Old 05-16-2013, 09:56 AM   #76696
procycle
procycle's Avatar
Oddometer: 2,410
Originally Posted by motolab View Post
I have some simple questions for you:
1) Do you deny ...?
2) If not, do you believe...?
Again, trying to deflect from the main point which is your claim that a DR650 can be made to run properly with an open airbox and an OEM needle.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 05-16-2013, 10:03 AM   #76697
acesandeights
Asperger
acesandeights's Avatar
Oddometer: 4,022
I sure wish I had the opportunity to loan my bike to Derek for a while. I've had one interaction, via PM, with Derek. It was very professional.
All the snarky sniping is unbecoming Jeff. I'm not you, but I'd step back just a little. Let people accept or reject Derek's comments unless you know he's saying something absolutely untrue. Otherwise you are coming across (to me) as petty.
If people wanted to be snarky, there are plenty of opportunities to do that related to experiences with Procycle too. Best, in my opinion to treat people or businesses professionally, especially online. You have a lot of experience specifically with the DR. From what I've gathered, Derek has a significant amount of broader knowledge or experience and he is speaking from that broad knowledge and experience.
http://breakingbooks.wordpress.com
Amazballs Indi-music at https://soundcloud.com/sprunty2000/
I may not be Rainman, but I'm not stupid eighter. Like Bartek on a taco.
I'll die with this hammer in my hand.
acesandeights is offline   Reply With Quote
Old 05-16-2013, 10:05 AM   #76698
motolab
motolab's Avatar
Oddometer: 2,777
Originally Posted by procycle View Post
This is what you always do - try to deflect the conversation away from the point. Results are what matters. You have none.
I do have proof that the DJ needle does not work. Where is proof to the contrary?
My questions were right to the point, because either the needle shape trends are not the needle shape trends, the the needle shape trends are the needle shape trends and the DR650 is somehow exempt from them, or the non-USA adjustable OEM needle will work better than the DJ.
Regards,
Derek
motolab screwed with this post 05-16-2013 at 12:14 PM
motolab is offline   Reply With Quote
Old 05-16-2013, 10:06 AM   #76699
motolab
motolab's Avatar
Oddometer: 2,777
I unwaveringly maintain that it can be made to work better than the DJ needle.
Regards,
Derek
motolab screwed with this post 05-16-2013 at 10:23 AM
Old 05-16-2013, 10:48 AM   #76700
procycle
procycle's Avatar
Oddometer: 2,410
I do have proof that the DJ needle does not work. Where is proof to the contrary?k
Yet again, trying to deflect from the main point which is your claim that a DR650 can be made to run properly with an open airbox and an OEM needle.
Old 05-16-2013, 10:49 AM   #76701
procycle
procycle's Avatar
Oddometer: 2,410
Yes, you have said that countless times but offer no results to back it up.
Old 05-16-2013, 10:58 AM   #76702
procycle
procycle's Avatar
Oddometer: 2,410
I apologize if I am comming off as snarky. It is certainly not my intention. Maybe adding some smileys will show that I have no animosity. I'm not trying to beat Derek up. I truly wish he would produce the results I am asking about. I believe such an accomplishment would benefit all DR650 riders who want to improve their motorcycles.
Old 05-16-2013, 12:12 PM   #76703
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 4,086
One slight correction though - it's CO (rather than CO2) that's the best indicator of mixture strength, and would therefore hopefully be shown on a dyno chart.
My mistake. I corrected it (so no one gets confused).
This is what it takes to make the DR run properly with an OEM needle.
Thanks for confirming Jeff, I may start a search for an unmolested air box.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-16-2013, 12:15 PM   #76704
motolab
motolab's Avatar
Oddometer: 2,777
Are there any charts to look at with the modified airbox in place?
Regards,
Derek
Old 05-16-2013, 12:26 PM   #76705
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,771
when he gets older wiser he'll reverse that transaction
Originally Posted by TrophyHunter View Post
http://www.advrider.com/forums/showthread.php?p=21346477#post21346477
Shameful plug for new DR items. Son sold his DR....bought my Strom.
Zapp
"I will not let the White City fall... nor our people fail. - Aragorn
K4 WEESTROM Stealthfighter Black -SOLD - Invisible to Radar, '02 DR650SE SOLD ,'Ole 97' DR650SE My Fave K5 WEESTROM ADVbomber
Zapp22 is offline   Reply With Quote
Old 05-16-2013, 12:44 PM   #76706
Zapp22
ZAPP - Tejas
Zapp22's Avatar
Oddometer: 13,771
Help me ID this Mystery Part
hmmm..... I just discovered today that a pair of "DR" headlamp/fairing "ears" I have had stashed are not....
But on a glance, they look like they are, and are actually identical in most respects except they are for a bike with bigger diameter fork tubes: 50mm to be exact. And the spacing of the rings is about 15cm
DR Big?
Zapp
Old 05-16-2013, 12:48 PM   #76707
procycle
procycle's Avatar
Oddometer: 2,410
DRZ400SM
Old 05-16-2013, 12:49 PM   #76708
Rainier_runner
Epic Adventurer
Rainier_runner's Avatar
Oddometer: 312
DR Big?
They're from a DRZ Sm. Can also be used with the factory DR headlight assembly if you convert to USD forks.
2014 KTM 1190 Adventure R
2006 Suzuki DR 650 ADV
Rainier_runner is offline   Reply With Quote
Old 05-16-2013, 01:13 PM   #76709
Richguzzi
Richguzzi's Avatar
Oddometer: 63
I'm worn out after reading the last three pages
And I think I have a case of concentric depression....
2012 DR 650
1986 Cagiva Alazzurra Tracker/Fighter/Cafe/Brat/Bobber project
1971 Moto Guzzi Ambassador
Slow old grey haired guys with arthritis and other ailments rule!
Richguzzi is offline   Reply With Quote
Old 05-16-2013, 01:23 PM   #76710
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
My DR has stock jetting,stock airbox with snorkle,stock pipe,yet I still get out of bed and put my pants on one leg at a time just like most guys.
Even with stock HP it handles like a pissed off hog if I pitch it sideways and pin it like my 530 KTM loves to do.
Im glad it doesnt make any more power,it dont need it.
Except maybe on the pavemento where all singles are too slow.
Feel free to continue with the jetting/carb/airbox wars though.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Times are GMT -7.   It's 04:05 AM.
