Old 07-03-2013, 11:00 AM   #78226
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by procycle View Post
I have no direct experience with the FCR but from reading the forums they don't seem to be able to return top notch fuel economy. More people report 40-45 mpg but rarely close to 50. I believe this is due to the available needles being a little richer in the mid-range than would be optimum for the DR. It's just a lucky accident that the TM40 works so well on the DR. There are only 3 needles available and they are identical except for the base diameter.
Originally Posted by Phreaky Phil View Post
The FCR can be tuned for better economy. I have got as good as 50mpg ( there is still room for improvement ) and have run on the TAT from sea level to 13000ft without changes. It was running richer up there, but no stumbling or surging.
Like many DR guys here, I followed MX Rob's long R & D with his FCR profect. Rob worked tirelessly to improve the fit and performance of the FCR onto the DR650.
For the longest time converts had high fuel consumption. After a couple years progress happened (I'd stopped following it at that point) and apparently some were getting much better MPG. That is apparently the status today.
For the FCR, I guess there are lots of needle choices. That and setting up the AP, squirt duration, squirt angle, leak jet ... and on and on ... all play a part.
Rob also went through various iterations of manifold adapters to allow the FCR to fit well on the DR. Took at least a year of trail/error to sort that out. Then came Needles. He must have tried at least a half dozen different ones. Meanwhile he was helping guys, really putting in a lot of his own time.
After a couple years of following along, I abandon the FCR idea even though I know the FCR well enough, and have a good running one on my little WR250F. The FCR on my Yam is very sensitive to altitude. I can't imagine what I'd do if it were on my DR650.
I just did not want to have to Fiddle around with all the various tuning elements on that Carb. Also, things wear out on it just like the BST. (AP pump and such).
I applaud those who've been successful with this conversion. It does appear the Mikuni Pumper is a more Plug and Play solution. For now I'll struggle along with my stock BST.
Old 07-03-2013, 11:01 AM   #78227
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,350
Originally Posted by Kommando View Post
Space the seatpan brackets down with washers and use Goop to glue some rubber washers to the seatpan bumpers.
Cut a small relief in the seat pan. The upgrade battery I put in my KTM was a bit taller too. I took a spade bit and drilled 1" holes in a couple spots to allow it to work.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 07-03-2013, 11:01 AM   #78228
DAKEZ
DAKEZ's Avatar
Oddometer: 19,739
Fuel economy? REALLY?
You do know that motorcycle riding is supposed to be FUN!!! (right?)
To hell with MPG! FPG is what you should be looking for.
F = Fun.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 07-03-2013, 11:02 AM   #78229
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,854
Originally Posted by Mongle View Post
I sure have... My stock tune sucked at sea level...got good between 5K and 9K...little worse above 9K. At 13K it was a gutless pig blowing black smoke!
How can one stock bike be so different from another? CA bike has different jets? Mine will wheelie in 1st and 2nd with stock carb and jets,I put a 14 countershaft sprocket on it and it goes fine. I live at 100' elevation and have ridden it to at least 11,000' with no problems at all.
Yet yours has a real narrow window where it will run right.
Odder then odd. I have never even adjusted the fuel screw on mine.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 07-03-2013, 11:06 AM   #78230
Foot dragger
singletracker
Oddometer: 12,854
Originally Posted by Rusty Rocket View Post
Foot: have you adjusted the mixture screw?
I will probably be able to answer this carb question in a day or so. I'm picking up a totally stock (carb with the mix scew untouched,stock airbox w/ snorkel intact and stock exhaust) 2009 in a couple hours. I will compare it side by side with my cut airbox,K&N filtered, DJ kitted, drilled slide carb'd, stock piped 1996. I will decide at that time whether to go after the carb on my new (new to me) DR.
Totally seat of the pants, but I can wheely in 3 gears with the throttle alone 14/42 spkts. I'll let you know.
BTW: I live at approx 200 ft above sea level.
I havent taken the plug out over the fuel screw,seems ok so I dont mess with it.
The plug color on mine is tan not white so they must have jetted it better at the factory.
Old 07-03-2013, 11:08 AM   #78231
procycle
procycle's Avatar
Oddometer: 2,367
Originally Posted by motolab View Post
You have neglected one key factor, and that is that in a CV carb it is the throttle blade rather than the slide that ultimately limits the air flow for a given throttle opening
And that somehow changes the air fuel ratio as it goes up in elevation? Please explain how that works.
To compensate the mixture for lower air density you would have to have some additinal air get past the slide without picking up additional fuel.
The idea of "for a given throttle opening" is useful for tuning but a much better way to think about what is happening during actual riding would be to say "for a given horsepower requirement" or "to maintain a given speed". If you rethink the idea using that frame of reference you will see that the idea that CV carbs compensate for altitude in some beneficial way is false.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle screwed with this post 07-03-2013 at 11:34 AM
procycle is offline   Reply With Quote
Old 07-03-2013, 11:10 AM   #78232
procycle
procycle's Avatar
Oddometer: 2,367
Maybe it's worn just enough to work properly
Old 07-03-2013, 11:12 AM   #78233
Foot dragger
singletracker
Oddometer: 12,854
Ride interstate at altitude, 2up, and you may want for some more power. This can be achieved inexpensively by opening up the flow of air and appropriately adding fuel.
Interstate at altitude 2-up on a DR.........Why would you do such a thing?
Im already sitting in the passenger area on mine going down the hiway and Im just 6' tall.
Cant be real comfortable with 2.
But Yeah Id always enjoy more power,Im just not willing to spend the money and time to fool with the thing,and it pulls my 180lbs around pretty dang well hiway or dirt.
Old 07-03-2013, 11:15 AM   #78234
Foot dragger
singletracker
Oddometer: 12,854
I try not to think about it,if I want to ride something faster I drag out the 1250 Bandit or 530 EXCR.
The DR is always ready to go and always gets me home,had some great trips on it.
Old 07-03-2013, 11:21 AM   #78235
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,681
F = Fun.
Unless of course you actually plan to adventure ride past Starbucks.....
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 07-03-2013, 11:33 AM   #78236
motolab
motolab's Avatar
Oddometer: 2,709
If the slide is open a certain amount for a given combination of throttle angle, rpm and altitude, the slide will be open less for the same combination of throttle angle and rpm at a higher altitude. If the rider now opens the throttle, i.e. there is a new combination of throttle angle and rpm at the higher altitude, the slide height would now be greater if he were to be able to instantaneously return to the lower altitude. If I understand correctly, you say this doesn't matter because the slide and needle rise and fall simultaneously. However it is the throttle angle the ultimately controls air flow, and not the slide. Therefore the needle will be lower in the emulsion tube for a given combination of throttle angle and rpm as the air density decreases.
Regards,
Derek
motolab is online now   Reply With Quote
Old 07-03-2013, 11:37 AM   #78237
motolab
motolab's Avatar
Oddometer: 2,709
It's the other way around, less fuel will be picked up for a given intersection of throttle angle and rpm.
Regards,
Derek
Old 07-03-2013, 11:59 AM   #78238
Rusty Rocket
Life behind "Bars"
Oddometer: 9,350
I received my '96 already modded so I have no idea how a stock one runs. I'm defiantly giving stock a chance before any carb/airbox mods.
2009 DR650
Old 07-03-2013, 12:01 PM   #78239
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,029
I later on did a carb kit and such since I mostly ride from 800- 5500ft. One reason my bike may be so different is that when I went to do the carb kit I found the idle mixture screw was all the way in! The guy on the assembly line must have been napping when my bike went across. I bought the bike new and had to take the plug out so I know there wasn't anyone messing with it before hand.
When I did all those elevations I had my 220lbs and another 70 lbs of gear so I was really working the bike hard...made it more noticeable.
Edit: on the plug color deal...I have found with newer-cleaner gasoline plug color is harder to determine fuel mixture. Having the dyno we pull plugs and look at them more for laughs than anything. With today's gasoline you can have a fuel mixture anywhere between 12:1 and 14:1 and it all looks the same. Also, plug color only matters where you shut the engine off. If you let the bike idle and then check plug color you are only seeing idle mixture.
Mongle is online now   Reply With Quote
Old 07-03-2013, 12:01 PM   #78240
Foot dragger
singletracker
Oddometer: 12,854
Regards,
Derek
This is what I have read about the CV carb,it was built to compensate for altitude and seems to do so.
A normal carb is a carb,pull cable the slide goes up.
Bigger thumpers are able to change altitude easier with out re-jetting then the little pea shooters though.
Times are GMT -7.   It's 12:56 PM.
