Old 06-28-2013, 08:05 AM   #78061
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,554
Originally Posted by ericos View Post
I thought the warranty does not cover normal wear and tear?
You are correct. Suzukis extended warranty (SEP) is worthless. They can, and will, call most anything wear and tear on a bike that's been used.
Beaten paths are for beaten men.
lamotovita is online now   Reply With Quote
Old 06-28-2013, 08:16 AM   #78062
Tex76
Motersykle Advntyers
Tex76's Avatar
Oddometer: 870
Originally Posted by Hesaid View Post
Well, there was a little of this and a little of that, and I think some gloves, but mainly it was the full size "replacement DR650".
MV
There, I fixt it
"We act as though comfort and luxury are the chief requirements of life, when all that we need to make us happy is something to be enthusiastic about."
2007 BMW R1200 GSA, 2009 DL1000, 2005 DR650
30:Unemployed and Homeless (2 months and 10,000 miles)
The Lost Texan, Wanders East
Tex76 is online now   Reply With Quote
Old 06-28-2013, 08:39 AM   #78063
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,643
Originally Posted by Albie View Post
Good lord! I used to be lucky to get 2500 miles out of a rear Tourance on both my Strom and GS. I feel giddy that I can actually get 2500 out of a Shinko 244 on my DR. ONLY 6000?
Again, though, the DR650 is lighter and I'm running higher pressures - both of which keeps the rear tires cooler, overall, and it's that heat that makes a tire wear faster than most other things. Also, the times I've run the bike "loaded" were only a few... I work too much.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is online now   Reply With Quote
Old 06-28-2013, 09:28 AM   #78064
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
In October 2012 I paid $11,000 for my DR, but it did come with some factory Suziki extras.
MV
11,000............That buys 2 new DR's I would think.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 06-28-2013, 09:56 AM   #78065
trainman
trainman's Avatar
Oddometer: 397
I think it's too much. http://dallas.craigslist.org/ndf/mcd/3862111934.html
John
trainman is offline   Reply With Quote
Old 06-28-2013, 11:55 AM   #78066
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Correct, no warranty covers normal wear items: Clutch, brake pads/rotors, chain/sprockets et al.
But the stuff I listed in my earlier post regards the BMW are not wear items and are covered. Even warped rotors can be covered depending on your dealer if he goes to bat for you. Clutch also is questionable. Not covered on older, high mileage bike most likely, but if a year old bike lost the clutch, you may be covered. So much depends on your dealer and how good he is with dealing with the OEM warranty Rep.
On the DR650 a blown 3rd gear that destroys the entire engine is not a wear item! (Duh!). Not much else seems to fail on DR's. Seems most of the problems we hear about lately are due to machines SITTING, unused for long periods. Old fuel, water, exposure, none are good for bikes. Bikes like to be ridden ... at least once every two weeks.
Old 06-28-2013, 11:59 AM   #78067
Adv Grifter
Oddometer: 6,128
Originally Posted by blackcap View Post
when you loose your bike keys in indonesia its possible to have the ignition barrel broken down so far that the guys will replace the internal pins and cut you a brand new key to suit it or cut you a new key to suit your old pins. we in the west have too much money to spend our time on things like this and just throw shit away thats only half broken
Boy, ain't that the truth. And as a result very few riders can do much beyond and oil change. Remember "Shop Classes" in Jr. High School? No more.
Old 06-28-2013, 12:08 PM   #78068
MADurstewitz
MADMark
Oddometer: 159
Originally Posted by GSF1200S View Post
Alright, I have ridden from Florida to Alaska and all over here and the Dr has been great to me so far (yes grifter, that means 3rd hasn't blown yet). When I'm back in Florida, I'm considering the 3rd gear swap as I believe that will pretty much eliminate the potential of catastrophe. I could be wrong..
So, since I'm going to tear the motor down, I have some questions for the group. If there is anything I don't like about the Dr, its that it doesn't have enough power on highway. I get it isn't a KTM or beemer, but I have been giving the 790 kit a look. I'm going to be going to south america and I need a reliable setup, so is there any consensus on the 790 effect on durability? I know power isn't free, but I figured I'd ask.
I'm also considering leaving the bore alone and going with an oversized head (pro cycle) and camshaft. I know the power gains are not as much, but I would suspect with larger valves the head should last as long or longer than the stocker and give me a little power in the process.
Fwiw, I have put about 13500 miles on the bike since I left and the valves haven't moved from where I set them. Also, is there some page with all the tricks to making a rear tire last? I will have destroyed a K60 in about 2500 miles, and everything else short of a road tire would be worse. I am very impulsive and turn down dirt trails off main roads frequently, so a road tire is no go. I know of the mefo explorer which I might try, but all the dual sport tires I ruin too quickly. I'm willing to compromise with wet both on street and in dirt so hard compound is no issue.
Do the 790. Use the motoman break in. You won't regret it. Get highway sprockets as well (16/42) I'm on interstates every day during my commute. Plenty of go. Cruises nicely.
MAD
(yes, those are my real initials)
MADurstewitz is offline   Reply With Quote
Old 06-28-2013, 12:18 PM   #78069
ER70S-2
ER70S-2's Avatar
Oddometer: 6,708
How many miles do you have on your 790 now?
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 06-28-2013, 12:24 PM   #78070
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,619
2012 Dr 650
Some might remember I posted a couple of weeks ago on info on the Dr.
Well just got back from a trip from WV. had a blast
Went back to the dealer today still had the 2012 model 0 miles got them down to $5800 out the door.
I think they just want to dance a little.
So I will check back in a week or so.
So what do you think good price or what should I shoot for?
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 06-28-2013, 12:27 PM   #78071
Adv Grifter
Oddometer: 6,128
Originally Posted by RideAlongAtlas1 View Post
The link to the Soft Luggage thread is here:
http://advrider.com/forums/showthread.php?t=885155
Sorry I took so long to reply. I'd love to see more inexpensive options than the table I posted a month ago. Indicating if they're waterproof or dustproof would be a bonus. My table were probably the most expensive options. They were all proof though (or 95% water proof)...one or 2 may have been slash proof as well, and supposedly didn't require racks, except where indicated. Still expensive I'm slowly starting to hear they are
That is a good Soft Luggage thread! Nice! I like the look of the Ortlieb and Wolfman ... but BOTH are quite expensive, IMO.
I've used several luggage options on my DR since 2006 and 50,000 miles.
Started off with Hard bags. (GIVI bags). Too heavy.
I've never spent a lot on soft luggage and found most items here on Flea Market or on Craig's List. Most use Rain Covers, are not 100% water proof and some not dust proof either. But cheap and expendable.
Here are a few I've used:
Happy Trails rack, used under $100 for the set. Works for just about any soft luggage. Keeps bags in nice and close, yet away from pipe. I've burnt up many bags over the years. Not with this set up.
Big Teknic bags ... found on sale several years ago ... $60 (big but not well made ... only used on two rides. Hold a TON. Too Wide, IMO.
This is not my bike ... but I use the same Nelson-Rigg bags. This is where I got the idea for them. Cheap and cheerful too!
Tourmaster Cortech bags, $75 used on Craig's list. This set destroyed in Baja mounted on my XR250R. I found another set. Not waterproof but have covers. They leak dust badly. I wouldn't pick these for Round the World but fine for shorter trips, and they are a nice size, IMO.
My Nelson-Rigg bags, found on Flea Market for $100, like new condition! Uses rain covers, very good zippers, dust proof, BIG and very well made. Lots of options for mounting them. A true RTW pannier.
I use a big duffel for a top bag when camping. A smaller one when not camping.
Adv Grifter screwed with this post 06-28-2013 at 12:34 PM
Old 06-28-2013, 02:06 PM   #78072
Thunderjet
Oddometer: 31
Originally Posted by trainman View Post
Contacted the dealership. Seems the $5399 was before "fee's" were tacked on. Best answer I could get on the fees was "several hundred dollars"
Typical bait and switch.
Thunderjet is offline   Reply With Quote
Old 06-28-2013, 05:08 PM   #78073
Thunderjet
Oddometer: 31
Scored! Dealer close to me agreed to $5,700 OTD for a 2013. Will pick it up next weekend. A little sooner than I wanted one but have to take whats given to you when offered. Still have to pay CO taxes which are nuts but that's life.
Old 06-28-2013, 06:29 PM   #78074
Foot dragger
singletracker
Oddometer: 12,856
The add doesnt say out the door for the price. Are dealer fees a new thing in your area?
Old 06-28-2013, 06:34 PM   #78075
Thunderjet
Oddometer: 31
No, dealer fee's are not "new" in my area. But that dealer was in Texas, I live in Colorado. Some dealers hide the fee's then advertise a low price to get you in the shop then they spring them on you. Simple 101 motorcycle buying.
That's why, at least to me, the only price that matters is the Out The Door price.
Times are GMT -7.   It's 07:27 AM.
