Old 05-14-2013, 04:38 PM   #76606
RichBeBe
All Hail Seitan!!!
RichBeBe's Avatar
Oddometer: 6,278
Originally Posted by ER70S-2 View Post
11 to 20 feet I hear you guys have horsepower down there too.
There's no doubt that we live in two different extremes of the DR environment.
I used to do all of the dyno development work Orient Express and TiForce exhaust systems and I would get calls "What elevation are you guys at?" I would say "Hold on a minute" and then pick up the phone and say "Since it is high tide about two feet' in about 6 hours it might be 5 feet"
We were literally on a canal and I could see the water from the door
"Remember that an enduro tests the endurance of three things: your machine, your body, and your wits. Only one has to fail to keep you from reaching the finish line." Cycle World March 1966
RichBeBe is online now   Reply With Quote
Old 05-14-2013, 06:33 PM   #76607
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,021
I exchanged a PM with Derek regarding the fuel enrichment vs pilot jet re cold/warming running. He was very informative and offers the non-US OEM jet. Seems like a good guy to deal with so far.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 05-14-2013, 07:01 PM   #76608
TaZ9
Happy Adventurer
Oddometer: 278
This is good advice...take it!
Originally Posted by procycle View Post
Actually the stock jetting is good for high elevation. If your bike runs good at sea level with stock jetting and the snorkel removed that points to a problem. It's getting more fuel than normal.
A stock DR650 with stock jetting (minus the snorkle) runs fine at the altitudes you find here in Colorado. Do yourself a big favor and keep it simple so your trip out here won't be spent wondering where you screwed up your carburetor adjustment, i.e. cut air box, jet kits, etc.
I am on my second all stock DR650, and after many, many thousands of miles, it still starts and runs perfect at all altitudes, AND gets 55-58 MPG on a regular basis. A properly cleaned and oiled air cleaner is also a big plus.
You may find it necessary to raise the idle at higher altitudes as the thin air can make even a properly jetted bike a little sluggish at idle.
Enjoy your trip!
Taz9
TaZ9 is offline   Reply With Quote
Old 05-14-2013, 07:03 PM   #76609
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Originally Posted by refokus View Post
It doesn't surprise me, (or probably anyone else on here) that you don't understand. I really don't think any explanation would clear it up either for you.
Also, it wasn't a complaint but an observation. To be a complaint I would have to be a customer and with the customer service that you displayed I don't ever see that happening.
The dude is selling an $18 motorycle part, after providing a large amount of free information that you can choose to believe or disbelieve. This isn't some gross exploitation of the ADVrider masses.
Same here.
And, I've had great transactions with Procycle and a half dozen other vendors on ADVrider too.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 05-14-2013, 07:05 PM   #76610
rpet
Awesometown
rpet's Avatar
Oddometer: 820
Enjoy your trip!
Taz9
I appreciate your response. I just need to rectify what I believe is an unduly rich mix at my home sea level. Then, I think this steed will be good for the LONG miles and the HIGH elevations... in other words exactly what I bought it for. #party
Old 05-15-2013, 12:17 AM   #76611
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
Originally Posted by Adv Grifter View Post
From what I've read over the years on this, a Fat, more free flowing header is mainly beneficial at HIGH RPM. Rob Muzzy (Kawi Super Bike tuner) has talked some about this, so has Kevin Cameron.
Race bikes benefit from Fat headers and more free flowing pipes because they are often at or near redline. So a HP spike can be seen at high RPM.
But when Dyno charts are compared to stock, the big headers usually lose out to stock in the low and mid range.
But on the DR650, the stock set up most likely is going to give a flatter torque curve with slightly better low and mid range torque/HP, but won't match Max HP near redline of a Fat header. Trade offs. You decide.
thanks. i've decided to keep the stock header and just get the mid-pipe.
i can understand the benefits of a fat header, but i'm a low and mid-range off-road rider.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-15-2013, 12:24 AM   #76612
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
Originally Posted by rpet View Post
No - it is better now that my idle is up to 1550 or so, but I still need to rev while pulling the clutch in to stop most times.
I will re-check clutch adjustment, but it doesn't seem to be dragging/pulling while I have the lever pulled in. Free play at the cable was correct last time I checked.
I am starting to think about opening up the carb for the first time and doing the O-rings just to be safe and checking float and other stuff while I'm at it. Preventative maintenance before my big trip would be smart, I think. I need to get the damn JIS screws replaced anyway in case I have to field strip the carb.
What's the cheapest source for the correct BST O-rings that could cause rich condition if they're going bad?
Speaking of which, I might as well throw out the request for jetting tips. I'm at sea level and I've heard that stock DR650 BST jets (with fuel screw adjustment, snorkel removed and twin air filter) is fine for sea level. Bike seems to run well (other than dying at stop signs).
BUT - in July I'm doing a 4 week tour of the Western United States. Big loop from San Fran, through Eastern Oregon on the OBDR, down the Rockies along the Divide Route and then the Western TAT.
Should I rejet for this trip or will the BST adjust enough to those elevations? I imagine we will be above 3500 ft the entire time, with plenty of riding at 6000 and higher. Any tips or links to previous discussions on this are appreciated.
I run from sea-level to over 14K with my BST. i just added 2 washers to shim the needle plus an adjustable pilot jet screw. I also have Irdidium plugs which I feel helps when the a/f ratio is off a bit. I know it helps to start the bike on a cold mountain morning. Pull off your airbox cover if you find you are having rich running symptoms when up high. This can help some.
Sounds like a sweet trip. Don't miss some of the BDR routes:
http://www.backcountrydiscoveryroutes.com/
Alaska
Old 05-15-2013, 12:26 AM   #76613
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
not sure how your BST is rich at sea level?
stock is lean and like PC said ideal above 6K.
go back to stock jets if you haven't already.
yes the BST does a decent enough job adjusting to altitude changes.
that is one advantage it has over a pumper carb from what i've read.
i remember a ride report of guys going over 17K on the Khardung La and the guy on a stock DR motored along while everyone else had to rejet.
Alaska
eakins screwed with this post 05-15-2013 at 12:34 AM
Old 05-15-2013, 01:03 AM   #76614
B1
Carbon-based bipedal
B1's Avatar
Oddometer: 3,430
posted this on the australian DR page then thought it might be worth dropping in here too.
i made a set of my own Legs Pegs for the DR. the moment i'm off road i like to stand pretty much all the time but it can get tiring on the upper body on all day rides, let alone five day rides.
just cut up and drilled some alloy plate, bought a pair of big door stops from the hardware, grabbed some spare alloy spacers, and stainless bolts. works a treat and cost $6... beats paying $150 for the real thing, which they don't make for the DR anyway.
did a bit of a write up on drriders here if you want to see more piccies.
free enduro training vids for gumbies here
B1 is offline   Reply With Quote
Old 05-15-2013, 05:10 AM   #76615
canoli
human
canoli's Avatar
Oddometer: 1,754
Nice! Let me know if you start selling these as I am very interested.
Canoli
canoli is offline   Reply With Quote
Old 05-15-2013, 07:52 AM   #76616
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,075
Originally Posted by Tex76
Just had this problem too, I have the gasket ready to go in but spread some RTV Sealant around the gasket to get me through the weekend, and it sealed the leak completely. A good stop gap if you need to buy some time.
Thanks Tex but the DR can sit until I get time to resolve the issue. I have a CCT gasket on order (even though I know I don't need one) and will R/R the starter motor, and lube the internal bushing, at the same time.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-15-2013, 08:13 AM   #76617
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 873
Are you going to pull the starter to lube? I read a writeup where a guy just drilled a hole, lubed, then plugged it back up. I need to do the same thing, starting mr DR in the morning wakes up every dog within 5 miles
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is online now   Reply With Quote
Old 05-15-2013, 08:25 AM   #76618
8gv
Oddometer: 2,478
Flat spot?
I'm new to DR's. My experience so far has been to test ride three, one of which I have purchased. All three had a flat spot on moderate acceleration. Am I to assume this is common to all of them? Could all three have sat too long and have goo in their carbs? The bikes were 2006 and 2008 models.
On my previous rides, KLR250 and KLS250s, there is a capped fuel screw on the carb which, when turned richer, helped eradicate this problem. I see this on my DR carb as well. How much of an improvement can I expect from this adjustment?
Yes I did read most of the carb banter here but hope to accomplish a reasonable improvement with the least invasive surgery.
8gv is offline   Reply With Quote
Old 05-15-2013, 09:37 AM   #76619
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Adjusting the fuel screw may help the flat spot. But other things can be done as well, none are hard or too involved.
It is definitely worth it to install an Extended Fuel Screw on your DR's BST Carb. Buy one from a local vendor. Allows very easy adjustment when motor is running. Great for fine tuning and altitude changes.
The Fuel screw is located at bottom of Carb, in front of float bowl cover. It has a tin cover over the orifice it sits in. Poke Tin cover with a wall board screw, pull out Tin cover.
Best to remove Carb to do this ... but you CAN get to the fuel screw if you loosen band clamps at air box and manifold, remove choke cable and throttle cable, then ROTATE carb around 90 degrees. This gives access to bottom on Carb. Carefully unscrew fuel screw ... do NOT lose washer, O ring and spring. Use them when you install the Extended Fuel screw.
Really easier to remove Carb from motor. Take your time, step by step. Lots of tutorials here and elsewhere. Once Carb is off you will need to remove the very tight Phillips screws holding float bowl on. Carefully use an Impact Driver to remove those really tight screws. Use a JIS bit.
Old 05-15-2013, 09:58 AM   #76620
motolab
motolab's Avatar
Oddometer: 2,777
Possible reasons are:
Blocked air flow due to very dirty filter.
Blocked air flow due to rag/registration paperwork/mouse nest/other obstructing inlet.
Overflowing carb due to dried/cracked/shrunken/deformed/otherwise damaged needle seat o-ring.
Overflowing carb due to worn out float needle tip.
Overflowing carb due to dirty float needle seat.
Overflowing carb due to leaking float(s), i.e. fuel inside the float(s).
High fuel level due to worn out float needle tip or sacked out needle plunger spring.
High fuel level due to misadjusted float height.
High fuel level due to leaking float(s), i.e. fuel inside the float(s).
Worn out emulsion tube due to worn out slide guide and/or removal/damage to/modification of the white needle spacer and/or use of a stainless steel or titanium jet needle.
Cold start enrichment circuit active after warm up due to damaged/misadjusted cable and/or missing/worn out return spring.
Main or pilot air bleed circuit obstructed.
Main or pilot jet fallen out.
Slide spring clipped.
Jetted incorrectly.
Fuel screw misadjusted (too far out).
Regards,
Derek
motolab is offline   Reply With Quote
Times are GMT -7.   It's 03:33 AM.
