Old 07-17-2013, 10:23 AM   #78766
procycle
procycle's Avatar
Oddometer: 2,403
Originally Posted by victor441 View Post
... don't think it would be any help with 3rd gear though, from what I've seen here the gear tends to crack into several pieces and probably would not contaminate the oil much beforehand.
+1
There have not been any reports of abnormal wear on destroyed third gear pieces.
Of all the spare transmission gears I have from various DRs the 3rd gears actually look less worn than any of the other gears.
There are a few photos here --> http://drriders.com/topic6662-30.html
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 07-17-2013, 10:23 AM   #78767
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,514
Originally Posted by MoBill View Post
At about 500 miles--changing oil here before any more riding by the way. Just waiting on my magnetic drain plug!
what's going in?
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 07-17-2013, 10:32 AM   #78768
MoBill
Smiles when says dat
MoBill's Avatar
Oddometer: 13,747
OW40 and GoldPlug.
MoBill is offline   Reply With Quote
Old 07-17-2013, 01:02 PM   #78769
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,810
Originally Posted by Rusty Rocket View Post
Still hate tire changes more.
So do I, but then I change tires a hell of a lot more often then I change oil.
Old 07-17-2013, 02:08 PM   #78770
WhichWayNow
WhichWayNow's Avatar
Oddometer: 160
Question Bike problem
I hate to interrupt another oil discussion, but I'm looking for some ideas on a problem that I have been having with my DR.
The bike is an '09 with over 25,000 miles on it. It has been well maintained with regular oil changes, valve adjustments, air cleaner cleanings, etc... It has an FMF Q4 pipe. The air box has been modded with most of the top cut out.
The problem started last summer. When passing at highway speeds, the engine will start to accelerate. It will then stop running completely for about a second or so, backfire and then accelerate again.
This problem has gotten progeressively worse. It has gotten to the point where the issue will occur while riding uphill at moderate throttle opening. It can even happen repeatedly sometimes at lower cruising throttle positions.
The problem is specific to certain specific throttle/load/rpm conditions. It does not appear to be random in nature.
I've spent a lot of time diagnosing this issue without any success in resolving it. The following are some of the things that I have looked into.
  • Cleaned the air cleaner. It is definitely not clogged
  • Adjusted main jets and needle richer, leaner and everywhere in between
  • Cleaned the carburetor throughly, including completely disassembling everything
  • Verified free flow of fuel out of the petcock. I removed the fuel line and opened the petcock. Fuel flowed out steadily. I also verified that the fuel line is not kinked.
  • I removed the little fuel strainer from the BST inlet.
  • Replaced the BST with a TM40 Pumper carb. The issue must not be the carb, because it is still happening with the TM40
  • New spark plugs
  • Adjusted valves
  • Added a cover on the top of the air box to restore nearly stock air opening
Basically I've tried all of the obvious steps that I can think of. Has anyone else run into this sort of issue? Does anyone have any idea where to look next?
WhichWayNow is offline   Reply With Quote
Old 07-17-2013, 02:15 PM   #78771
dankatz
Oddometer: 350
  • New spark plugs
  • Adjusted valves
I don't have an aftermarket pipe, but had a similar problem on my last trip (2008 with 21k miles). On my bike, it was obvious to me what the issue was - a burned clutch. Any uphill it would stop accelerating and sometimes even loose speed. Maybe, your clutch is slipping? Is it the original?
dankatz is offline   Reply With Quote
Old 07-17-2013, 02:19 PM   #78772
WhichWayNow
Oddometer: 160
I have had the clutch replaced. I did have a slipping issue a while back. This is an engine problem where the engine quits running completely for a breif moment.
Old 07-17-2013, 02:25 PM   #78773
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
Sounds like a sidestand switch problem to me. Try holding the stand up with a bungee to see if it happens again.
My DR was cutting out, confirmed by the method I mentioned above, and a new set of sidestand return springs cured it.
In fact now that I see your original description, I'm sure that this is your problem. Passing at speed is exactly where I had the same problem as you describe.
Emmbeedee screwed with this post 07-17-2013 at 02:38 PM
Emmbeedee is online now   Reply With Quote
Old 07-17-2013, 02:38 PM   #78774
WhichWayNow
Oddometer: 160
My DR was cutting out, confirmed by the method I mentioned above, and a new set of springs cured it.
Interesting thought, I'll check that out. I would think that it would cut out when I hit bumps if that were the case. I haven't noticed any correlation there, but it's worth checking out.
Old 07-17-2013, 02:42 PM   #78775
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,836
I think vibration at passing speed and leaning out to pass is what makes it happen then. Bumps didn't have any effect, on my bike.
Old 07-17-2013, 02:56 PM   #78776
dankatz
Oddometer: 350
That is odd - I agree. Do you think the petcock maybe malfunctioning sometimes?
Old 07-17-2013, 02:56 PM   #78777
Krusty ...
What? Me hurry?
Krusty ...'s Avatar
Oddometer: 7,600
I'd that's not it, inspect your other electrical connections, under the seat and tank. Not sure which tank you're running, but you may have a kinked vacuum line that is restricting flow intermittently.
SUZUKI DR650SE INFORMATION INDEX
"...choosing a DR indicates an affinity for peace, harmony and enlightenment. Serenity lies in accepting it as it is, changing what you want, and the wisdom of knowing it ain't orange." -psmcd
Krusty ... is offline   Reply With Quote
Old 07-17-2013, 02:58 PM   #78778
barko1
barko1
barko1's Avatar
Oddometer: 3,405
Recently I had a similar issue, changed out the fuel but it seemed so abrupt, seemed electrical. Happened in several gears and seemed to be when the engine was under a heavy/accelerating load. Today I rode it hard on some rougher dirt and it never happened.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 07-17-2013, 02:59 PM   #78779
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Given that the cut out occurs at a more predictable point ... I'm guessing it's not the side stand switch (but of course it could be ), certainly worth checking.
IMO, the problem is definitely electrical/spark related.
Start with the simple things:
Check Kill switch for grounding
Ignition key switch issue?
Check for shorting or broken wire (like in the stand switch and clutch disable area)
Replace the Spark plug wires and caps (unlikely as DR will run on just one)
Check out the coil (very rare to fail on the DR ... never heard of a failure)
God Forbid ... ECM. Best way to check is to replace with a "known good" ECM unit and pray that is not it. Expensive.
I'm not certain if an intermittent Regulator/Rectifier could cause that sort of total cutting out or not? Perhaps one of our resident EE's could chime in?
Old 07-17-2013, 03:05 PM   #78780
Adv Grifter
Oddometer: 6,128
Water in fuel can cause a sudden cutting out. It really can mimic an electrical problem. And sometimes if takes full throttle (and enough vacuum) to suck the water up from deep in the Carb Bowl. (water sinks in gasoline)
Draining Carb bowl or tank worth a shot ... can't hurt!
Times are GMT -7.   It's 06:50 PM.
