Old 07-08-2013, 06:37 PM   #78451
GSF1200S
Oddometer: 976
Originally Posted by Adv Grifter View Post
Hard to tell from that pic ... but I'd say you're doing well on that sprocket.
If you can take off the plate and get an IN FOCUS shot, it would expose the sprocket shoulders better. Also, take you finger and feel the tooth edges ... if they are very sharp ... this is a sure sign of wear. But to my eye yours looks OK the the teeth tips are still squared off. Here are a couple of sprockets in various states of wear:
You can see that the sprocket on the right is just slightly "hooked". Not bad but it's there. But what is more common is the shoulder wear ... and the sharpness on the teeth edges. Compare to sprocket on left, which has about 5000 miles on it. Also notice the "wells" between teeth. On a worn sprocket these "Wells" widen. Can you see the difference?
Hard riding and Hard acceleration speeds up wear a lot. Also, high speed on the interstate will wear chain and sprockets faster.
So look for shoulder wear, hooking and tooth edge sharpness. A good front sprocket will save your chain, adding about 30% to it's life. (at least)
How much should I expect out of a DID xring chain having seen a bunch of dirt and highway? At 14k miles, changing the rear sprocket at 6k and the front at 9k, my chain is shot.
That said, I'd did the tat through AR and OK, trails in moab, 60 mph+ headed north, the Dalton, denali, road to McCarthy and countless other little dirt paths from time to time. I'm trying to gauge if its died too quickly or if that's just the way this dual sport deal is..
I'm used to getting about 15k on my Bandit, all street but WAY more power and torque and a thicker chain.
I have tried to clean it and use bel ray chain lube, but I get the feeling dirt sticks to the lube and acts like rubbing compound destroying the chain. I'm thinking of using automatic transmission fluid as it cleans and lubes- cleaning seems just as important to off road chain life as lubrication does.
This is my first dual sport and so I'm wondering what you all have to say. The chain didn't move after the initial stretch, but its now starting to kink and has just stretched for the first time. I'm holed up here in Fairbanks waiting for a moto shop to open tomorrow to see if they have a 525 chain 120 link (45 tooth rear sprocket), otherwise I'll have to order and wait here while its shipped. My fault, I just expected to make the lower 48 before this one would need replacement
GSF1200S is offline   Reply With Quote
Old 07-08-2013, 07:33 PM   #78452
Indytriumph
Indytriumph's Avatar
Oddometer: 33
Tell me more about the lights and what wind screen is that?
Tom
Originally Posted by Graniteone View Post
Rolling some fire roads near Cheeseman Reservoir Colorado. New fairing and lighting working well. [/URL]
Indytriumph is offline   Reply With Quote
Old 07-08-2013, 08:37 PM   #78453
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I'm assuming you've got the stock DID O ring chain on your bike now? If so, 14K in the conditions ridden IMHO, very good! Changing sprockets helps. My original chain only went about 12K and hardly any dirt or abuse.
It is ... IMHO ... well worth it to spring for a high quality DID X Ring chain. DID recently came out with a new line of X ring chains and I've not used one. I think the new ZVM series is slightly lighter duty than previous product. (525 VM-2)
I've used their previous 525, VM-2, X ring Gold chain on several bikes, over 200,000 miles. (Tiger 885, Vstrom, DR650) I got 25,000 miles on ALL my VM-2 DID X ring chains ... and never really managed to wear one out! It's a great chain, and next to stock you can easily see the difference. The X ring is a hunky thing by comparison. They really never stretch.
You may find the old VM-2 chain still in stock at some dealers but it's mostly discontinued and the new ZVM and VX Pro have replaced the VM-2. Try Pro Cycle, TPI, Keintech, Bike Bandit. Someone may still have the VM-2 in stock.
If not, go with the new DID X rings (ZVM or VX Pro). All are good and will last substantially longer than your original O ring chain. A Rivet link is highly recommended. DID now sell a complete KIT, with sprockets included. No idea if they are any good. I prefer OEM Suzuki sprockets because they seem to last longest.
Trans Fluid is a good lube but does not stay on long. Flys off. Bel Ray product is NOT GOOD IMO. Does not lube and collects grit. NO sticky lube for me. Trans fluid using an Auto Oiler like a Scott or other oiler is good for touring. Makes a mess but perfect for long rides in rain and such.
On the road I use 90 wt. gear oil and wipe down daily and re-oil. Cheap and excellent. Off road ... NO oil at all. Just clean with WD40 daily and wipe down. Change front sprocket at around 8K miles.
Old 07-08-2013, 08:45 PM   #78454
GSF1200S
Oddometer: 976
No, this IS a vx2 x ring chain! I have been very good with chain maintenance and I have used the belray stuff because it seems to be everywhere. To clean I've used kerosene when possible and diesel when not. There is no doubt however that it is shot.. clearly kinking.
I always lube on a hot chain, and I do not skip days. I guess I wonder how it managed to do so poorly. It has to be my fault because the chain is legendary. What is really good "lube" for off road scenarios? I don't like oilers specifically due to how they act off road.
I don't want to blame the chain lube and the calcium chloride shit on the dalton.. but I do want to
Old 07-08-2013, 09:07 PM   #78455
Adv Grifter
Oddometer: 6,128
Wow! I'm surprised the VM-2 crapped out on you so early! Bel Ray really sucks. So that could be part of the problem ... calcium chloride? Dunno.
Kero and Diesel are perfect cleaners.
Any chance you could be running your chain a bit too tight? About the only thing I can think of? Kinking is not good. Definite sign the end is near.
How far does the chain pull off the rear sprocket? That is another good measurement of wear.
I've positively hammered my DID's but I've NOT RIDDEN AS MUCH OFF ROAD, MUD, SAND AS YOU HAVE. IMO, that must be the difference. Of the 25K miles X 2 ... I've done on my two DID VM-2's on my DR, only about 3 or 4K miles was off road ... and most of that was dry sand, dirt, Desert.
I only rode some mud in Utah and Colorado, maybe 1000 miles worth total on my two rides out there.
I don't know what to suggest. The DID's are the best chains I've ever found.
Don't blame you for avoiding Auto oilers off road. The pros run NO LUBE AT ALL off road. But they can afford to put on a new chain/sprockets at every pit stop! We can't do that. But generally speaking I must say I've had the very best results with long lasting chains off road running NO LUBE at all. NO ... they won't match road going miles ... but do better than with a bunch of lube mixed up with sand. Run it dry. Wipe down and clean when you can ... especially after water crossings. Hope you can find something reasonable up in AK. Let us know what you end up with!
Old 07-08-2013, 09:08 PM   #78456
ER70S-2
ER70S-2's Avatar
Oddometer: 6,291
I got many thousands of miles after my chain started kinking. I asked a friend about the kinking on his KTM chain, "So what?" was his reply.
When my chain needed to be adjusted after each of 3 or 4 consecutive 200 mile rides, I replaced it.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 07-08-2013, 09:19 PM   #78457
GSF1200S
Oddometer: 976
This is why I'm thinking ATF fluid in a squirt bottle might be great. I have keintechs simple stand and it takes me seconds to get the rear wheel off the ground and spinning. If atf fluid cleans lubes, but must be put on a lot, it would be perfect for off road. Once I hit off road, stop lubing until I get back on road again, yeah?
This trip has had a lot of rain (but not in Alaska! Go figure ), mud, sand, etc.. but I still think it must be either me or the lube I used. I think I'm going to carry a small squirt bottle of diesel and a small squirt bottle of atf fluid and see how it goes.
Yeah, I won't buy anything but an o ring chain. If its cheap but alright quality I'll have a DID waiting in Montana. If I can't get decent quality, I'll wait here for one to be shipped. I'm going to remove my current chain (clip type) and SOAK it overnight in kerosene and see if it loosens up. It has just stretched for the first time after break in which is usually the sign of the end
Old 07-08-2013, 09:21 PM   #78458
GSF1200S
Oddometer: 976
I have heard some don't care, but I have also heard that snapped chains can be very bad. I'm headed down into Yukon and besides Whitehorse the next nearest sign of any society is Prince George BC. I guess I don't want to take the risk..
Old 07-08-2013, 09:33 PM   #78459
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 436
Tom
I bought the fairing and lights as a package deal from Advmonster. Lights are M60 with a rotary dimmer for the driving light. This is a totally plug and play set up. Flick on the high beams and you are going to see what is ahead of you for a good long while. Fairing does a good job of knocking down turbulent air and cleaning the air around your head up. I fully endorse this set up. Well done.
Here is a link for more info.
http://advrider.com/forums/showthread.php?t=766161
Graniteone is offline   Reply With Quote
Old 07-08-2013, 09:34 PM   #78460
Eggsontoast
Eggsontoast's Avatar
Oddometer: 66
Cry Cracked frame repair DR650SE
Hi guys and girls,
I have already performed a search on this and I have yet to find any real information regarding in depth weld repairs and frame composition for the DR650SE.
My DR has developed a crack in the frame, just above the swingarm pivot point.
I know how to weld and have access to my own equipment. I want to perform a repair which I will be documenting on these forums and youtube; as a guide to the people who have suffered from this problem and would like to perform a permanent weld repair.
This is very important to me as I use my bike for courier work and fun, she is my only form of transport and everyday I am off the road I am loosing serious money.
Could anyone please clarify to me what metal the DR's (SE model) frame is made from? As far as I can tell it's made from steel (Mild perhaps?) but I am unsure as to wether it is alloyed with anything else i.e: Molybdenum. If anyone has had any sort of experience at welding on these frames could they please come forward and shed some much needed expertise on the matter.
Much, much appreciated!
PAT
La Moto, c' est une aventure qui mene jusqu' au bout du monde...
Eggsontoast is offline   Reply With Quote
Old 07-08-2013, 10:06 PM   #78461
Samford
Samford's Avatar
Oddometer: 62
Runs like poo whenever there's water involved?!?! wtf?
I'm a bit stumped here...
So, whenever the bike gets drenched from either riding through deep puddles or it starts raining... the bike runs like (for lack of a better word) poo! It backfires like crazy when the throttle is released, it dies when left at idle for more than 5 seconds, and it has about 40% of its power until it dries up and then everything goes back to normal again. What the heck could be causing this? Is it inhaling water maybe? or something electrical? Any help would be appreciated.
*Edit: it has the pumper TM40 carb on it.
Thank you.
"'Any bike's subframe is liable to crack with the extra weight of the luggage when travelling on corrugated dirt roads,' it said somewhere. Hmm, I thought... mental note: Strengthen subframe. Second mental note: Find out what subframe is." - Lois Pryce
Samford screwed with this post 07-08-2013 at 11:38 PM
Samford is offline   Reply With Quote
Old 07-08-2013, 10:14 PM   #78462
ER70S-2
ER70S-2's Avatar
Oddometer: 6,291
Originally Posted by Eggsontoast View Post
Hi guys and girls,
PAT
It's a DR, made out of mild steel, weld it, ride it, don't jump it.
2013 WR250R
Old 07-08-2013, 10:47 PM   #78463
panhead_pete
Oddometer: 1,128
Thank you.
Have you re-routed the carb breather lines back up to the airbox?
More gear and still no idea.
panhead_pete is offline   Reply With Quote
Old 07-08-2013, 11:02 PM   #78464
Adv Grifter
Oddometer: 6,128
Kinking can sometimes be an early sign of wear. But sometimes kinks can be made to go away with good cleaning with Kerosene or WD40. Off road bikes develop kinks much earlier. If the kinks persist it's good indication you are about 4000 miles away from a new chain. (that is, on the fabulous DID VM-2 X ring chain) Other chains? A 1000 miles until it will be gone. I've never had a VM-2 stretch much. Maybe ONE adjustment in 25,000 miles. NONE of mine were really shot and I only replaced them as I had some big ride coming up. In Mexico or India ... my old chains would be kept in service another 10,000 miles easy.
Never start a long ride on a marginal chain/sprockets. Chapter ONE Page ONE of ADV 101 !
Old 07-08-2013, 11:04 PM   #78465
Adv Grifter
Oddometer: 6,128
Hi guys and girls,
PAT
What part of Australia are you from mate? (PS: The DR is not a Moto Cross bike ... or a Dakar Racer! )
Times are GMT -7.   It's 12:02 PM.
