Old 05-29-2013, 07:51 AM   #77101
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,952
I also have a PWD bash plate on my DR. I plan to get the DR engine guard set (from Perry @ AMP - LINK) which includes more protection for the oil filter cover. I don't think any bash plate provides enough protection for the sides of the motor (stator cover, clutch cover or oil filter cover).
I contacted PWD to find out what alloy they use to make these plates. It's 5052. I bought a piece of 2" x 12" x .1875" (3/16) 5052 from McMaster-Carr and will have that welded onto the leading edge of the PWD plate. The extension will provide more protection from debris slung up by the front tire. IMO, PWD seems to be one of the best available for the DR. I just would like a little more coverage.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 05-29-2013, 09:28 AM   #77102
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,343
Originally Posted by ketur View Post
The fork caps were insanely tight too, although maybe that's normal. Either way my hands were starting to be sore from various attemps so I added a little leverage...
You must loosen the clamp bolts before trying to take off the caps. I go so far as to spread them a bit with a stubby screwdriver before turning the wrench.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 05-29-2013, 09:52 AM   #77103
Mud Missile
Aventurero
Mud Missile's Avatar
Oddometer: 171
Cogent shock
[QUOTE=Rob.G;21488005]
Got home, spent the day cleaning the grime off the airbox, suspension, etc, and then installing a fancy new Cogent rear shock with their special shaft assembly and a 7.5 spring. The shock and spring feels great. I do need to do a little tweaking of the settings to get it just right. I softened the clicker on top by one click... but... how do you adjust the rebound on this thing? I don't see any other clickers anywhere. On my KLX, it's another screw thing down at the bottom. On that bike, I ended up going two clicks back on the Compression and two clicks forward on Rebound.
Also, I got a rim lock in my last Rocky Mountain ATV/MC order since I have a set of D606's to go on my spare wheelset. But I was just thinking... do the DR wheels have holes for them or will I need to drill one? If I have to drill, where should I put it? Close to the valve stem or opposite from it?
Rob
QUOTE]
Rob, I ordered the Mojave and I am waiting to get my hands on it to install it. I just finished reading the installation manual and the damping adjustment knob is at the bottom of the shock. You can turn it clockwise or counterclockwise to adjust it, according to the manual. How did the installation go? Any hints, comments, etc? I won't have much time to mess with it once it's delivered since I'll be heading to Mexico early June. I guess I'll be making adjustments on the go. Thanks
Mudmissile
Mud Missile is offline   Reply With Quote
Old 05-29-2013, 09:58 AM   #77104
ketur
dat stonk
ketur's Avatar
Oddometer: 29
Can anyone provide me with some insight on adding fork oil? Why do I see a weird syringe tool? Why isn't adding oil just a matter of dumping 565ml then calling it good?
ketur is offline   Reply With Quote
Old 05-29-2013, 10:13 AM   #77105
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,648
That's fine if you are happy with the stock air gap. The "weird syringe tool" is for fine tuning the gap.
Old 05-29-2013, 10:14 AM   #77106
TUCKERS
the famous james
TUCKERS's Avatar
Oddometer: 11,943
You can do that. You can also measure it from the rim of the fork top, I did on my two bikes.
James and Colleen Tucker.
Aut viam inveniam aut faciam
DMV work/insurance/registration/titles/address use/room rental/motorbike&vehicle buying/travelers help/problems solved
TUCKERS is offline   Reply With Quote
Old 05-29-2013, 10:28 AM   #77107
ER70S-2
ER70S-2's Avatar
Oddometer: 6,659
Originally Posted by Rob.G View Post
...........................Finally, I change the oil, lubed the chain and went for a ride. The shock and spring feels great. I do need to do a little tweaking of the settings to get it just right. I softened the clicker on top by one click... but... how do you adjust the rebound on this thing? I don't see any other clickers anywhere. On my KLX, it's another screw thing down at the bottom. On that bike, I ended up going two clicks back on the Compression and two clicks forward on Rebound.
Rob
Rob, does your shock have a knob on the bottom, like the red one on my Cogent with rebound? Do you have a photo?
Mine with 32,xxx miles finally got a new 7.5 spring to handle my 180 pound weight + 30 pounds riding gear and tailbag.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 05-29-2013, 11:54 AM   #77108
Rusty Rocket
Life behind "Bars"
Oddometer: 9,343
2009 DR650
Old 05-29-2013, 12:00 PM   #77109
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,753
No reason to loosen that top clamp - the forks are what looks like half an inch lowered so the clamp is nowhere near the top cap.
Emmbeedee screwed with this post 05-29-2013 at 01:33 PM
Emmbeedee is online now   Reply With Quote
Old 05-29-2013, 12:27 PM   #77110
8gv
Oddometer: 2,485
NSU and torque values...
My NSU task is going well and I'll soon be reassembling.
Can anyone please tell me what the torque values are for:
Clutch main shaft nut
Clutch spring bolts
Case cover bolts
Foot peg bracket bolts
I've looked at many tutorials online but I never see these #'s.
8gv is offline   Reply With Quote
Old 05-29-2013, 01:01 PM   #77111
Rusty Rocket
Life behind "Bars"
Oddometer: 9,343
Originally Posted by Emmbeedee View Post
No reason to loosen that top clamp - the forks are what looks like half and inch lowered so the clamp is nowhere near the top cap.
I'd still suggest trying it. The clamp can distort the tube out of round a bit, especially at the top and with what he's described concerning stripped threads and broken bolts, who knows how tight the clamp could be.
2009 DR650
Old 05-29-2013, 03:56 PM   #77112
BergDonk
BergDonk's Avatar
Oddometer: 3,679
Originally Posted by Bronco638 View Post
....................... I don't think any bash plate provides enough protection for the sides of the motor (stator cover, clutch cover or oil filter cover).
Still reckon that?
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is online now   Reply With Quote
Old 05-29-2013, 03:59 PM   #77113
dresda
shut up and RIDE!
dresda's Avatar
Oddometer: 987
I'm trying to compare heated glove liners to heated grips. The Warm N Save glove liners take 11 watts each. The Oxford grips site says they take 4 amps. How to compare? Anyone know?
I ran my Warm N Safe 90W jacket liner (with heat troller running at about 40%) and socks all last weekend in the cold and wind with no problems for the bike. Will a set of grips or gloves tip the balance unfavourably?
Stephanie
'01 Suzuki DR650 (Patsy Q), '11 VW Golf TDI Wagon
'....and I shall baffle you with cabbages and rhinoceroses in the kitchen, incessant quotations from "Now We Are Six" through the mouthpiece of Lord Snooty's giant, poisoned, electric head. ' from My Pink Half of the Drainpipe by Bonzo Dog Doo Dah Band.
dresda is offline   Reply With Quote
Old 05-29-2013, 04:00 PM   #77114
BergDonk
BergDonk's Avatar
Oddometer: 3,679
Clutch main shaft nut 50 nm
Clutch spring bolts 10 nm
Case cover bolts 6 nm
Foot peg bracket bolts 39 nm
Old 05-29-2013, 04:03 PM   #77115
BergDonk
BergDonk's Avatar
Oddometer: 3,679
W = V x A
so 4 amps @ 12 + v <> 50 W
Times are GMT -7.   It's 08:18 PM.
