Old 07-17-2013, 08:23 AM   #78751
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,826
the DR650 thread
Originally Posted by thump! View Post
Hell, I'd buy his used oil!
Well if you are using this stuff, you are !
But I know your not Thump. . Just kidding.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot screwed with this post 07-17-2013 at 08:31 AM
DockingPilot is online now   Reply With Quote
Old 07-17-2013, 08:38 AM   #78752
DockingPilot
Oddometer: 9,826
the DR650 thread
Originally Posted by MoBill View Post
I gotta ask--what about OW30 synth--how does that breakdown--shear, what's that mean.
I'm not being a wise ass--I have the gene.
Well typically Bill the further the spread the quicker and more vulnerable the oil is to shearing. The molecule chain as they call them are longer and break easier. Which is why you see a lot of 20w50 , 10w30/40 spreads in conventional oils. Syns are able to spread it more (5w50 for example) supposedly.
Shearing means the oil has been broken down into a lesser grade weight. Gear boxes do a good job of this.
Never sampled a 0/30
Sent from my iPhone using Tapatalk 2
Frank Reinbold
Old 07-17-2013, 08:48 AM   #78753
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,748
I've been using the 0W40 in everything since about 2007...there are no "fuel economy" additives in the Mobil if I understand it correctly....no issues.
The WR250R, at 15,000 of hard miles when I hydrolocked it was tired, but clean as a whistle.
Oh...and 45,000 on the DL, 25,000 miles on the GS500--no issues with that oil...again--not really more than anecdotal evidence--but at least we know it doesn't cause a failure? Hmmmm...
MoBill is offline   Reply With Quote
Old 07-17-2013, 09:05 AM   #78754
DockingPilot
Oddometer: 9,826
the DR650 thread
No. I'm sure anything anyone uses is fine. The level I take it too is strictly for the bored and or anal. Lol
Frank Reinbold
Old 07-17-2013, 09:07 AM   #78755
MoBill
MoBill's Avatar
Oddometer: 13,748
THere's something to it--we used to send oil samples out on our diesel 12cyl M60 tank engines regularly--it's a huge predictor--for instance, that 3rd gear issue these can have--any of that possible to foresee?
Old 07-17-2013, 09:11 AM   #78756
DockingPilot
Oddometer: 9,826
Well ill keep and eye on the iron levels I have thought of that.
Frank Reinbold
Old 07-17-2013, 09:16 AM   #78757
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,544
all this oil talk is makin' me itchy.
I hate oil changes. Messy. Always end up with some on me and some on the garage floor.
The price of motorcycle oils makes me sick. almost as bad as when I go to the grocery store and see the price of food!
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 07-17-2013, 09:22 AM   #78758
victor441
victor441's Avatar
Oddometer: 993
+1, I maintained a bunch of diesel generators until recently, from a little 3 cyl. aircooled Lister up to a big V24 Detroit Diesel and we did an oil (also fuel and coolant) analysis on all of them yearly and it was definitely worthwhile, in some cases it gave early notice of serious problems. Oil analysis alone is not very expensive, don't think it would be any help with 3rd gear though, from what I've seen here the gear tends to crack into several pieces and probably would not contaminate the oil much beforehand.
victor441 is offline   Reply With Quote
Old 07-17-2013, 09:31 AM   #78759
DockingPilot
Oddometer: 9,826
Well Russ with that said, I'm out the door. I have a 1500 oil tanker inbound for Carteret NJ with a fresh supply.
Lol
But would anyone be surprised if I told you we are exporting more oil now then we ever did ?
Frank Reinbold
DockingPilot screwed with this post 07-17-2013 at 09:36 AM
Old 07-17-2013, 09:32 AM   #78760
MoBill
MoBill's Avatar
Oddometer: 13,748
Oil changes location in a variety of ways.
Old 07-17-2013, 09:41 AM   #78761
Rusty Rocket
Life behind "Bars"
Oddometer: 9,544
Still hate tire changes more.
2009 DR650
Old 07-17-2013, 09:51 AM   #78762
MoBill
MoBill's Avatar
Oddometer: 13,748
Word.
Old 07-17-2013, 09:54 AM   #78763
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Storage Wars ...
Originally Posted by bross View Post
Just curious about your intervals though. If your oil analysis is saying your oil is still good at 1000, why not run it to 1500? Blackstone usually recommend that anyway don't they? I thought that was the point of oil analysis.
I got a few samples checked with Blackstone years ago when I switched to Amsoil, mainly to see if I could go the Amsoil recommended twice the drain interval of the manufacturer. My oil tests on my Kawasaki Meanstreak (liquid cooled big twin) and BMW R1200RT (air/oil cooled twin)showed the oil to still be in spec well after the recommended drain interval. I didn't put enough miles on those bikes to double the drain interval with our short riding season in Canada but I was comfortable enough with the results to change the oil in the fall when the bikes get winterized and then just ride all spring/summer/fall.
I also hand the new owner of any of our bikes sold a detailed maintenance log and they all seem surprised and pleased as well. Most bikes just get ridden and put away with little regard for maintenance so I think buyers are surprised to find one that's actually been looked after.
I'd rather buy tires than oil. I've been known to replace a few tires before their time, but that's another discussion.
It's good you changed the oil BEFORE storing your bikes for Winter. Lots of guys put 'em away with old oil in there. Someone commented about engines stored for long periods and corrosion. Old oil left sitting can cause corrosion more quickly than fresh oil.
But all that said, if I were you I'd still try and run my bikes at least once a month or so, even if just idling and revving up a bit. 20 minutes should do it. All engines hate to sit ... only bad things can happen.
I kept two vintage Brit bikes for 11 years. I only rode them in Summer and not many miles if any. Sometimes if away for work or traveling I'd not be able to fire them up for as long as 3 months. One was a '79 Bonneville Special, the other a '67 BSA Lightning Rocket.
I used Stabil in the fuel (I kept tanks FULL) and Marvel Mystery Oil in both fuel and oil. I also fogged the cylinders with Marvel. They seemed to run better every year! ... and always started after 1st or 2nd kick. The Carbs never gummed up ... they just ran and ran. The old guy experts always said to change the oil before you stored them ... and the really anal guys would change it again before putting them back in service. I did not do this ... just ran the perfectly clean oil all Summer.
Old 07-17-2013, 10:16 AM   #78764
Adv Grifter
Oddometer: 6,128
Some Mobil One Synthetic oils are "energy saving" and others are not. Actually "most" of Mobil's most common synthetic car oil IS energy saving. I think it has a Green cap?
Mobil One Motorcycle specific oil of course, has no "energy saver" additives ... but Mobil make two others that don't either.
Wal Mart carry two versions that are NOT energy saving. One is called "High Mileage" (for high mileage engines), the other is something like "Extended Service", (claiming you can go further between oil changes) This extended service product I have not seen lately. Both are Full Synthetic, not blends. I'm not certain if these two oils would be considered "true synthetics" by the experts or not? Both are car oils, not the motorcycle version.
Anyway, I've used both of them for about 5 years now in a variety of bikes.
All good. No oil analysis, but no apparent issues in my 90K Vstrom (sold), WR250F dirt bike, 50K mile DR650, or Triumph Tiger 1050.
The good news is that Mobil One at Wal Mart is very affordable ... even more so when ON SALE. 3K to 4K change intervals here ...depending on use and time.
My 250F dirt bike gets fresh oil after just about every ride. (only 2 to 300 miles typically)
Old 07-17-2013, 10:21 AM   #78765
MoBill
MoBill's Avatar
Oddometer: 13,748
It has some of the API circle blank--doesn't say some of the shit that the other ones say about that--this is the OW40 Europeeon formula, so it's GOT to be good.
At about 500 miles--changing oil here before any more riding by the way. Just waiting on my magnetic drain plug!
Times are GMT -7.   It's 05:37 AM.
