Old 05-12-2013, 08:21 AM   #76531
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,644
What ft./lb do the DR650 head bolts get torqued to?
I know my Ford F-150's head bolts are torque-to-yeild, and are supposedly non-reusable, but some guys say you can use them a second time - but no more than twice.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 05-12-2013, 08:45 AM   #76532
EBMOTT
Oddometer: 70
Question rear shock
Is anybody out. There running on a ricor shock. If so what do you think of it?
EBMOTT is offline   Reply With Quote
Old 05-12-2013, 09:26 AM   #76533
bumpathump
Oddometer: 328
Maynard -
> Anneal the washers by heating with a propane torch to glowing red and
> allowing to cool down slowly. Reuse the bolts.
Copper is annealed by plunging into cold water after heating.
Rick
bumpathump is offline   Reply With Quote
Old 05-12-2013, 10:41 AM   #76534
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 781
Originally Posted by bumpathump View Post
Maynard -
Rick
Might be terminology in this case? For re use of copper washers and even the old Triumph 650 head gaskets we used to heat them up in an oven and then take them out to cool on their own. Never had a leak doing it that way.
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 05-12-2013, 11:36 AM   #76535
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Maynard -
Rick
Rick,
I think Maynard is correct. IIRC, Annealing requires slow cooling. Plunging into water HARDENS the metal. (I'm going back to memories from High School metal shop here ... so I defer to any experts here )
I've used this technique on Copper Drain Plug washers for about 30 years ... never a leak and never stripped one either.
Old 05-12-2013, 12:10 PM   #76536
gzr
gzr's Avatar
Oddometer: 38
Tech question: Head bolt washers
Thanks for reassuring me that I can reuse these.
As far as I know copper doesn't really care about the cooling rate when you anneal it. Ferrous metals (and some aluminium alloys that can be solution treated) are another story and that's probably what some people were thinking of....
@ MamboDave, the bolts take 27.5ft-lb and the nuts take 18 ft-lb. That's little enough that I doubt they will yield (even though they are machined "narrow" along their length and the thread has a fine pitch)
The service manual does not mention anything about replacing unless I'm missing it completely.
gzr is offline   Reply With Quote
Old 05-12-2013, 12:40 PM   #76537
ER70S-2
ER70S-2's Avatar
Oddometer: 6,708
Be aware that the manual is wrong with the locations of the different length head bolts. Set the head in place and drop the bolts in, making sure all of them are standing the same distance up.
If you're just retorquing this won't matter.
Example of the wrong fastener location:
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-12-2013, 12:42 PM   #76538
procycle
procycle's Avatar
Oddometer: 2,375
Originally Posted by Adv Grifter View Post
Rick,
Copper is annealed by heating it to a dull red heat. It doesn't matter if you let it cool slowly or quench it in water the result will be the same - soft copper.
Steel is totally different and will harden if quenched from red heat but can be annealed by heating up to a specified temperature (usually not hot enough to glow red) and letting it cool slowly.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 05-12-2013, 12:44 PM   #76539
procycle
procycle's Avatar
Oddometer: 2,375
Do you have a photo of every single DR650 component?
Old 05-12-2013, 12:50 PM   #76540
ER70S-2
ER70S-2's Avatar
Oddometer: 6,708
Cool2
Not yet.
2013 WR250R
ER70S-2 screwed with this post 05-12-2013 at 01:11 PM Reason: better answer
Old 05-12-2013, 05:09 PM   #76541
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 462
Well after finally getting this new to me 2007 2200 miles DR set up to my liking, I am starting to really dig it. New Eibach .47 springs in front, Gold Valve Emulators, new Cogent rear, new bars, grips, seat, TKC 80's, lowered foot pegs, fork brace, seal reatainer, case saver and added a 5.3 Acerbis Tank.
Exhaust and carb are up next. Not sure which exhaust however....? Does anyone use a steering damper with their DR?
Rode 150 miles today on and off road. The bike is handling great. I need to load her up and see how she handles with all my camp gear.
Graniteone screwed with this post 05-12-2013 at 05:23 PM
Graniteone is offline   Reply With Quote
Old 05-12-2013, 05:23 PM   #76542
Kommando
Kommando's Avatar
Oddometer: 7,389
Originally Posted by Graniteone View Post
Well after finally getting this new to me 2007 2200 miles DR set up to my liking, I am starting to really dig it. New Eibach .47 springs in front, Gold Valve Emulators, new Cogent rear, new bars, grips, seat, TKC 80's, lowered foot pegs and added a 5.3 Acerbis Tank.
Try a GSX-R muff if you appreciate quiet and not having to repack while racking up mileage. DG makes some loud inexpensive muffs that need repacking, but they flow better and are pretty durable. I currently run a stock muff for quiet, longevity, and $$. You may want a bit more flow at altitude.
The stock carb can be improved significantly with a kit from Procycle. For the mountains, I'd lean towards opening up the airbox instead of leaving it stock. You may want to just rejet and then remove the airbox door, to test before cutting the airbox.
Kommando is offline   Reply With Quote
Old 05-12-2013, 08:25 PM   #76543
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,644
What weight are you for the springs?
their motorcycles
RyanR
Old 05-12-2013, 08:42 PM   #76544
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 636
Any of you fine DR riders headed to the ADV rally in TN " Rick's rendezvous"?
I'll be there with my old dr and I hope it's not going to be the only one. I just installed the Cogent DDC fork valves that are the cogent solution similar (but better) to the emulators/intiminators.
Hoping to get onto a couple rides as well as have a beer or two with some dr folks.
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 05-12-2013, 09:58 PM   #76545
Harry94025
Oddometer: 291
Copper has a face-centered cubic grain structure which will be optimally ductile following the quench, although the metal will be in an annealed state with air cooling as well. Another benefit of quenching from the dull red heat is that the oxide scale will be removed during quenching, leaving a nice clean sealing surface.
Regards,
Harry
Harry94025 is offline   Reply With Quote
Times are GMT -7.   It's 11:45 AM.
