Old 05-24-2013, 09:38 PM   #77011
JagLite
JagLite's Avatar
Oddometer: 1,439
Talking Shocking!
Originally Posted by Rob.G View Post
First, a huge thank you to ProCycle! What a great operation.
Got home, spent the day cleaning the grime off the airbox, suspension, etc, and then installing a fancy new Cogent rear shock with their special shaft assembly and a 7.5 spring. The shock and spring feels great. I do need to do a little tweaking of the settings to get it just right. I softened the clicker on top by one click... but... how do you adjust the rebound on this thing? I don't see any other clickers anywhere. On my KLX, it's another screw thing down at the bottom. On that bike, I ended up going two clicks back on the Compression and two clicks forward on Rebound.
Rob
PS: I posted my white IMS tank in the flea market. :)
You didn't get a copy of the Moab shock tuning instructions?
You can read it or print it out on the PC website.
The quick answer is the red knob on the bottom of the shaft that goes around the shaft.
Attitude ~
The difference between
Ordeal and Adventure
James
JagLite is offline   Reply With Quote
Old 05-24-2013, 10:03 PM   #77012
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,280
Nope; just found it on their website, thanks! I do need to set my sag soon as I can find somebody to measure for me. I think I have it pretty close as it is.
Good to know on the rebound adjuster. I'll add a click or two in the morning before I head out.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G screwed with this post 05-24-2013 at 10:08 PM
Rob.G is offline   Reply With Quote
Old 05-24-2013, 10:15 PM   #77013
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 12,197
Originally Posted by Foot dragger View Post
2 up to Tierra Del Fuego on a DR? I like it! I tend to sit all the way back on the seat even at 6' tall to cruise slabs so 2 up must be perfect and more power to you!
NO! We have two DR's. The Mrs is an ADVRider! She's done 160,000 miles on BMW's since 2000.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 05-24-2013, 11:51 PM   #77014
BergDonk
BergDonk's Avatar
Oddometer: 3,931
Smoother then stock? My bone stock DR will climb anything its pointed at as smoothly as an electric motor,refuses to stall and runs the same from 10,000' to sea level. The plug has never shown a lean condition,it gets 50 mpg most all the time. I dont think I'll mess with it.
Its almost like the factory engineers tuned the airbox/exhaust/carb to all work together as a package and get the best happy medium for many uses.
A bike this big and tank like really doesnt need to go faster in the dirt.
Way smoother.
The best you've ridden, is the best you know!
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 05-25-2013, 04:32 AM   #77015
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Haven't been on here much lately, but does anybody have these?
http://www.ebay.com/itm/1996-2010-Su...af71a9&vxp=mtr
They seem pretty near, but I wonder how they really perform.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 05-25-2013, 10:04 AM   #77016
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,746
Also, I got a rim lock in my last Rocky Mountain ATV/MC order since I have a set of D606's to go on my spare wheelset. But I was just thinking... do the DR wheels have holes for them or will I need to drill one? If I have to drill, where should I put it? Close to the valve stem or opposite from it?
Rob
I put my rimlock 4 spots over from the valve stem Because that is where every dirtbike I've ever owned puts them I know there's a reason, but not the details. Yes, you must drill the rim yourself. Make sure you got a 2.50 rimlock if you have the stock rim.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 05-25-2013, 10:31 AM   #77017
poppawheelie
poppawheelie's Avatar
Oddometer: 595
Originally Posted by TUCKERS View Post
The 2009 I recently got had carb mods. Drilled out slide, different jets, needle, cut open airbox. Kientech header/ mid-pipe. GSXR can. Air screw.
All it did was make more noise. Stumbled on take off.
I put the standard jets back in the carb, standard needle back in, covered up the airbox. New slide with one hole. I kept the air screw and exhaust mods. Installed a K&N filter.
Runs like a champ now. Smooth and no stumble on take off. It used to 'hic' after you rolled the throttle on for a tad. You had to rev it at stop lights and let the clutch fly to overcome this.
When I set up my DR in 2009, I went just a little richer than stock and have been happy with it ever since. It pulls smoothly through the rev range. Like someone alluded to, it's not an MX bike. Opening up this and that makes more noise than anything else.
Reminds me of the Harley guys. I'm still trying to get the Street Glide I bought months ago to run right. It sure made enough noise with the Vance and Hines and opened air filter the previous owner put on it. I corked the V & H, but the air box and mapping are wrong, just messed up and did nothing but make noise. Couldn't find a stock muffler and air box via Craig's List, or I would have put that on. Would get better gas mileage too, I'm sure.
"To me the trail is calling! The old trail - the trail that is always new." Matthew Alexander Henson
"It's not the destination. It's the journey." Me
poppawheelie screwed with this post 05-26-2013 at 06:50 AM
poppawheelie is offline   Reply With Quote
Old 05-25-2013, 10:43 AM   #77018
motolab
motolab's Avatar
Oddometer: 2,861
Originally Posted by poppawheelie View Post
Like someone eluded to, it's not an MX bike.
Is it possible that you meant "alluded"?
Regards,
Derek
motolab is offline   Reply With Quote
Old 05-25-2013, 11:15 AM   #77019
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
So, K&N filters are no good whatsoever?
Should I go back to OEM or use something else? No dirt riding.
Trip to Tierra Del Fuego planned, will try to find the best road surface possible as the Mrs Tucker doesn't 'enjoy' soft surface.
K & N are common and in use world wide on Bikes, Cars and big trucks. I'm sure they have thousands of loyal customers who have had good luck with the product. Some here rave about them ... so obviously not everyone has had problems ... and they certainly flow a lot of air.
I'm happy with Foam filters. If there was something better the Japanese OEM's would be using something different on their Race bikes. NONE are using K & N ... ALL are using oiled foam air filters .. and have been for 40 years. Now why is that?
Some K & N filters are sort of a "One Size Fits All" item. So perhaps in some cases that is allowing dirt ingress? I have no idea why dirt gets into them ... but I've seen it with my own eyes. The other thing is poor owner maintenance. Especially off road, a K & N will require more attention than a good Foam Air Filter. Not a good travel item, IMHO.
The Suzuki DR650 OEM foam air filter is well made, filters perfectly and strong. But it's just a but restrictive to air flow. This is NOT a big deal.
Many here have had good luck with Twin-Air foam filters. UNI Filter make a good Foam filter for the DR650 too. I've been running Twin-Air filters on my DR for nearly 50,000 miles. They filter very well ... NO DIRT gets in Carb if properly oiled and installed.
Take care of your Twin Air filters ... good for 20,000 miles of hard use. Should cover your S. America ride. Handle them with care, DO NOT use Gasoline to clean them. (Diesel is OK but rinse well with soap and water, never squeeze hard or wring out)
Off Road In S. America
I'm sure with practice your wife will become a better off road rider. Deep sand is tough, even for experts. Baby Steps. You guys will encounter rough sections, but most dirt roads are in decent condition. More and more is paved.
You probably should skip the Salar de Uyuni (Salt lake in Bolivia), but most everything else I'm thinking she can handle ... if carrying a light load on a well lowered bike and well set up bike.
When practicing off road remind your wife of the following off road riding techniques:
1. VISION: Look WELL OUT AHEAD, at least 30 yds. ahead. This will have a sort of miracle affect on her control and confidence. Look where you want to go ... and you will go there. Never look down just ahead of front tire. (bad!)
STAND UP: She will need to learn to ride the bike standing ... and do everything from that position. Not hard, just takes seat time. Baby steps.
RELAX ... your grip on the bars, steer with feet and knees on tank. RELAX.
BREATH: Many novice riders tense up off road ... and they stop breathing!
really true! If you tense up and hold your breath
(many do it unconsciously) ... you will tire quickly and get ARM PUMP.
POSITION: scoot back on seat in soft conditions, use a bit more throttle to keep bike going straight.
Practice Practice Practice!!!
Old 05-25-2013, 11:40 AM   #77020
TrophyHunter
Oddometer: 2,312
Regards,
Derek
I think he meant "Pedant". There's also a debate in the law office I work in whether the period is before or after the quotation marks.
Gosh, isn't this fun?
'07 WR450 2013 HD Road King '15 Tiger 800 XCx
TrophyHunter is offline   Reply With Quote
Old 05-25-2013, 11:55 AM   #77021
motolab
motolab's Avatar
Oddometer: 2,861
I don't follow.
Regards,
Derek
Old 05-25-2013, 12:00 PM   #77022
motolab
motolab's Avatar
Oddometer: 2,861
I can think of at least two cases where a K&N drop-in filter flows less air than stock.
That may be true for off-road racing (which is of course what's relevant to this thread), but for road racing it's not.
Regards,
Derek
Old 05-25-2013, 01:59 PM   #77023
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,958
No dirt riding.
I don't mind K&N's for street riding, in fact I have one for my 690 when I motard it, but I don't want them when it comes to any off road riding.
Albie screwed with this post 05-25-2013 at 02:12 PM
Old 05-25-2013, 02:09 PM   #77024
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,958
My buddys DR that's stock now had a FCR with all the MX Rob tricks and it definitely ran rougher then the stock set up. He only had it on his bike for like a month before he went back. He felt the tiny bit of advantage the FCR gave him didn't offset the annoying rough ride.
At the end of the day, no matter how much go faster aftermarket stuff I pile on my DR it's not gonna come close to touching my 690, so why even bother? I am more then happy with my DR set up the way it as ATM. I am so glad the PO was the one who dumped all the money into the bike and not me!
Old 05-25-2013, 03:55 PM   #77025
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,870
This is an interesting perspective you guys are describing. I've always heard / read the other carbs were so much better than the stock DR650 carb... is there a general agreement that no aftermarket carb runs / delivers as smoothly, and that the hoopla is really all about power delivery instead?
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Times are GMT -7.   It's 01:57 AM.
