Old 06-04-2013, 04:47 PM   #77311
Brutalguyracing
Oddometer: 985
help clutch issues
i have a 2002 dr650 with say 5k on it im the 3rd owner
i just got the bike recently
drives well the problem i am having is
the clutch engages at the very end of clutch lever release
meaning i can disengage the clutch in the first id say 1/2"-3/4" of pull on lever
any ideas on what to do
i have no clutch slippage at high speeds.....
any info would help
thanks
Brutalguyracing is offline   Reply With Quote
Old 06-04-2013, 05:28 PM   #77312
Skidmarkart
Dirty Middle Age Man
Skidmarkart's Avatar
Oddometer: 225
That Bimota is amazing. Trade you my sister for it.
Skidmarkart is offline   Reply With Quote
Old 06-04-2013, 05:35 PM   #77313
Brutalguyracing
Oddometer: 985
pics of said sister
Old 06-04-2013, 05:40 PM   #77314
planemanx15
planemanx15's Avatar
Oddometer: 1,009
Lowering links
Just bought a set of these. Really good price and a few different sizes for customization. I'll report back on the quality when I recieved them. Lowering my 790 2"... It seems like a lot, but with a 2x4 under my feet, I can get the ball of my feet on the ground. With another 1/2" I should be Even better. My only concern is bottoming out my suspension two up. I might have to turn up the preload on the rear spring. On the front, I'll just pull the forks up 1.5 inches.
http://burkhartcycle.com/store/index...roducts_id=162
Edit: if I knew at the time the vstrom 1000 seat is 1+ Taller than the 650, I wouldn't have to go though this trouble when I installed the seat.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 06-04-2013, 05:52 PM   #77315
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,272
any info would help
thanks
I dont know if the dr is designed same but I had the same problem on my vulcan. Ended up being a week clutch pack spring. I never felt it slip either.
Mongle is offline   Reply With Quote
Old 06-04-2013, 06:17 PM   #77316
Brutalguyracing
Oddometer: 985
good to know
thanks
Old 06-04-2013, 06:24 PM   #77317
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
good to know
thanks
I'd adjust the clutch...
NordieBoy is offline   Reply With Quote
Old 06-04-2013, 06:44 PM   #77318
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,272
Well, there is that.
I have a bad habit of thinking people do the easy stuff before asking questions. I dont always remember that some people dont know where to start.
Old 06-04-2013, 07:07 PM   #77319
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
That was going to be my 2 cents worth of suggestions
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 06-04-2013, 07:13 PM   #77320
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,899
Originally Posted by Albie View Post
All a moot point for me these days as I don't race anymore and I'm not the least bit interested in squeezing out the last ounce of power out of the bikes I have. Heck, even my Gixxer's bone stock and it'll stay that way till I dump it. Besides, the nearest tuner to where I live now is 210 miles away, and he uses one if those DJ dyno's.
Most any stock Gixxer will hit 160+mph,of course more for the bigguns.
I just dont need to do that on the street,but its nice to have it there in case something comes up where you need it,the handling must be inspiring.
Im picking up a used 1250 Bandit on Thursday,not a fast one but good solid bottom end grunt and supposed to be comfy enough.
Mainly want a reliable bike for burning up and down the CA coast and beyond.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 06-04-2013, 07:16 PM   #77321
Brutalguyracing
Oddometer: 985
any advise on what to do to adjust it?
would i be able to use the adjustment at the lever
Old 06-04-2013, 07:34 PM   #77322
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,269
Bent Riser
I have (well, had) a ROX 3-1/2" riser on my DR650. When I pulled everything apart last week to do some wiring work, I noticed the stupid thing was BENT. Or more accurately, curved. Apparently from the bike going down on the right side a few too many times, the thing actually bent. I'm amazed because of how thick the aluminum was.
So, I'm replacing it with a PowerMadd 3" model that shows up tomorrow. I have the same one on my KLX250S and that thing has survived countless dumps without any issues... dumps far worse than the DR has ever experienced.
Anybody want a really good deal on a bent ROX? :)
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 06-04-2013, 07:37 PM   #77323
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,941
Needs got nothing to do with it.
Hell, a Bandit will go well into the triple digits without even trying.
Old 06-04-2013, 08:46 PM   #77324
WhiskeyTangoM3
I WANT!
Oddometer: 10
Well fellas...I think it's safe to say you should have a new DR650 grunt joining the ranks in the near future.
After a while of searching, learning and have happily settled on choosing the DR as my first motorcycle.
WhiskeyTangoM3 is offline   Reply With Quote
Old 06-04-2013, 09:12 PM   #77325
Chill
Chill's Avatar
Oddometer: 332
It should be adjusted so that there's a few MM of play at the lever. So that the first few MM are just taking up the slack in the cable. It needs that slack so that when you turn the bars it's not pulling the cable. It sounds like yours is too tight so you'd need to wind the adjuster in. There's one at the lever and another along the cable with a locknut.
Manual says... loosen the locknut by the lever and wind the adjuster fully in. loosen the locknut on the cable and adjust so there is 10-15MM play at the lever end. Tighten all locknuts. Lubricate with motor oil.
Chill is offline   Reply With Quote
Times are GMT -7.   It's 02:47 PM.
