Old 07-03-2013, 07:43 PM   #78271
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by FlowBee View Post
FlowBee on the soapbox here. Please indulge me for a minute. I've just got to give say how much I appreciate how easy it is to adjust the valves on the DR. I'm fortunate enough to have multiple bikes (3), and I do all the wrenching myself. All of the bikes got their annual full PM this week, and all use screw/ locknuts for valve adjustment.
The last done was the BMW RT. The difference: the half hour it takes to remove all of the tupperware and the half hour it takes to replace it all on the BMW! "But the heads are exposed" you say. Yes, but you need to do a throttle body sync afterwards and THAT entails all the tupperware be removed. WTF BMW?? All those little Torx screws all over the place. Be sure to keep track of which ones go where ...! Be sure you have the special tool to pull the spark plug igniters. Be sure you have lots of room to lay out all that tupperware.
The DR took 30 minutes total, and that included pulling the side covers, seat, and tank. All of the clearances were still within specs after 5000 miles since the last check. Hint: be sure to empty a Safari tank before pulling it. It weighs 65 lbs full ! OOF!! Thanks Suzuki! I love how easy this bike is to service.
The only bike easier was the Guzzi, and that goes without saying. No bodywork to remove and you can adjust the valves while seated. With a cup of coffee by your side.
I can't imagine having to pull multiple cams and buckets to then drive down to the dealer to buy a bunch of shims (if they stock them) while the bike sits in pieces. GAAH!!!
Thanks for indulging me. Now back to our regular DR talk ....
FB
Good post, feel your pain regards BMW body work. I've found that once you've done it two or three times it goes quicker. I write down the order of
for Dis ... and RE assembly. Save time.
Shims aren't bad either once you've get down the routine. I'm not a professional mechanic but I do learn from doing a few times. The trick is to already have shims at hand BEFORE YOU BEGIN. Also, often just swapping around shims you have will work. Getting the routine and order of work is the same as the bodywork. Takes some doing to pull valve covers and cams but once your into it ... not so bad. I did a few of my Ninjas, VFR Honda, Vstrom and my 1050 Tiger. The Honda was BY FAR the hardest and had to have a friend for help and advice. Turns out they needed NO Adjustment!
The DR is child's play and can be done at the side of the road if need be. I actually did this once for a friend who got it wrong and set valves 360 degrees out. We had to do it HOT ... just winging it. Checked them again in Motel that night ... I was spot on!
When hot I just set barely lose. When cold, all good.
Old 07-03-2013, 08:27 PM   #78272
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Originally Posted by 955616846 View Post
So you'll throw away more money on towing it instead...
For tax purposes I record every cent that goes into vehicles and know exactly what they cost to own and run. My company's Toyota Landcruisers cost 2.5x as much to run (cents/km) over their entire lives than my R1200GS (which are surprisingly cheap on the long haul) despite the hideous cost of keeping tyres on the bike.
My time wasted to change tires is worth a hell of a lot more.
Old 07-03-2013, 09:04 PM   #78273
Adv Grifter
Oddometer: 6,128
Originally Posted by AKASY View Post
Sure it does
Let's see 2 up on the interstate or 60mpg which matters to me?
Wow! fantastic Video. Knarly stuff ... I don't think me and my DR are going up there! Good going man! You guys make it look easy.
I've really got to buy a GoPro!
Old 07-03-2013, 09:40 PM   #78274
Adv Grifter
Oddometer: 6,128
If you live out in the great western states and your great rides are less than an hour away count your blessings. You are indeed fortunate.
Come on out for a visit ...
20 minutes from my door via twisty roads and Redwoods gets you here. You may not know it .. but you've all seen this road in hundreds of TV commercials. Mostly shot from chopper.
10 minutes south ... Highway one, Sunday Morning Ride route. Not for the feint of heart!
Old 07-03-2013, 10:13 PM   #78275
rockydrxrvr
Multi Meter Meathead
Oddometer: 163
I answered my own question
Originally Posted by rockydrxrvr View Post
My standard shoria battery is 3.5 inches tall, the upgrade in 4.13 inches tall, I cut a block of wood the dimensions of the 'upgrade' before it is shipped, to see if it would fit, only a 1/16th inch clearance, so with connectors tightened down, the bottom of the seat will 'chafe' on the connections.----- looks like a probable no=go. Any DR owners figure a way around this besides a custom remote battery box like the XRL650'S have?
I have a few elec. accessories to add on.
With the wood block test,-- sized to the larger upgrade Shorai, and the fact you must stretch and force the stock main cables upward, I would say this is a cold winters project to make an aluminum box and mount it elsewhere on the DR. Just use the 210 cranking amp regular Shoria, and keep an eye on it if you store you bike.
Anybody make a remote battery box for the DR?
stock number LFX14L2-BS12>>>>>GOOD PEOPLE TO WORK WITH<<<<<<
rockydrxrvr screwed with this post 07-04-2013 at 03:49 PM
rockydrxrvr is offline   Reply With Quote
Old 07-03-2013, 10:38 PM   #78276
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
I'm one of those people. There is a reason the 'coasters call the midwest / plains the "flyover states". Some of us have to live here to generate an income that isn't subject to a bubble. While I love riding in SE Ohio, it's still 2 hours away - and that's as good as it gets in Ohio. That's why I love the DR. It allows me to get to far away places on the slab at slab speeds within a reasonable amount of time, yet still have a chance of enjoying the scenery while I'm "out west". Yes, I have a trailer, but I hate using it for anything other than retrieving a bike or helping out a friend. The DR can handle 700 mile days on the slab if necessary. I've done it in a pinch.
I was talking about people who toured out west. Their tour plan map had them going down interstates while in the mountains ie seeing Colorado from I-70 only. I've seen it enough to take notice it's common.
It's the screwed up US bigger is better mentality. They have 2 weeks and dammit they are going to visit all the western states. 2 weeks is barely enough for Colorado alone.
Not really sure you are talking about as far as why you live where you do? A bubble? As in everyone in the mountain states are just flipping houses or something??? That's just shallow-minded. People work hard everywhere they live. Some were born and raised in incredible place, but most chose to live where they do. It took sacrifices and effort like anything want in life. It's not fortune or luck that makes it happen, but determination and action. Many give up and stay where they are because that's all they know.
Alaska
Butler Maps website:
http://www.butlermaps.com
eakins screwed with this post 07-03-2013 at 10:48 PM
Old 07-03-2013, 10:40 PM   #78277
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,566
I must be especially slow. I've been touring Colorado for 6 years and found new places as recently as this morning.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 07-03-2013, 10:46 PM   #78278
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,270
I find new places all the time.
Alaska
Old 07-04-2013, 03:42 AM   #78279
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Riding around Perth, Western Australia
A Dr650 Youtube video is here:
http://youtu.be/djShf90lwSI
[IMG][/IMG]
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 07-04-2013, 05:02 AM   #78280
AKASY
Noob
Oddometer: 2,172
Vids
Me and my DR aren't going up there either At that time I was without a DR.
That was my KTM--just wanted to show why riding out West is such good riding. I'll take the DR into some rough stuff but not on a narrow snow covered ledge with a 200 foot drop off on the side
Don't make the mistake of believing everything you think.
AKASY is offline   Reply With Quote
Old 07-04-2013, 05:05 AM   #78281
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,841
[QUOTE=AKASY;21781177]
Originally Posted by Rusty Rocket View Post
Have you priced it? If I recall, it's outrageous.
I just picked up a used factory original on EBay for $49 delivered--couple of minor smudges but otherwise perfect. They are out there.
Mine came with the bike.
Old 07-04-2013, 05:06 AM   #78282
thump!
thump!'s Avatar
Oddometer: 1,564
Originally Posted by FatChance View Post
When I got my first DR650 in 2003 it came with the factory printed manual (still have it). As I recall Suzuki was selling them for about $120 or so back then. It is very convenient.
Paper manuals are nice at home but they don't travel nearly as well as the PDF files on my Android phone. I have one for each of my 4 bikes on the Droid and have used them several times while traveling. Yes the screen is small but having that file in my pocket is way better than nothing at all.
thump! is offline   Reply With Quote
Old 07-04-2013, 05:07 AM   #78283
AKASY
Noob
Oddometer: 2,172
[QUOTE=eakins; 2 weeks is barely enough for Colorado alone.[/QUOTE]
Dang my planning must really suck I've been going to Colorado to ride for decades and I'm still finding new riding
Old 07-04-2013, 05:38 AM   #78284
scootac
Just a Traveler
scootac's Avatar
Oddometer: 3,209
I'm going to be hanging out here for awhile....
Brought this home last night,,, an '02.
Where's the shaft drive on this damn thing???
Been awhile since I lubed and tightened a CHAIN!!!
The world is a book, those who don't travel, read but a single page
'81 R100RT, '04 ST 1300, '02 DR 650
scootac is online now   Reply With Quote
Old 07-04-2013, 06:56 AM   #78285
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 648
Scootac, nice bike! Welcome into the light.
AdvGrifter, that twisty bumpy road looks like heaven! I would love to be on that with my little Ducati 900 ss.
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Times are GMT -7.   It's 11:48 AM.
