Old 05-21-2013, 07:14 PM   #76891
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Originally Posted by motolab View Post
OK, so just to make sure I understand, your NZ/AU DR650 came with a bare brass emulsion tube, but the NZ/AU spec replacement is nickel plated?
Regards,
Derek
I ordered a Needle Jet for a DR650 locally and got the nickel plated Y5-M instead of our brass Y5.
NordieBoy is offline   Reply With Quote
Old 05-22-2013, 12:29 AM   #76892
ketur
dat stonk
ketur's Avatar
Oddometer: 29
I just found out previous owner put rear axle in the wrong direction. Nut is on left side. I don't think this is catastrophic but I'm finding a rather large handful of funny things on this bike. Also I'd say the rear axle was torqued to about 20ft lbs... Thank goodness for cotter pins...
ketur is offline   Reply With Quote
Old 05-22-2013, 12:38 AM   #76893
Magnum Noel
Magnum Noel's Avatar
Oddometer: 196
Originally Posted by RideAlongAtlas1 View Post
My new DR650 has not done more than 200km on its standard tank. I've had in around 2 months. Conked out twice. At the moment it's in the garage and has done close to 200km, but I turned it to reserve earlier this evening as I was riding along.
"A DR650 does 200km on a standard 13l tank. It therefore uses 6.5 litres per 100km".
Under normal urban and highway conditions. Fair or unfair statements?
Mine uses between 4.5 and 5.5L per 100k depending on riding style etc. Standard exhaust and DJ kit.
Magnum Noel is offline   Reply With Quote
Old 05-22-2013, 12:42 AM   #76894
blackcap
blackcap's Avatar
Oddometer: 550
just a couple of quick questions to the collective knowledge pool; will the stock chain guide work with a 47t rear sprocket? and do the powerbomb header pipes have any special technology inside that little expansion chamber, or is it just that, an empty expansion chamber?
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 05-22-2013, 04:55 AM   #76895
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Originally Posted by Chill View Post
Sounds similar to my first few tanks.I used to get about 230km to the standard tank eventually from memory. But I also remember the first few tanks went quick until I got the hang of how to get the most out of the bike. I came to if from a big 4CYL bike and the power's in a different place here. I switched to a Clarke tank 15L and it goes to reserve around the 300km mark, so I'd probably run dry at 350km.
What fuel do you put in. I used to use BP95 but have tried 98 recently, feels a bit quicker but that could be in my mind. I was getting occasional pinking on 95.
I've been using 91 octane. Do you reckon if I went higher it'll help? What is 'pinking'? Cheers
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 05-22-2013, 05:07 AM   #76896
rpet
Awesometown
rpet's Avatar
Oddometer: 820
probably not; probably not; yes.
'76 Xl250 '04 XR250R '09 DR650 '10 TR450
Ride The West - OBDR, CDR & western TAT - July 2013
Instagram with plenty of bike pics.
Read my homie's underway Africa trip RR - Round Africa with a Surfboard
WTB: Clarke tank for DR650 for cheap - any color but blue.
rpet is offline   Reply With Quote
Old 05-22-2013, 05:53 AM   #76897
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,737
I run the highest octane I can find. Usually 93. I get "pinging" (detonation) at heavy load. Usually too low of a gear at a large throttle opening, like when you should be downshifting, but can't because you are climbing a hill in nasty rocky terrain and can't get to the shifter quick enough. It is worse for my bike on lower octanes.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 05-22-2013, 06:41 AM   #76898
8gv
Oddometer: 2,522
So let's see if I got this right...
Valves are in spec
Stock everything
Plugs are new, gapped and clean
I was getting some light backfire when using engine braking with the throttle closed. I turned the mixture screw richer (out) a half turn and it went away.
I did this because I believe the backfire came from a lean condition.
Am I right?
8gv is offline   Reply With Quote
Old 05-22-2013, 07:25 AM   #76899
3DChief
"Moto therapist"
3DChief's Avatar
Oddometer: 412
No. The backfire comes from a lack of a decel circuit in the BST40 carb. Many carbs have a circuit that trickles a small amount of fuel when the throttle is closed and that's why you don't hear it on them. Suzuki chose not to use that system. The only correct way to get ride of it is to replace the carb with one that has a decel circuit. That backfiring is not hurting a thing, Suzuki engineers know a thing or two about engines.
Tim
3DChief is offline   Reply With Quote
Old 05-22-2013, 08:27 AM   #76900
thump!
thump!'s Avatar
Oddometer: 1,647
Usually pinging means you're on the lean side of stoichometic combustion for a given compression ratio and timing advance. Higher octane fuel exists for the purpose of preventing detonation. Those fuels burn more slowly than lower octane. Theoretically you will get maximum fuel mileage and maximum power running the lowest octane that prevents detonation (pinging).
thump! is offline   Reply With Quote
Old 05-22-2013, 09:24 AM   #76901
dresda
shut up and RIDE!
dresda's Avatar
Oddometer: 999
Pinging aka as pinking sounds like a bunch of metal sock knitting needles dropped onto a concrete floor. Just in case anyone wonders what it sounds like.
Sent via aldis lamp on Tapatalk
Stephanie
'01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon
dresda is offline   Reply With Quote
Old 05-22-2013, 09:59 AM   #76902
ER70S-2
ER70S-2's Avatar
Oddometer: 7,259
Am I right?
Although the backfire went away, so did several MPG. The mixture screw flows fuel at all throttle openings and wastes some fuel doing so. Tim nails the explanation below.
Originally Posted by 3DChief View Post
No. Yes. The backfire comes from a lack of a decel circuit in the BST40 carb. Many carbs have a circuit that trickles a small amount of fuel when the throttle is closed and that's why you don't hear it on them. Suzuki chose not to use that system. The only correct way to get ride of it is to replace the carb with one that has a decel circuit. That backfiring is not hurting a thing, Suzuki engineers know a thing or two about engines.
Tim
Fixt to avoid confusion, even if I was the only one.
Technically, the backfire comes from a lean condition, as you went on to say.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 05-22-2013, 10:17 AM   #76903
yachabibi
Oddometer: 34
so... cop pulled me over, tail light not working
Last night, toward the end of a very long ride, 650 miles, a cop pulled me over to tell me that tall light wasn't working.
I had to tape my flashlight ( red led) to my luggage rack so cop would let me go.
I have the 250 mod and the led license plate light.
Neither are working when the bike is on but both light up for breaking.
this problem is also intermittent.
where do I even start trouble shooting?
Apart from replacing turn signals and battery I have installed Oxford heated grips and hid headlight from procycles.
thanks
yachabibi is offline   Reply With Quote
Old 05-22-2013, 10:33 AM   #76904
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Yea, seems counterintuitive. Also, the mixture screw flows fuel even when throttle is fully closed, that fuel is wasted.
I found by leaning out my mixture screw (pilot fuel screw?), my overall MPG went up from about 46 MPG up close to 50 MPG. My idle is just a tiny bit lumpy but worth it for the improved MPG. I have the stock muffler and wear ear plugs, so the minor backfiring not an issue (for me). With a loud Yosh pipe (or other loud pipe) ... it may drive you crazy?
Old 05-22-2013, 10:44 AM   #76905
ER70S-2
ER70S-2's Avatar
Oddometer: 7,259
thanks
Hi Yachabibi and welcome to the site.
The plate and tail light run on the same wire, start at the tail light and work your way forward.
Do us a favor and fill in your profile location; state or country.
The red circles indicate connectors that aren't used in the USA. So you'll find plugs just hanging around, don't fret.
2013 WR250R
Times are GMT -7.   It's 07:16 AM.
