Old 05-13-2013, 12:22 PM   #76561
motolab
motolab's Avatar
Oddometer: 2,714
Originally Posted by Kommando View Post
That's a run sheet for a DynoJet kit, if the info at the bottom is correct. Procycle has sold several different carb kits. While the DJ kit has been one of them, IIRC, it is not the only one. They also sell Factory Pro and another kit of unlabeled origin.
See http://www.procycle.us/bikepages/dr650.html#jetkitdr650 and http://www.procycle.us/info/question...l#pc_jet_kit-1. In the second link it says that the ProCycle kit needle has the same profile as the DJ. While the FP kit will have a more useful needle profile, note that there will be accelerated emulsion tube wear due to the titanium material it's made from.
Regards,
Derek
motolab is offline   Reply With Quote
Old 05-13-2013, 12:45 PM   #76562
procycle
procycle's Avatar
Oddometer: 2,375
Originally Posted by motolab View Post
I've already said many times that I have not tuned one.
DR650 that is.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 05-13-2013, 12:52 PM   #76563
motolab
motolab's Avatar
Oddometer: 2,714
Originally Posted by procycle View Post
DR650 that is.
What point is it you are trying to make?
Regards,
Derek
Old 05-13-2013, 12:53 PM   #76564
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,043
Exhaust question?
-BST carb (shimmed needle, stock jets, 2nd slide hole drilled, pilot screw, iridium plugs)
-Stock airbox with snorkle removed
-14 tooth CS
-zero plans on engine big-bore mods
-much of my riding is off-road at elevation (5-14K) and lower speeds. i use my DR as a touring dual-sport. often i'm chugging up a dirt hill in 1st gear loaded with camping gear.
-paved road speeds are in the 70-80 mph range at the most.
-I really like how the bike runs now. linear and strong with plenty of 1st gear grunt to take off.
Adding my GSXR-40 muffler back on to the bike to loose weight and breath better.
Normal Jesse mid-pipe w/ stock header or bigger mid-pipe and Jesse's big header???
Is there any advantage to the big header except on the top end? Is a pumper carb needed to take advantage of the big header?
I'm leaning towards the regular mid-pipe, stock header. Should I consider the bigger stuff at all for my situation?
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-13-2013, 12:59 PM   #76565
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,043
Regards,
Derek
I'd say that PC is questioning your 100%-knowing-the-answer BST carb tuning expertise when you have only tuned for the KTM 640 motor and not the DR650 motor.
I have no doubt you are an expert carb tuner and thank you for the immense help you have provided me and others, but myself, I would never attempt to be expert/answerer/solution-guy for something I have not personally worked on. That's just me, but you are very confident that your KTM 640 motor experience translates over to DR650 knowledge.
I'd say PC is questioning you on that?
Alaska
Old 05-13-2013, 01:35 PM   #76566
motolab
motolab's Avatar
Oddometer: 2,714
I'd prefer if he spoke for himself.
I've worked on many BST40 carbs.
It has nothing to do with KTM640 tuning experience per se. It has to do with tuning CV carburetors in general. The trends are the trends. In my experience a needle with a shape such as the DJ needle has will always make the top end leaner than the bottom end, so the needle is at least in part responsible for the strangely shaped CO trace we see in the graph. Opening up the airbox and installing the appropriate main jet for correct high rpm mixture always trends toward making the lower rpm richer than it should be (the more it's opened the worse this gets), so you would need a needle that does the opposite in order to counter that trend. Obviously you would not want to install a needle with a shape that exhibits the same trend.
Regards,
Derelk
Old 05-13-2013, 01:45 PM   #76567
barko1
barko1
barko1's Avatar
Oddometer: 3,379
Regards,
Derelk
So what needle do you recommend?
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 05-13-2013, 01:48 PM   #76568
motolab
motolab's Avatar
Oddometer: 2,714
The first needle I would try would be the non-USA adjustable OEM needle.
Regards,
Derek
Old 05-13-2013, 02:25 PM   #76569
Kommando
Kommando's Avatar
Oddometer: 7,389
Exhaust question?
-14 tooth CS
I'm no expert, but at your altitude, I'd be trying to flow as much air as I could when at max altitude, then tune the carbing to suit for down low when you close off portions of the airbox intake.
Kommando is offline   Reply With Quote
Old 05-13-2013, 02:28 PM   #76570
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,043
Motolab Derek is not a fan of this technique, but many of us have added 1 or 2 stainless steel washers under the USA needle clip to slightly raise the needle up and thus release more gas on the main jet.
Each washer is approx 1 clip position change on an adjustable needle. The KLR guys call this the 22 cent mod. I have 2 washers and i'm happy with it. Derek does not like how this technique creates a small amount more of preload on the slide spring vrs the adjustable needle where the needle moves up in the spring but the spring itself is not pushed together tighter.
To me it was cheap and it worked. I'm on stock jets. I'm sure there might be a ever so slight change in the spring tension, but it's such a small amount, i'm not sweating it. I tried 1 washer and then 2 & liked it better. I tried 3 and not so much.
I also have a pilot fuel screw which i play with depending on my elevation.
I've spent 6 months riding at sea level, plus ride up to 14,000' in the summer all on the same carb setup and it runs at all those elevations. The only thing i tweak per elevation is move many turns out i'm on with the pilot jet.
Sure i'd love FI, but this CV carb really does work on a huge range of elevations.
Alaska
eakins screwed with this post 05-13-2013 at 02:36 PM
Old 05-13-2013, 02:35 PM   #76571
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,043
thanks.
never had to do any changes to the airbox even at sea level. thought i might need to put the snorkle back in to reduce airflow but it was not needed. i've read how others have removed the airbox cover when riding at very high elevations to try and gain as much air as possible but I haven't needed this either.
really wondering if the extra expense is worth it on my bike for the fat header when i'm not a wide open down the hiway throttle rider? when i'm at those high elevations i'm usually in lower gears going slower anyway.
guess my question to any pipe tuners out there: does a fat header affect performance across all throttle ranges or just head at the top/max throttle?
Alaska
Old 05-13-2013, 02:52 PM   #76572
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
Regards,
Derek
Best we could get from it was raising it half a clip and pulling the snorkel.
NordieBoy is offline   Reply With Quote
Old 05-13-2013, 02:53 PM   #76573
barko1
barko1
barko1's Avatar
Oddometer: 3,379
Regards,
Derek
Where does one get it? Thx
Old 05-13-2013, 03:21 PM   #76574
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,377
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 05-13-2013, 05:07 PM   #76575
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by Rusty Rocket View Post
I prefer Ms. Johannson eating popcorn.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Times are GMT -7.   It's 03:10 PM.
