Old 06-27-2013, 10:53 PM   #78046
andy from MO
andy from MO's Avatar
Oddometer: 26
Originally Posted by 805gregg View Post
Just find a used one, I got a '96 for $1900, with only 10,000 miles, I'm 5'11 with a short 30" inseam and my DR is just the right height,a Sargent seat will cure the seat problems
I bought (ok....stole from a friend deal) my 1996 about 4 years ago for $1300 with 1800 miles on it and it was bone stock. It's suspension was better than my new 2012 although I'm not complaining about my 2012. I sold it to another friend a few years later for $1800 with a custom seat and BBQ rack on it and it had about 8000 miles. I ended up buying a new one but buying used is a great way to go and I think $1900 for a 96 with 10k is a pretty good way to start out!
andy from MO is offline   Reply With Quote
Old 06-27-2013, 11:19 PM   #78047
Hesaid
Hesaid's Avatar
Oddometer: 1,375
Originally Posted by Thunderjet View Post
MSRP is $6,399 for a 2013. Suzuki is tossing in $400 in bonus cash. Apply the bonus cash to the $6,399 and offer the dealer $5,800 cash OTD not counting taxes.
What do you think? To much? To little?
In October 2012 I paid $11,000 for my DR, but it did come with some factory Suzuki extras.
MV
DR Feelgood , Tipsy Wombat, Pinkfoot, FatCat, and how they got their names: What the hell is a wombat? And now, the tales of their adventures.
Hesaid screwed with this post 06-28-2013 at 09:58 AM
Hesaid is offline   Reply With Quote
Old 06-27-2013, 11:28 PM   #78048
ericos
Oddometer: 48
Originally Posted by Adv Grifter View Post
That strategy has worked well for BMW riding friends. The standard BMW warranty is 3 years. They bought extended warranties, adding another 4 years. So many things have failed on those R1200GS's, that they've come out quite well money wise. (broken luggage, final drive, wheel, shock, ABS computer, CAN Bus. But it does not cover everything ... like warped rotors. They managed about 60K miles, then they got tired of the bikes. One bought a KTM990, the other a Triumph Explorer.
Plus, once on an after market warranty, they fight you on every single repair. PITA.
That strategy may be less likely to work on a Suzuki ... they just don't break as much. Still, a long warranty does give peace of mind.
I thought the warranty does not cover normal wear and tear?
ericos is offline   Reply With Quote
Old 06-27-2013, 11:47 PM   #78049
blackcap
blackcap's Avatar
Oddometer: 538
Originally Posted by Albie View Post
That "box" is the IGNITION. It's all ONE piece. So if you do want to take it apart, you pretty much have to BREAK it apart.
So if it is bad, which as most everyone else has pointed out is doubtful, you HAVE TO BUY ANOTHER IGNITION. There's no fixing it.
Here's what it looks like off the bike.
its not ONE piece. theres about a million pieces inside there. i had a problem with mine a couple of years back and it turned out to be dirty contacts inside this box. pull the two little rubber/plastic caps off that sit about halfway down the body and use the right torx bit (or cut a slot in the head of the torx bit and use a flathead screwdriver) to remove the fasteners. that box will fall apart in your hands and youll be bale to check the internal contacts at least. it can probably come apart more but i had no need so cleaned up the terminals and bolted it all back together, no more problems.
when you loose your bike keys in indonesia its possible to have the ignition barrel broken down so far that the guys will replace the internal pins and cut you a brand new key to suit it or cut you a new key to suit your old pins. we in the west have too much money to spend our time on things like this and just throw shit away thats only half broken
"One must die sometime and to die with ones boots on is very noble" - Carl Stearns Clancy, first RTW motorcycle, 1912-13
Australia to Iceland on a DR650 http://oztoice.wordpress.com
and facebook https://www.facebook.com/oztoice
blackcap is offline   Reply With Quote
Old 06-28-2013, 04:16 AM   #78050
Escaped
Escaped's Avatar
Oddometer: 488
What is your average highway cruising speed?
Even at the high cost, that sort of life makes it worth while ... especially on a long tour where you do NOT want to pack a tire or change mid way. But
God forbid you get a flat. If the Tourance is anything like a Avon Distanzia, breaking the bead is not easy. But maybe you can just ride it flat to Alaska?
Unfortunately most of my mileage is commuting. my daily speed ranges from 0 to 85 miles per hour indicated with a fair amount of daily miles "splitting" at around 20mph."
2006 DR650 54,407 miles
DR650 - Eyes open all of the time
Escaped is offline   Reply With Quote
Old 06-28-2013, 04:39 AM   #78051
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Good
Originally Posted by Escaped View Post
For long life and reasonable performance, I really like the Metzeler Tourance (130 / 80 on the rear) tires on the DR650. I think because they are designed for the big dual sports they give extra long like on the DR. Negatives are that they are expensive and very difficult to change in the "Field".
I hate to even mention it (because its hard to believe) but I have put over 14,000 miles on each of my last two sets.
43,000 miles now on my 2006 DR650
Holy bloody struth mate, that's bloody good.
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 06-28-2013, 06:07 AM   #78052
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Cool2 The Soft Luggage Thread
Can you post a LINK for your "Soft Luggage Thread" ? Good idea! ... but the fact is, within the 55,000 posts on this thread are hundreds of Soft Pannier options shown ... also hundreds of posts about various Racks available. Almost NONE are as expensive as the ones you've posted above. .... .....
The link to the Soft Luggage thread is here:
http://advrider.com/forums/showthread.php?t=885155
Sorry I took so long to reply. I'd love to see more inexpensive options than the table I posted a month ago. Indicating if they're waterproof or dustproof would be a bonus. My table were probably the most expensive options. They were all proof though (or 95% water proof)...one or 2 may have been slash proof as well, and supposedly didn't require racks, except where indicated. Still expensive I'm slowly starting to hear they are
Old 06-28-2013, 07:01 AM   #78053
Thunderjet
Oddometer: 31
Originally Posted by andy from MO View Post
Take advantage of the 0% for 5 years too if they're still offering it!
I gave $5149 out the door for my new 2012 on March 14th, 2013! ....0% for 5 years and nothing down equals about $85 /month. That's hard to beat in my opinion. I've already saved enough in gas to make the payments plus some!
Missouri is close enough for a ride. Who was your dealer and salesperson?
Thunderjet is offline   Reply With Quote
Old 06-28-2013, 07:03 AM   #78054
andy from MO
Oddometer: 26
Originally Posted by Hesaid View Post
In October 2012 I paid $11,000 for my DR, but it did come with some factory Suziki extras.
MV
How about some info on those "factory Suziki extras"....
Old 06-28-2013, 07:11 AM   #78055
andy from MO
Oddometer: 26
Drinnan's Cycle
West Plains, MO
417-257-7771
Joe and Betty are the owners and that's who usually answers the phone. I don't think they have any more 2012's though....let me know if I can help!
Old 06-28-2013, 07:16 AM   #78056
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,709
I'm believing it.
I'm at over 6000 miles with my Shinko 705's, and the rear seems like it has another 2000 in it (unless off-road traction was a concern).
Not sure about you, but I run my tires at higher pressures than DR650 specs state I should... it just feels better for road use. But it also seems that it is aiding in longer road life out of tires that some claim only get them to 6000 miles (for the rears).
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 06-28-2013, 07:19 AM   #78057
Hesaid
Hesaid's Avatar
Oddometer: 1,375
Well, there was a little of this and a little of that, and I think some gloves, but mainly it was the full size spare.
MV
Old 06-28-2013, 07:26 AM   #78058
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,734
Originally Posted by Mambo Dave View Post
I'm believing it.
Good lord! I used to be lucky to get 2500 miles out of a rear Tourance on both my Strom and GS. I feel giddy that I can actually get 2500 out of a Shinko 244 on my DR. ONLY 6000?
Old 06-28-2013, 07:33 AM   #78059
Thunderjet
Oddometer: 31
Drinnan's Cycle
West Plains, MO
417-257-7771
Thanks, I sent them an email.
Old 06-28-2013, 07:44 AM   #78060
andy from MO
Oddometer: 26
Well...."full size spare".
MV
I see now....I'm thinking along those same lines right now! Good for you!.....uh and someone else!
Times are GMT -7.   It's 06:34 AM.
