Old 06-18-2013, 10:04 PM   #77686
sander
sander's Avatar
Oddometer: 323
Originally Posted by MoBill View Post
I tried making that thing....it slips inside--I dunno--it won't stay put. I am prone to ham-fisting stuff when using a shortcut--so I ordered the SST.
On the rear shock--I'm at a lost to understand how you can take it off the top with that cylinder on the side---and I can't figure wtf to do to remove it from the bottom.
Do I just hold the top and unscrew the clevis?
I'm sorry--but I don't see what to unscrew except that.
Loosen those 2 serrated nuts left of the spring (1 and 2), first the left most one (1) and then the one that sits against the spring (2). That way you remove all the preload on the spring once the spring is loose all the stuff keeping it there (3) will just fall out.
sander is offline   Reply With Quote
Old 06-18-2013, 10:29 PM   #77687
ER70S-2
ER70S-2's Avatar
Oddometer: 6,713
205'd by Sander
Remember when the tool arrives, insert it in the top of the fork and secure it with a wrench/cross bar and then turn the allen screw on the outside bottom of the fork tube. Don't try to turn the tool you ordered, turn the wrench.
Again thanks to DisTech:
When I said you can remove "it" from the top or bottom, I meant the shock can be removed from the top of the bike or out the bottom of the bike.
Loosen the two collars with a hammer and punch, on the left end of the shock in your photo, as I described earlier (clean the threads so you don't gall them). Then unscrew them to the left, toward the cylinder on the side (oil reservoir), about 1-1/4". The first one will spin over easily, once the threads are clean. The second collar will have spring tension and you may have to use your hammer and punch for the first few turns. Once it's a little looser, you can grab the spring and collar with your hand and turn them both, which is faster than the hammer/punch.
Then slide the spring and rubber bump stop to the left and remove the alum spring seat on the right end sitting on the clevis (don't try to unscrew the clevis). The spring seat is cut so it can slide sideways off the shaft once the spring and bump stop are moved to the left (in your photo). With the spring seat off, the spring will slide off, to the right, over the clevis.
We're getting closer, keep asking questions and we'll get you through this project. Don't force anything, take a pic, ask a question; someone will be along inna minit.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 06-19-2013, 03:09 AM   #77688
duckslider
unintentionaldrifter
duckslider's Avatar
Oddometer: 3,299
Originally Posted by Tman00 View Post
Time for some new rubber. Need a good all around tire. Hated the stock tire-went the Kenda 270 route and want to try something else. Give me some ideas and how you liked the tires used.
hey Tman00,how many miles did ya get outta the kenda270?was it a rear?
Part of an Internet Forum ''Gang'' of Cyber Punks...........apparently.
2010 Deeaaaah 650(Black Pearl)
Wash it? It's a workhorse,not a bloody showpony.
duckslider is online now   Reply With Quote
Old 06-19-2013, 05:03 AM   #77689
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,377
you need these any way,
http://www.harborfreight.com/9-piece...7880-html.html
if you have a compressor:
http://www.harborfreight.com/1-2-hal...nch-95310.html
if not:
http://www.harborfreight.com/12-in-e...nch-68099.html
Then the thing will fly apart and you can use the tool for other jobs. And all for probably the same money as the Suz special tool.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 06-19-2013, 05:41 AM   #77690
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,736
Thanks fellas. Thanks much. I get it now--backing off the preload exposes the hardware I need to loosen to remove the clevis. "Clevis"...that's fun to say.
SST from MC superstore should be here today. I can't wait to move ahead.
3 circuit solution, powerlets, all here...it's all still in pieces, but it's ready to go back together as soon as the suspension is done.
Funny on the harbor freight stuff--I need to buy the impact--I'm set on hexes, but not to 30mm
MoBill is offline   Reply With Quote
Old 06-19-2013, 05:52 AM   #77691
Tman00
Oddometer: 29
Duckslider, I am running the 270's front and rear-put on at the same time. Right now I think I am at 3500 miles,but I will have to check tonight. The rear has some tread left but traction on the dirt is suffering badly. The front is starting to cup. They were pretty good new-no complaints. Just wnated to try something new.
Has anyone tried the Bridgestone Trailwing 302's? How about the TKC 80's?
Tman00 is offline   Reply With Quote
Old 06-19-2013, 06:04 AM   #77692
Tman00
Oddometer: 29
Originally Posted by Adv Grifter View Post
I agree. If you are on a budget the Shinko 244 is very hard to beat. Kenda 270 is similar. I'm running a 244 rear now and like it fine for street and moderate off road. Cheap and wears pretty well too.
Thanks Grifter..thats the kind of info I am wanting. Someone who has tried it and what they have found. And yes my budget is on the tight side right now.
Old 06-19-2013, 06:04 AM   #77693
8gv
Oddometer: 2,488
Fork work...
When I disassembled my KLR250 forks I used a Craftsman spark plug socket that has an external hex. I put it on upside down on a couple of long extensions.
The air tool I borrowed from autozone (for a car repair) didn't work out due to my wussy 5 gallon air compressor.
On the 250 there was a torque spec for tightening the rod. If there's a Suzuki spec, can this be accomplished with an air tool?
8gv is offline   Reply With Quote
Old 06-19-2013, 06:27 AM   #77694
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
why do you want to remove the "clevis" ? It does not need to come off the shaft to change the spring. after yo loosten the preload collars and slide the spring to the top of the shock you will see the bumper can slide up also and then the two bottom spring keepers can rotate and slide off the shaft to the side.
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 06-19-2013, 07:34 AM   #77695
MoBill
MoBill's Avatar
Oddometer: 13,736
sorry...I meant the hardware,.not really moving the clevis. I just like saying clevis. :boobs
Old 06-19-2013, 09:31 AM   #77696
BlueLghtning
Riding is my passion
BlueLghtning's Avatar
Oddometer: 5,264
Originally Posted by ER70S-2 View Post
Shinko: 705 (mostly street)
Shinko: 700 or 244. These two seem to do the same job, I'm unsure why they make both. I've been running the 5:10-17 244 and like it.
I don't ride mud or much sand, the rear tire is rarely an issue for me. Stolen quote: "Which rear tire?..........something round and black."
I've recently switched to a DOT knobby on the front and although they wear out pretty quick, I sure like 'em.
I've got the D700's on my DR650 and had the 244s' on my WR250R. I figured i'd be doing more street duty on the DR650 and thought the 700's would give me better life and better street performance with maybe a bit less dirt.
IMOP, the 700's & 244's are not even close. You would think they would be looking at them and that's what I thought, but I was totally wrong. The 700's suck off road compared to the 244's. In gravel they are not nearly as confidence inspiring and they are down right scary in the mud. They also let go with little to no warning. The 700's have a very 'soft' sidewall tire and therefore airing down makes the street ride horrible and really doesn't gain you much on the dirt so you end up leaving them aired up all the time. The 244's are a nice compromise between full on knobby's and still having decent street performance. You can run them at various pressures and they still handle very well.
I've also found the 700's are wearing very quickly on the road and probably not lasting near as long as the 244's even though I've played off road a lot more on the 244's. The 700's actually feel really good on the road, but that's about the only positive I can give them. Between the horrible off road performance and probably under 2500 miles on the rear, I'd either run the 244's if I wanted a 50/50 tire or the 705 if I wanted something a bit more street oriented.
I can't wait to get these crappy 700's off my DR650.
BlueLghtning - Follow me on my SPOT Messenger
Mine: KTM 650 ADV (Katuki), 09 DL650, 08 Husky TE610, 08 WR250R
Hers: 07 Ninja 650R, 13 CRF250L
Smugmug Pics - Save $5 <-- Click Here
BlueLghtning is offline   Reply With Quote
Old 06-19-2013, 09:48 AM   #77697
HackFlipper
HackFlipper's Avatar
Oddometer: 66
So some pages back I posed a question about luggage options for the DR. This was my problem.
So after buying the Promoto Billet saddle bag guards to go with my rack and trying many different bag placements I set off on a 600 mile ride. Got home with a melted right side cover and burnt bag. (I didn't set off with the bags looking like this by the way..) At least the bags were free to me! So for a solution I went this route.
Dirtracks.com racks and Nelson-Rigg adventure dry bags. I really wanted the Wolfman setup. I just couldn't get over the price. So for less then $200 bucks all in this is what I got. First impressions of the Racks is that they are pretty sturdy. The Nelson Riggs lack some of the features of the Wolfmans..ie quick removal from the racks etc. They do have a lifetime warranty though. They're spacious and seem tough. We will see after the next adventure.
Terry
2010 Triumph Scrambler
2008 Suzuki DR650
1975 Honda CT90
HackFlipper is offline   Reply With Quote
Old 06-19-2013, 09:56 AM   #77698
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,969
I don't think the torque spec, for the Allen bolt on the bottom of the DR fork, is that tight (that you would need an impact gun or an air wrench). IIRC, it's like 19 lbs/ft. When I did my forks, I used a 1" piece of square steel tubing held in a vice. The fork was just slightly less than horizontal to keep any old fork oil in the fork. I was able to hold the fork up, keep some pressure so that the 1" tube was not displaced and torque the Allen bolt. I was pretty surprised at how easy it was to dis-assemble and re-assemble both.
I saw your post and was afraid that's what was going to happen. My DR came with a set of side racks that I cannot identify (and a brand new set of the N-R bags that you have). I've decided to go with the Bike Nashbar brand of bicycle pannier bags on my "no name" side racks. Seems to work OK but I've never really done any extended trips with that set-up. It's a shame that the Pro Moto Billet side racks didn't do much to keep the bags off of the muffler or keep your side panel from getting melted. They sure are nice looking. Ah well, live and learn.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 screwed with this post 06-19-2013 at 10:03 AM
Bronco638 is offline   Reply With Quote
Old 06-19-2013, 09:56 AM   #77699
ER70S-2
ER70S-2's Avatar
Oddometer: 6,713
Thumb
BlueLghtning: Thanks for the detailed feedback. I know someone running them right now on a DR, I'll send him your information.
2013 WR250R
Old 06-19-2013, 10:45 AM   #77700
Ackme
talented fool
Ackme's Avatar
Oddometer: 527
That would be me. Thanks for the heads up ER70S-2
I just replaced them after about 4000 miles. I did not find them terrible on the street but not much better than the Bridgestones that came with the bike. In the dirt they seemed a bit better than the Trailwings but nothing to get excited about.
I figured that was just the trade off with any 50/50. For some reason I was feeling flush and spent a bit more for the replacments. I went with a TKC for the front - seems to have good rep for very good dirt manners and acceptable road ability - downside being relatively short life. We will see.
To be a little more economical I put a Michelin T63 on the rear - it is round and black, even if a bit more $$$ than the 244... alright 2X .
ack
"nothing is foolproof to a sufficiently talented fool"
Ackme is offline   Reply With Quote
Times are GMT -7.   It's 04:47 AM.
