pickled Amnesiac is online now   Reply With Quote
Old 08-09-2006, 04:01 AM   #754
NJCapoRider
NJCapoRider's Avatar
Oddometer: 127
Short Clutch & Brake Levers
Does anyone know a source for short clutch and brake levers that will fit a DR650? I want shorter than OEM levers but prefer to retain the ball ends like stock. Thanks.
Wayne
_________________
The destination is rarely as important as the ride!
NJCapoRider is offline   Reply With Quote
Old 08-09-2006, 05:31 AM   #755
bing
Supermoto Tourer
bing's Avatar
Oddometer: 71
You can use an XR shorty lever for the clutch. I don't know of any alternatives for the front brake. Perhaps an RMZ or DRZ lever???
bing is offline   Reply With Quote
Old 08-09-2006, 04:00 PM   #756
Starky14
Yowie Bait
Starky14's Avatar
Oddometer: 205
Short levers
Wayne
I had to shorten the cluch lever on my 2006 DR to fit inside the brushguards. I cut the ball off the end. The ball has a hole on the underside. I drilled this hole slightly larger, I think to 13mm, don't drill right through. Smoothed the burs off and glued (araldite) the ball back on by puting the end of the lever in the hole on the ball. Shorter lever by 1.5cm. You can hardly tell the diffrence in the look and it didn't cost anything. Fooled the dealer when he rode it. Using the same principle you could make the lever whatever length you want. Just a very cheap thought.
Starky
Starky14 is offline   Reply With Quote
Old 08-09-2006, 04:24 PM   #757
NJCapoRider
Oddometer: 127
Short Clutch/Brake Levers
Thanks for the information/suggestions guys. I got some good options now. Thanks.
Wayne
_________________
Old 08-09-2006, 04:52 PM   #758
Vampire
Vampire's Avatar
Oddometer: 138
[quote=Starky14]I had to shorten the cluch lever on my 2006 DR to fit inside the brushguards. ]
FYI, there is a new range of Barkbusters that are designed to fit dual sport bikes. I have just purchased a set for the DR and they fit perfectly, leaving plenty of room around the levers.
Wayne
I refuse to grow old until I grow up.
Vampire is offline   Reply With Quote
Old 08-09-2006, 08:17 PM   #759
Starky14
Yowie Bait
Starky14's Avatar
Oddometer: 205
[quote=Vampire]
Hi Vampire,
Yeah I know about the new model but I got these at right price $79 instead of $135 for barkbusters, so can't complain. Always some comprimise isn't there.
By the way how did you carry spare fuel on your trip to the Flinders Ranges?
Starky
Old 08-09-2006, 08:46 PM   #760
elevatorjunky
oily adventurer
elevatorjunky's Avatar
Oddometer: 186
Originally Posted by David_S
Well I figured since I was commuting on the DR last week I would see what my range is with the IMS tank. The range was good, 232 miles. The only problem is reserve puked at just over a 1 mile later. Pretty piss poor design IMO. Anyone else ran yours on reserve yet? I'm wondering if I got a bum petcock or is that just the way it is with a pingel installed on an IMS? Fortunately I was close to home and a passer by stopped. I rolled the DR into the ditch and laid her on her side and rode home to get some fuel.
The stock Yamaha petcock I.M.S sends only gives me about 180 miles before reserve.I guess I am to assume I will have about 50 miles on reserve.I have to run it out one of these days to know for sure.Has any one else ran an I.M.S tank dry before?
Some smart thing that some great guy said that doesnt apply to me that I wish did.
'99'KTM 380EXC "California plated"
elevatorjunky is offline   Reply With Quote
Old 08-09-2006, 11:22 PM   #761
Vampire
Vampire's Avatar
Oddometer: 138
Starky[/quote]
See pic, I had a 5 litre can in a carrier I adapted from a Willow Tool carrier.
Wayne
Old 08-09-2006, 11:30 PM   #762
Vampire
Vampire's Avatar
Oddometer: 138
IMS Fuel reserve with Pingel fuel tap
I received my IMS tank with pingel fuel tap this week and took it out for a run today to test the reserve.
With the tap in the 'on' position, I continued until the engine quit entirely then switched to reserve. At 100 kph (about 60mph), the bike ran for a further 19.8 kms before dying.
I normally get about 21 km/litre at that speed, so I calculate that the reserve is about .95 litres, or close to 1/4 US gallon.
At the same fuel economy, that's about 12 miles.
Nowhere near enough for my liking, so I think I will take the fuel tap out and see whether I can install a longer intake tube. Hopefully it won't be too difficult, but i'd like about 4 litres (1 US gal) reserve.
Wayne
Old 08-09-2006, 11:33 PM   #763
Pickled Amnesiac
ex Fishbulb....
Oddometer: 1,236
reserve...
does anyone know the volume of reserve in a 34lt safari tank?
ive just put mine on and i think i should carry a 5 litre jerry can when i test it...
Old 08-10-2006, 12:08 AM   #764
InertiaDRZ400
AusSafari Addict
InertiaDRZ400's Avatar
Oddometer: 583
capasity kms
how many kms are you guys getting from one of those safari tanks ? or the ims ?
InertiaDRZ400 is offline   Reply With Quote
Old 08-10-2006, 12:11 AM   #765
Pickled Amnesiac
ex Fishbulb....
Oddometer: 1,236
Wicked
so far from my safari.... 40.
but i only put it on yesterday.
Times are GMT -7.   It's 03:26 PM.
