Old 07-01-2013, 05:11 AM   #78136
FlowBee
Just me.
FlowBee's Avatar
Oddometer: 5,754
Originally Posted by phreakingeek View Post
I On my new bike I went with a Pat Walsh Designs skid plate that mounts to the factory rear mounts and uses rubber dampers.
+1. PWD plate is thick, wide and goes all the way back to the swingarm bearings junction. Price is similar to others.
"And then this one time at banned camp ....."
FlowBee is offline   Reply With Quote
Old 07-01-2013, 06:59 AM   #78137
805gregg
Just Stroming along
Oddometer: 1,561
Originally Posted by acesandeights View Post
Some say the Procycle one doesn't go far enough back.
And if you hit too hard the rear clamp bolts can puncture your cases, I just extended mine with a 7"x6 3/4" piece of aluminum that is welded to the skid plate in front and attaches to the rear Suzuki mounts. So it now covers the whole engine and eliminates the rear clamp bolt puncture problem
805gregg is offline   Reply With Quote
Old 07-01-2013, 08:42 AM   #78138
sandwash
sandwash's Avatar
Oddometer: 1,357
Or you can do what I did,just take that one clamp off.One of these days I will remove the plate and have a piece welding to it and use the back mounting holes.
97dr650
sandwash is offline   Reply With Quote
Old 07-01-2013, 09:34 AM   #78139
ER70S-2
ER70S-2's Avatar
Oddometer: 6,462
Originally Posted by Thumper Dan View Post
I was starting to get withdrawals
Originally Posted by Krusty ... View Post
ER70S-2 is probably passed out at his keyboard, his finger reflexively tapping the refresh button...
Last night:
This morning:
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 07-01-2013, 09:51 AM   #78140
PPCLI-Jim
PPCLI-Jim's Avatar
Oddometer: 221
i noticed that might be a possibility so i made my plate out of 1/4" check plate wide and put the mounting clamps on the outside of the frame. i also ground the shark fin in front of the drain plug way down sao that if i REALLY hit something HARD there isnt that issue
I'm not saying to kill all the stupid people . .. Just remove the warning labels and let nature run it's course
http://www.youtube.com/user/spudhead/videos?view=0 my youtube channel
PPCLI-Jim is offline   Reply With Quote
Old 07-01-2013, 09:54 AM   #78141
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,856
I had one that used the clamps to attach to the frame and they knocked a hole in the engine when I had a hard hit. As someone who's had a plate fail and ended up with a totaled bike, I'd say it's worth the extra to get the best you can afford. On my new bike I went with a Pat Walsh Designs skid plate that mounts to the factory rear mounts and uses rubber dampers.
I went the extra step and had the plate upgraded with welded armor and 1/2 inch rubber dampers on the entire frame tubes, but for most riders, the stock Pat Walsh plate is plenty of protection.
The best answer to this is to watch what your running into and dont blindly slam a 400 lb bike into something it doesnt have the clearance for.
Look way ahead,dont hit stuff that will smash the skidplate and bike.
DR's are very close to the ground,they can hit bottom on trail objects hard enough to launch a rider right over the bars that my 200 KTM wouldnt notice a bit.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 07-01-2013, 10:16 AM   #78142
clocklaw
clocklaw's Avatar
Oddometer: 1,989
Well, as of yesterday, I no longer have a DR650.......time for a change....y'all have fun!
2005 FJR1300 - "my Blue Angel" 2005 FZ1 - "Shazaam"
My Twins are Twins!
1992 TDM850 - "Ginger" & 1993 TDM850 - "Raven"
clocklaw is offline   Reply With Quote
Old 07-01-2013, 10:24 AM   #78143
begrateful
Oddometer: 50
New to the DR650 club.... Project 2K
I just wanted to express my Thanks for all the great information that is shared on this website...
I had the the very fortunate opportunity to purchase a 2007 DR650 w/4800 miles right before Christmas for $800. Since it came with some extras I sold off what I did not want and had a net of $685. in it. I was also fortunate enough to log onto Ebay looking for a couple of small parts and found a seller who was parting out a bike that had not been listed yet. It had Front/rear RAce Tech suspension, skid plate, Pro-Taper bars with mounts, F40 muffler with mid pipe and the header with the expansion pipe, rear fender with smaller light, FCR carb, Fork Brace and K& N air Filter.
Some more looking around on a DR website and I found a great rear rack, Buell dual headlight and some other goodies... All told I have $2100. in a superb 2007 DR with a lot of stock parts to sell off....
begrateful is offline   Reply With Quote
Old 07-01-2013, 10:34 AM   #78144
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I'm not sure which plate I have ... I think it's the Moose or a copy?
It's pretty solid but is too short and uses brackets to attach to lower frame rails.
I wrapped my frame rails with rubber inner tube. I bought longer bolts and added rubber washers btwn brackets & frame. Also glued down some rubber stripes to quiet it down a bit. I've taken a few hits in Death Valley and Baja .. so far so good! But NO IDEA if it would handle a really huge HIT or not. I try to avoid such things when possible. I don't ride aggressive off road and avoid super knarly trails.
Old 07-01-2013, 10:55 AM   #78145
refokus
Just Learning
refokus's Avatar
Oddometer: 2,456
I try to avoid the Hughes hits as well. The key word "try".....
Grifter, what is that you are using for the side stand on the right side of your bike?
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 07-01-2013, 11:24 AM   #78146
Adv Grifter
Oddometer: 6,128
That's one leg from a broken Tri Pod. It's super light Alu, but the twist lock outs don't work for holding bike up ... so has to be used like you see it in the pic. I used to take it with me, but no more. But sometimes it can be nice to have a prop stand to repair a flat or do maintenance. The leg shown weighs less than a pound! It's just wedged funky style in there, not that secure. Pic is 4 years old. Bike's changed a lot since then.
Old 07-01-2013, 11:38 AM   #78147
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,185
Anybody have a CDI?
Thanks to help from Jeff @ ProCycle, I've diagnosed my CDI as being bad. So I need a replacement. Does anybody have one sitting around they'd let go of at a reasonable price? Best I've found so far is about $300 for a used one on eBay (with shipping), or about $200 for a new aftermarket one from Belgium.
I'm riding some of the OBDR (Oregon Backcountry Discovery Route) this week over 4th of July and was going to take the DR650, but since it's down, I'm doing it on my KLX250S. BTW if anybody wants to join us (it's me and one other guy going; he's on an XR650), DM me ASAP, as we're leaving on Wednesday and returning Sunday.
Rob
'12 Suzuki V-Strom DL650
'96 Suzuki DR650
'92 Yamaha TW200
Rob.G is offline   Reply With Quote
Old 07-01-2013, 12:09 PM   #78148
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,610
Rob
Hi Rob,
Which route or sections? i rode the OBCDR Crown Jewels in combination with the WBDR last fall on my DR.
Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 07-01-2013, 12:16 PM   #78149
jna
Oddometer: 72
Clunking sound
We did a ride from Fruita Co to Gateway Co this weekend via Glade Park and Sheep Creek this past Staurday. After riding a difficult 30 mile section of loose rock, steep climbs, and decents I stopped to take a picture and when i restarted the engine it made an audible clunk that sounded similiar to a rock hitting the bash plate. I shut it off and restared it again and the same thing happened. I know the bike was hot because we had been doing very slow technical riding in 90 plus temps at over 7500 ft. Once we reached the valley floor we were at 4500 ft. Let the bikes sit in shade for almost an hour while we had a beer, and did not hear the noise when starting up. I have heard a clunk before when shutting off the bike but that noise is more like a small wrench hitting the bash plate. Does anyone else ever hear anything like this on start up or shut down? Bike is 2009 with about 9000 miles trail was borderline brutal in places.
jna is offline   Reply With Quote
Old 07-01-2013, 12:18 PM   #78150
Rob.G
Mostly Harmless
Rob.G's Avatar
Oddometer: 2,185
We're riding Route 4 to the east from Prineville, then picking up Route 5 and turning north and going as far as we care to go given weather, stamina, etc. Then slab it back on the twistiest roads possible. Due to the high heat this week, we're going to trailer to Redmond or Prineville and find a place to park it for a few days while we do the trip.
Also, thanks to this awesome group of people, I already found a replacement CDI at a good price!!
Rob
'96 Suzuki DR650
'92 Yamaha TW200
Times are GMT -7.   It's 02:34 AM.
