Old 05-22-2013, 02:02 PM   #76921
motolab
motolab's Avatar
Oddometer: 2,584
Originally Posted by ER70S-2 View Post
The mixture screw flows fuel at all throttle openings and wastes some fuel doing so. Tim nails the explanation below.
While that's technically correct, the difference is greater the more the throttle is closed and therefore the higher the vacuum that is trying to suck fuel past the exposed area adjacent to the tip of the screw. At WOT a fuel screw adjustment may or may not be detectable at all as a change in CO%.
Regards,
Derek
motolab is online now   Reply With Quote
Old 05-22-2013, 02:05 PM   #76922
motolab
motolab's Avatar
Oddometer: 2,584
Originally Posted by Adv Grifter View Post
I found by leaning out my mixture screw (pilot fuel screw?), my overall MPG went up from about 46 MPG up close to 50 MPG. My idle is just a tiny bit lumpy but worth it for the improved MPG.
Part throttle should be tuned with the responsible circuits, not with the fuel screw.
Regards,
Derek
Old 05-22-2013, 05:06 PM   #76923
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Regards,
Derek
I was not tuning it for part throttle. I was tuning it at Idle/shut throttle ... I was wasting fuel on the over run (like shutting off coming into corners).
Leaning out produced a significant increase in fuel economy.
As you stated above, on the over run with shut throttle, vacuum is increased, sucking fuel past fuel screw needle. YMMV.
Old 05-22-2013, 05:11 PM   #76924
motolab
motolab's Avatar
Oddometer: 2,584
Thanks for clarifying.
Regards,
Derek
Old 05-22-2013, 06:27 PM   #76925
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,842
I did Colleen's DR Neutral safety mod today. YES...the Phillips screws were barely hand tight.
I replaced them with drilled stainless socket head Allens, blue Loctite AND safety wire. I would have just left it off but she likes the green light.
DON'T OVER LOOK YOUR NEUTRAL SAFETY GUYS, IT COULD BE A DISASTER.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 05-22-2013, 07:04 PM   #76926
Burnt Toast
Slingshot: engaged.
Oddometer: 214
Throttle sticking
So, over the last few rides my throttle started sticking a little, then a lot. Today it won't return on it's own. I took it apart and cleaned the bar which had some crud and rough spots on it. I used some fine sandpaper and sanded it until smooth. Put the throttle body on without cable and housing...smooth. Each of the cables moved pretty freely with good spring tension on throttle cable. I lubed the cables while I was there. Reassembled...dragging again. I took the housing off and held the cables with my hand and turned the throttle...smooth. I assembled the housing with the throttle body off of the bar...smooth.
It seems that the housing is putting the assembly in a slight bind. I can't find any spots that appear to be rubbing, but it acts like it is. No crashes or bump-ups. Bike has only been used on the street since I owned it.
Thoughts?
Burnt Toast is offline   Reply With Quote
Old 05-22-2013, 07:45 PM   #76927
joexr
Oddometer: 3,773
Thoughts?
Cables too tight?
Old 05-22-2013, 07:54 PM   #76928
ketur
dat stonk
ketur's Avatar
Oddometer: 28
I'm dreading this work, specifically removing the clutch basket and the complications that come from that. I'm probably going to end up trying to yank the thing out and be done with it... unless I can't get that upper screw anyhow.
ketur is offline   Reply With Quote
Old 05-22-2013, 07:55 PM   #76929
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,503
Cables at bad angles.
Which I never mind since I ride a lot of street, and have bikes do that since 1993. If I want more throttle I turn it, and if I want less - I still turn it. If I want to take my hand off of the throttle and stretch that arm, or ride with no hands and stretch my torso ... I'm free to do so.
But I understand why any dirt bike or bike ridden off road should have a snappy return throttle.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 05-22-2013, 08:42 PM   #76930
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 677
With a little patience it can be done with the basket on. I switched my phillips head screws over to allen heads with no problem leaving the basket in place. I think if you do a search I think you'll find about 40% of us have done it that way.
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 05-22-2013, 08:42 PM   #76931
Chill
Chill's Avatar
Oddometer: 315
Originally Posted by RideAlongAtlas1 View Post
I've been using 91 octane. Do you reckon if I went higher it'll help? What is 'pinking'? Cheers
I'd avoid the 91 in Australia these days as most 91 octane brands seem to be E10.
Try a tank of 95, see if it's better. I had a look at some receipt I had of my first few fills. Starting with a full tank, I got 193km = 8.12L to fill it back up and 129 - 6.83L to fill it back up. Maybe the standard fuel tap (petcock) is going onto reserve at 8L instead of when you've only got 1L left.
Chill is offline   Reply With Quote
Old 05-22-2013, 08:45 PM   #76932
ER70S-2
ER70S-2's Avatar
Oddometer: 6,281
Thoughts?
One of the best wheelies I ever walked was after spending the night next to a campfire after spending the day tipping over in a riverbed (bike died every time it saw water, at the most inopportune moments). Everything on the bike was full of sand. Once we got out, we rode through the Memorial Day camp sight. Guys walked up and said "Are you the guys that spent the night on the Muddy?" Yep, that was us. As I rode away on the single track, I popped a wheelie. Much to my surprise it was the 'perfect storm'. Hit the balance point, coasted, rolled the throttle on and off as needed. The sand filled throttle was under my complete control. Sure wish I could do that on the DR.
Don't be afraid, we'll talk you through it. Just be patient and don't force anything. When I forgot to plug in my NSU after removing the shock, the bike wouldn't idle in neutral on the kickstand. That sucked. This is a life lesson and you want to learn it now. Patience: It might even save your marriage.
Thoughts?
What year, how many miles?
2004 DR650: 62,496 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 05-22-2013 at 08:51 PM
ER70S-2 is offline   Reply With Quote
Old 05-22-2013, 08:49 PM   #76933
Chill
Chill's Avatar
Oddometer: 315
And we have another one.
To clarify, this is 95 RON rather than 95 (R+M)/2, right?
Regards,
Derek
Not sure what I'm another one of? I assume it is RON. I have only ever seen RON at the pump, I have not seen or heard of (R+M/2) before. In Australia many brands of 91 are now E10 (10% Ethanol) so are generally avoided. Some better info here http://www.bp.com/retail/liveassets/...nd_PowerV2.pdf
Old 05-22-2013, 08:57 PM   #76934
GSF1200S
Oddometer: 976
I don't know what your experience level is, I'm not trying to talk down to you or scare you.
I just did my CCT gasket last week, I don't even have the pipe back on yet. Some bits: If you decide to use RTV instead of fighting with gasket removal, you don't have to take anything off to remove the CCT. Is it easy, nope, but can be done. Why would you want to do that? The two bolts holding my exhaust manifold to the head were tight. If one breaks, you'll have to deal with getting the broken bolt out of the head. So I decided to WD-40 the bolts and let them sit overnight. I squirted the seam between the flange and the head, flushed it good so the WD could wick up the threads overnight. My point is, if your pipe hasn't been removed recently, hose it down tonight. Both bolts went off like gunshots when I removed them.
If you decide to remove and replace the gasket, the pipe and oil lines have to come off so you can get in to scrape. I used Permatex Gasket Remover but it was painfully slow. Although I don't like using power anything on an alum gasket surface; I used a 2" Roloc on an air grinder to get the worst of the gasket off, that gasket is stuck. You can re-use the washers on the banjo fittings, worse case is they'll seep a tiny bit of oil until you can get new washers.
Another potential problem: in the photo with the screwdriver stuck in the CCT, the handle is exactly where the pipe lives. You'll need a pretty short screwdriver in order to fit in the end of the CCT to release the plunger.
Good luck, let us know how it went.
In this photo with the pipe off you can see that the CCT will clear the starter and bracket that fastens the end of the clutch cable, if you choose to use RTV. (which may have to cure overnight ??)
Totally didnt take it as condescending or trying to scare me. I would consider myself "reasonably proficient" with the DR having taken most of it apart at one point or another, though most of my experience is with older cars. Biggest problem isnt that im not comfortable doing the job- its that I have a "on-the-road" toolkit and not my entire tool collection available.
I might try an RTV (ultra black oil resistant sound good?) solution and see if it holds. Mine is leaking pretty bad, and will certainly require a good bit of rag, qtip and carb cleaner cleaning at this point. Do I just try and goop the shit on as accurately as possible with the header in the way? I know what you mean about pulling header bolts as I had a bit of a nightmare with my Bandit replacing its header. I wonder how much a shop would charge to do this?
GSF1200S is offline   Reply With Quote
Old 05-22-2013, 09:02 PM   #76935
GSF1200S
Oddometer: 976
I hear you, but really it isnt that bad. Rather than trying to snake the bolts out, I just removed the clutch basket. Good thing to know how to do- if you ever need to replace a clutch it will save you tons of money in labor. There isnt really much you can mess up- just take pictures as you take it apart. You can usually slide the fibers/metals off all at once and set them down. Getting the clutch basket nut off is as easy as fifth gear+ rear brake, and thats really it. It sounds bad but its really not- I dreaded it too
Times are GMT -7.   It's 02:10 PM.
