Old 07-04-2013, 11:26 AM   #78301
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by wavygravy87 View Post
You mean to tell me that Suzuki has sold a bike since '96 with a 3rd gear that MAY explode, and screws on the NSU that MAY fall out. Both instances probably trashing the engine. And they are fine with that, obviously. BUT! They decided to make the investment to install a seal retainer to prevent a seal that MAY (BUT I'VE NEVER HEARD OF) pop out and spray oil everywhere. The 3rd gear and NSU screws are reported cases, but the seal popping out is a new one to me. They really have their priorities together huh? Take that few Yen they spend on that damn retainer and put a lockwasher and some threadlock on those NSU screws why don't you?
Good points and it does raise questions. In Suzuki's defense, they have tightened up the NSU screws on newer bikes and now use an Allen Head bolt. The reason those bolts are not super tight is that the NSU plate is plastic. Too tight, it will shatter. But still ... Suzuki should Loc Tite those bolts in place at the factory.
The 3rd gear thing is a bit of a mystery. Most failures happen to Aussies. (maybe 85% of them?)
Hard off road riding may be the clue? Not sure. There is a WHOLE THREAD dedicated to this topic. Check it out.
My feeling on the seal retainer is that, for Suzuki, it's a clear and preventable liability issue. Oil on rear tire, instant crash. Big court settlement and a cheap and easy fix from the Factory. Not many have popped out ... but there are documented cases here on this thread and elsewhere. It's FAR from common, but does happen. If you look at all 78,000 posts on this thread. What? Maybe 5 to 10 cases at most?
In most cases you can simply PUSH the seal back in place ... or glue it in. (yes, it's been done). But now there are THREE options for retainers: 1. Berg Donk's prototype (the real pioneer on this mod), 2. Pro Cycle's elegant version, 3. Suzuki version, also elegant.
The original seal is some sort of Press fit. Obviously tolerances are not all that perfect or consistent and this is why some pop out. But the numbers, over all, are tiny relative to the roughly 100,000 DR650 produced since 1996.
I used Blue Loc Tite on my '06 NSU bolts, which were not loose but not tight either. I tightened them as much as I dare, added Blue Loc Tite. So far so good. No one has figured out the 3rd gear issue. Lots of questions there, fewer absolute answers.
Old 07-04-2013, 12:18 PM   #78302
thump!
thump!'s Avatar
Oddometer: 1,365
Originally Posted by Fire Escape View Post
Are the Suzuki factory seal retainers a 'bolt on' for older bikes? Just buy it and slide it in place without any machine work?
If so it would seem to be a quick and easy upgrade to consider. I have yet to lose a seal (on any bike) but riding a 'well oiled' rear tire has little appeal to me.
Bruce
Yes
thump! is offline   Reply With Quote
Old 07-04-2013, 12:29 PM   #78303
thump!
thump!'s Avatar
Oddometer: 1,365
Originally Posted by Adv Grifter View Post
That point can't be repeated too often.
Many uninformed riders of F.I. bikes seem to think Fuel Injected bikes are immune to losing power at altitude. They are not. While their fuel mixture is maintained as altitude increases, they do lose power the same as ALL internal combustion engines do.
My Non Stock jetting did not work above 13K ft. but the most noticeable was loss of overall power ... which on the DR begins at about 7 or 8000 ft and gets worse the higher you go.
Forced induction (supercharged/turbocharged) motors, particularly those with fuel injection don't really lose much since the supercharger usually has excess cylinder filling capacity. Turbocharging plus water injection where mainstays for high altitude flight of WWII piston engine aircraft. Modern OTR trucks are usually super/turbocharged and they can really haul the mail over the high passes. That's probably not gonna help your DR650 though.
Old 07-04-2013, 12:39 PM   #78304
andy from MO
andy from MO's Avatar
Oddometer: 26
Originally Posted by andy from MO View Post
Thanks so much for the link! $0.18 for 2 stainless washers to shim the stock needle up a bit and surge is totally cured!!! About 30 minutes and $0.18 and PROBLEM SOLVED!
I've never been one to make a bike overly rich.....I like the 60 mpg or so with this new 2012 and my previous 1996. I'll give you an update on what 2 small washers to shim the needle up will cost me in fuel mileage. I expect about 2-3 mpg but hopefully less.
PS- I left stock idle setting alone and stock main jet alone. 1 washer helped but didn't totally eliminate the surge....2 did the trick! I'll measure the thickness of the washers with micrometer tomorrow. Thanks again guys and gals!
Stainless washers were .028" thick each so I ended up shimming the needle .056" total. I think .040-.050 would do the trick too.
CV carbs DO compensate for altitude changes a little better (but not perfectly by any means). All around I like CV carbs.....just my nickels worth.
andy from MO screwed with this post 07-04-2013 at 10:44 PM
andy from MO is offline   Reply With Quote
Old 07-04-2013, 12:48 PM   #78305
8gv
Oddometer: 2,419
I believe ProCycle has a beefy third gear set for sale. It's pricey when used as a deterrent. The testimony I've read tells me the third gear issue grenades the engine. I wonder if I'll someday regret not putting in the set from ProCycle.
8gv is offline   Reply With Quote
Old 07-04-2013, 03:10 PM   #78306
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
Originally Posted by FatChance View Post
I grew up in Minnesota and both weeks of summer up there are wonderful!
If only they were consecutive.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 07-04-2013, 03:11 PM   #78307
scootac
Just a Traveler
scootac's Avatar
Oddometer: 3,058
Thanks for the welcome guys!
Coupla questions to start... just how common is this NSU thing I keep reading about? Bike has like 2600 miles on it. Don't know if it's been done on this bike or not. How worked up do I need to get? Neutral light works OK. The paper base gasket was changed out for the metal one according to the PO.
'Nother thing,,, no tools in the tool kit,,, so what size wrenches should I put in there? I'm thinking wrenches, screwdriver, fuses, zip ties and little roll of wire will stretch my wrenching abilities!
AND,,, will one of those PVC tool tubes fit in there or someplace else? I see Procycle has a steel one for sale,,, but $90 or so!
Thanks for the help!
The world is a book, those who don't travel, read but a single page
'81 R100RT, '04 ST 1300, '02 DR 650
scootac is offline   Reply With Quote
Old 07-04-2013, 03:18 PM   #78308
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,561
I know that there are more than a couple of pictures in this thread showing the location and procedure but the search function is a bit lacking (for me anyway), try using Google and include 'advrider' in the topic. Someone may come up with a link shortly.
Bruce
The ADV search function is generally useless and has been for all the years I've been hanging around here. Googling a topic produces better results and an inmate furnishing a link () is best.
My Clymer's manual should arrive in the next few days so I can plan my attack.
bwanacswan's dad
Old 07-04-2013, 03:24 PM   #78309
GSF1200S
Oddometer: 976
Originally Posted by eakins View Post
I was talking about people who toured out west. Their tour plan map had them going down interstates while in the mountains ie seeing Colorado from I-70 only. I've seen it enough to take notice it's common.
It's the screwed up US bigger is better mentality. They have 2 weeks and dammit they are going to visit all the western states. 2 weeks is barely enough for Colorado alone.
Not really sure you are talking about as far as why you live where you do? A bubble? As in everyone in the mountain states are just flipping houses or something??? That's just shallow-minded. People work hard everywhere they live. Some were born and raised in incredible place, but most chose to live where they do. It took sacrifices and effort like anything want in life. It's not fortune or luck that makes it happen, but determination and action. Many give up and stay where they are because that's all they know.
I agree with this. There is so much to see and I just don't think I could do two week trips and such. When you add weather it gets worse. I like being able to have time to just hang in one place and wait out weather, etc. I've seen guys taking trips from the lower 48 with only two weeks total. 4 days up 4 days back and a week in the state. I do get that people have families and work etc, but how do you enjoy such a timeline?
GSF1200S is offline   Reply With Quote
Old 07-04-2013, 03:26 PM   #78310
Adv Grifter
Oddometer: 6,128
When you get time, go ahead and read about this Novo 3rd gear set from the UK. Or ask Jeff at Pro Cycle. Lots of info here and a list of some of the 3rd gear failures:
http://www.advrider.com/forums/showthread.php?t=424132
The fact is there is no definitive evidence ...yet ... proving the Novo gear will prevent a trans failure. The salient point I noticed in all this was when the very experienced owner of Novo in the UK said he saw no faults with the stock Suzuki 3rd gear ... or any indication that the gear box design was any way at fault for the failures. Sure, his billet gear replacement is stronger, but is it really going to end 3rd gear failures? More questions than answer on this one.
Old 07-04-2013, 03:30 PM   #78311
Adv Grifter
Oddometer: 6,128
Nordie Banned? WTF!!
Anyone notice Nordie Boy has been banned? Anyone have any idea why?
Sure, he's a wise ass ... but come on mods. He's one of the most knowledgeable and experienced DR guys that's ever showed up here.
Give me a frickin' break!
I hope he makes it back!
Old 07-04-2013, 03:49 PM   #78312
Adv Grifter
Oddometer: 6,128
If one or both of the two NSU bolts falls out in can end in disaster ... or if you lead a charmed life, it will fall harmlessly into the bottom of the case to be fished out later. Most internal blow ups involve 3rd gear, but some could be from an errant NSU bolt floating around in there. The simple fix is to ask the PO of your bike if he addressed the problem, or pull off clutch side case and have a look in there. About a one hour job. If original NSU bolts are still there, then another hour or two to get in there and remove them, apply Loc Tite ... and button it all back up.
A TON of info on this thread, complete with pics and tutorials. Search and you will find.
'Nother thing,,, no tools in the tool kit,,, so what size wrenches should I put in there? I'm thinking wrenches, screwdriver, fuses, zip ties and little roll of wire will stretch my wrenching abilities! AND,,, will one of those PVC tool tubes fit in there or someplace else? I see Procycle has a steel one for sale,,, but $90 or so! Thanks for the help!
Tool kits:
The stock tool kit is no great loss. Nothing in there is great. I've done my own kit to fit the bike and modify my kit depending on ride at hand. I also carry a nice Nut/Bolt/Washer and misc kit. Here are a couple iterations of what I've got:
Long range kit. Make sure you've got key tools for the DR, proper allens, breaker bar, telescoping magnet, valve core remover and valve core fishing tool, small socket set, tire tools, levers, bead breakers. Vise Grips, tape, electronic kit, two part Epoxy, Super Glue, patch kit, Rubber Cement, spare Master link and on and on. The more you ride and travel the better feel you'll get for what works for YOU in your tool kit.
Old 07-04-2013, 04:57 PM   #78313
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 623
I agree re: Nordi boy. I've never seen any thing he has done to deserve banishment.
Rick
Cogent Dynamics Inc.
motocd.com
NC Rick is offline   Reply With Quote
Old 07-04-2013, 04:59 PM   #78314
NC Rick
Cogent Dynamics Inc
NC Rick's Avatar
Oddometer: 623
I need to ride with 'Grifter, my one pair of rusty pliers isn't likely to help me much
Rick
motocd.com
Old 07-04-2013, 05:00 PM   #78315
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,309
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Times are GMT -7.   It's 02:16 PM.
