Old 05-23-2013, 09:22 PM   #76966
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,807
Originally Posted by Chill View Post
I'm still debating the muffler issue. I've found a 2nd hand Gixer pipe but it's working out to be $400+ once I've factored in the mid pipe etc, and that's a lot considering the end result will be a 10 year old frankenstein exhaust. For that price I could....
Looking at the FMF Q4 on the procycle site... so how quiet is quiet? Does anyone have recent experience of these? Is it possible to pack them more and make them quieter? I have an FMF header already and it runs well with the STD airbox (+K&N filter) and STD carb. If I add the end pipe will it still run well or will I have to rejet? I'm a bit confused with rejetting, is it done to balance changes to the airbox and/or changes to the exhaust? I'd like to keep the airbox and carb standard if possible.
just pick up one of the Busa pipes instead. They are MUCH cheaper and easier to find than the 40 GSXR muffler and Jesse's setup is that they only stick out maybe 1/2" more than the GSXR pipe. The beauty in this setup is you don't need to repack ever and the noise levels are closer to stock plus it looks stock.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-23-2013, 09:23 PM   #76967
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,137
Originally Posted by eakins View Post
Bet those will be real popular as most every DR squeals.
Only if you wash them.
I still want one...
DR650 Wiki
NordieBoy is offline   Reply With Quote
Old 05-23-2013, 09:37 PM   #76968
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by warp9man View Post
Hey guys, I couldnt stand it any longer. After listening to my DR and nearly every other DR I came across sound like the starter was a squealing pig I took one apart and found that the backside of the starter has a simple brass bushing in it that wears out. My bike had around 8k miles on it when the starter started squealing, I took it apart and greased the bushing and that worked for a while then it went back making that embarrassing sound that makes you hold your head in shame when you hit the E-buttonghead:. I couldnt take it any longer so off to the CAD program I went and came up with this little beauty.
Behold!! A new starter cap with a real sealed bearing in for the armature shaft :
I have been running the prototype for some time now. Im pretty happy with how it turned out. A few quick mods and she going into production after the holiday. I hope you guy's approve
This should make the starter brushes last longer and reduce the amp's needed to start the bike when your bushing is headed south.
Wow! Great work! I hope you are on Vendors forum?
Good luck with it!
Old 05-23-2013, 09:52 PM   #76969
warp9man
Gravel in my Travel
warp9man's Avatar
Oddometer: 595
Good luck with it!
Nope not on the vendors forum yet. Guess I better get to work on that.
Thanks guys!
warp9man is offline   Reply With Quote
Old 05-23-2013, 10:59 PM   #76970
ketur
dat stonk
ketur's Avatar
Oddometer: 28
Originally Posted by Albie View Post
So a couple years ago when I bought my DR it came with a TM-40 carb, modded air box and a full FMF system. I never really liked the set up when I would ride it back to back with my buddy's DR that is all stock. Well I managed to find a BST carb and unmodified air box for cheap, and the PO gave me the stock exhaust with the bike.
So I got all the stock stuff bolted on today and took it for a test ride. Man, the bike just runs sooooo much better. It revs up much quicker, in fact I almost ran into the back end of my buddy not expecting it to accelerate that quickly. The bike just runs much smoother and the quiet exhaust is just a relief after that noisy assed FMF can.
It's actually easier to ride, especially doing some climbs on some pretty rutted out and muddy hills. With the pumper carb I seemed to always have to shift a lot more trying to keep up the revs. With the BST I can lug it and the bike will still pull. I have a feeling I'm going to see an improvement on mileage as well.
The only down side is the obvious increase in weight, but this is a pig of a bike anyway so I can live with a half dozen extra lbs.
Previous owner gave me stock exhaust, as it currently has a Two Brothers exhaust, and I'm still unsure of jetting mods. You inspire me to hurry up and put stock exhaust on and see how that feels.
ketur is offline   Reply With Quote
Old 05-24-2013, 12:01 AM   #76971
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,899
The 2009 I recently got had carb mods. Drilled out slide, different jets, needle, cut open airbox. Kientech header/ mid-pipe. GSXR can. Air screw.
All it did was make more noise. Stumbled on take off.
I put the standard jets back in the carb, standard needle back in, covered up the airbox. New slide with one hole. I kept the air screw and exhaust mods. Installed a K&N filter.
Runs like a champ now. Smooth and no stumble on take off. It used to 'hic' after you rolled the throttle on for a tad. You had to rev it at stop lights and let the clutch fly to overcome this.
So easy to ride now. I have a 16T front with OEM rear. It topped out at 100mph showing on speedo with me sitting upright behind National Cycles screen. Also a one foot square TT 41L top box on the rack...not bad.
My normal speeds will be speed limit and a tad over, so I'm good to go.
It sure likes to go around bends I'll tell you that. It holds the line nicely and inspires confidence. You have to keep it on the boil and with the 16T front that means lower gears for tighter bends. Coming from a BMW R1150GS that ran like a diesel big rig this is a change of pace for me. The lack of torque takes some getting used to....but I love it! I thought it was a bit buzzy on the freeway with the 15T front, and I do some freeway so have to compromise.
your mileage may vary
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is online now   Reply With Quote
Old 05-24-2013, 12:16 AM   #76972
thetable
thetable's Avatar
Oddometer: 1,444
Originally Posted by thump! View Post
Actually 32 ft/sec/sec regardless of mass.
In a vacuum.
thetable is offline   Reply With Quote
Old 05-24-2013, 01:18 AM   #76973
LexTalionis
Inciteful
LexTalionis's Avatar
Oddometer: 441
Originally Posted by thetable View Post
In a vacuum.
Damn! I was waiting till I had read to the end of the thread before posting the exact same response, and then read I had been beat!
Good call.
Lex
The older I get, the better I was.
LexTalionis is offline   Reply With Quote
Old 05-24-2013, 04:54 AM   #76974
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,651
Thanks guys!
I'm interested! If the cover's as well made as the Warp9 levers on our two DRs, we'll be able to forget that little issue forever!
Old 05-24-2013, 05:57 AM   #76975
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,570
Originally Posted by Foot dragger View Post
FMF's are loud,maybe their newest Q model is quieter but Id hate to have to listen to the noise all day on my DR,I have the older Q muffler on my 530 and it runs great that way,but can be heard a ways off.
With just a 14 tooth countershaft sprocket my DR will climb great and slide corners in the dirt easily,the only way a DR will keep up with a 530 is to toss both out of a plane and see which falls faster.
I've got a Q4 on my KX 450F and it is actually QUIETER then the stock can. Of course there were reports that guys failed tech because the stock cans on those 09 KXF's were too loud.
Mine came with the 14 tooth CS sprocket. Never wanted to go to the stock 15 myself.
Old 05-24-2013, 06:01 AM   #76976
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,570
LOL, I shudder to think how much money I threw away when I tossed my old stock Busa cans, back then they weren't worth the cost of shipping, I saw one on E-bay yesterday selling for $175!
Anytime you change the flow of the intake or exhaust or both you need to balance your carb to match. Actually, the K&N filter does flow more air, so you have modified your airbox.
Old 05-24-2013, 06:53 AM   #76977
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,878
Originally Posted by motolab
Yes. You did say it in a previous post. I saw it and promptly forgot.
We also chatted about it on the phone. But, with the amount of people that you speak with, I don't expect you to remember that.
That's obviously for you to decide, but I would have recommended continuing/widening the search. Did you make inquiries with Factory Pro, SuperFlow and Land & Sea?
You gave me a few names to check and they weren't able to help. I do not think SuperFlow or Land & Sea were on the list though. I'll be honest, it would be great for research (and I'm all about that) but another $250 for a dyno run is a little steep for my budget right now. I have a few other things I need to resolve, on the DR, and some farkles I'd like to buy first. So, maybe later this year or over the Winter, if I can find a dyno that's not too far away.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-24-2013, 06:55 AM   #76978
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,255
Holy schmoly: 77,000 posts about changing a DR from stock to modified. Have we peaked and are we now going the other way?
Changing everything back to stock. Might just be easier to buy a new one.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 05-24-2013, 07:00 AM   #76979
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,878
Kev, I'd be up for one of these as well, provided it doesn't cost one arm and one leg. Any ETA on when we can purchase?
Old 05-24-2013, 07:03 AM   #76980
Rusty Rocket
Life behind "Bars"
Oddometer: 9,255
I was hoping "after the Holiday" meant this weekend.
Mine squeals badly. But I just deal with it. Might want one also. Might be an easy job while I fix the CCT gasket soon.
Suzuki doesn't sell that part separately, you have to buy the whole starter. Does anyone have a source for brushes? There must be another similar starter from Japan that is the same.
2009 DR650
Times are GMT -7.   It's 12:42 PM.
