Old 07-13-2013, 04:21 PM   #78661
Carl Childers
Ghost in the Machine
Carl Childers's Avatar
Oddometer: 807
Originally Posted by 955616846 View Post
Something I don't understand is why people replace the NSU screws when all that is required is that they are removed, cleaned and reinstalled with a drop of 243.
For the belt and suspender type guys allen heads are the way to go for using safety wire. I did mine with the basket on and replaced the stock screws with allen heads because it gave me a more precise feel to torquing them but as mentioned it's the loc-tite that ultimately does the job.
New Mexico, not really new, not really Mexico.
Carl Childers is offline   Reply With Quote
Old 07-13-2013, 04:23 PM   #78662
MrBob
Certified Geezer
MrBob's Avatar
Oddometer: 7,563
Originally Posted by Rusty Rocket View Post
is this what you're looking for
Not.
"When I was younger I was afraid I'd die riding now that I'm old and falling apart, I'm afraid I won't."
bwanacswan's dad
MrBob is offline   Reply With Quote
Old 07-13-2013, 04:44 PM   #78663
Hypnotizedd
Oddometer: 6
Hey guys, my 1998 dr650 needed a top end rebuild, I found a piston and cylinder off an 06 for the swap, and ordered these piston rings http://www.partzilla.com/parts/detai...140-32E10.html but the piston rings are too small, even though part ills said that those piston rings fit a 96-current. Does anyone know the bore size that I need to order?
Hypnotizedd is offline   Reply With Quote
Old 07-13-2013, 07:02 PM   #78664
procycle
procycle's Avatar
Oddometer: 2,385
Those rings should be correct. P/N 12140-32E10. There is only one ring size from OEM Suzuki.
Something is not right. Either wrong rings in the package or the piston/cylinder you have is from a big bore - something.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 07-13-2013, 07:19 PM   #78665
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Originally Posted by MrBob View Post
I got the SS allen screws at my local ACE.
The only problem with using stainless screws is that if one should ever come out again, it won't stick to the drain plug magnet.
Old 07-13-2013, 08:23 PM   #78666
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,689
great point.
Wow.
If I ever do switch them over (I have them loctited now, but with regular blue loctite, not the oil-specific stuff), I'll remember that.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 07-14-2013, 01:02 AM   #78667
Hypnotizedd
Oddometer: 6
The cylinder sleeve is 99mm bore, will any 99mm piston ring work? I'm having trouble finding one
Old 07-14-2013, 03:23 AM   #78668
newride
newride's Avatar
Oddometer: 704
rear sprocket screws
Is there any secret to getting the rear sprocket screws out more easily? I have only got 2 out of the 6 out. They just wont budge...
http://s704.photobucket.com/user/new...tml?sort=3&o=0
1975 BMW R90/6
My moto blog: http://jbloggie1.blogspot.com/
newride is offline   Reply With Quote
Old 07-14-2013, 03:30 AM   #78669
thump!
thump!'s Avatar
Oddometer: 1,510
The '98 DR650 has a bore of 100mm. The standard cylinder is plated (Nikasil or the like) and cannot be bored without replateing. AFAIK Suzuki does not make oversized piston although Wiseco and others do.
thump! is offline   Reply With Quote
Old 07-14-2013, 03:41 AM   #78670
RideAlongAtlas1
IS GOOD ! ! !
Oddometer: 147
Quite a specific question - for Procycle maybe.
Does anyone know if Procycle's Magnetic Sump Plug is built such that the screw-top-end hexagon part is also magnetic? Or is it just the screw-in THREAD part that is magnetic??
I bought the Procycle Magnetic Sump Plug. Got a dealer to fit it on the first service. Now that the magnetic sump plug is in, I went to check to see if the dealer remembered to use my magnetic sump plug and not just use a miscellanous sump plug.
Nothing metallic sticks to the sump plug crew-top-end hexagon part. So I can't tell if they used the magneitc sump plug I provided or if they forgot and just used anyone laying around the shop. Can;t tell until I have a 6000km service done (wiich Ill do myself) - one of the reasons I bought the bike was to work on it myself.
Thanks.
See my DR650 motovlog here https://www.youtube.com/ridealongatlas
RideAlongAtlas1 is offline   Reply With Quote
Old 07-14-2013, 04:34 AM   #78671
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Take the nut off behind the sprocket. Don't try to turn the screws. That is doomed to fail.
Emmbeedee screwed with this post 07-14-2013 at 05:07 AM
Old 07-14-2013, 04:49 AM   #78672
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,768
Originally Posted by RideAlongAtlas1 View Post
Does anyone know if Procycle's Magnetic Sump Plug is built such that the screw-top-end hexagon part is also magnetic? Or is it just the screw-in THREAD part that is magnetic??.
The magnet can't be seen from the hex side. It's an insert on the top, inside the engine. I think the hex is 14mm in size and I could be wrong, but I think the original drain plug was larger than 14.
I'll check later. I have 2 PC drain plugs in our bikes.
Old 07-14-2013, 06:07 AM   #78673
Ever Onward
Time Killer
Ever Onward's Avatar
Oddometer: 820
On the stock '06 carb,
Can anyone tell me what the low speed carb adjuster screw regulates ?
Meaning, does it control fuel metering, or air metering amounts in the low speed circut ?
Ever Onward is offline   Reply With Quote
Old 07-14-2013, 06:12 AM   #78674
brucifer
brucifer's Avatar
Oddometer: 2,488
Fuel. Generally as a rule of thumb, if the screw is located towards the front of the carb it regulates fuel--to the rear--air.
2014.5 Kawasaki KLR650 NE-2006 Buell XB12SS-2001 Husaberg FE650E-2001 Yamaha WR250F-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F
brucifer is offline   Reply With Quote
Old 07-14-2013, 07:13 AM   #78675
thump!
thump!'s Avatar
Oddometer: 1,510
+1 Also, they were most likely installed with thread locker. A bit of heat directly on the nut from a propane torch usually helps.
Times are GMT -7.   It's 02:49 AM.
