Old 07-17-2013, 03:06 PM   #78781
thump!
thump!'s Avatar
Oddometer: 1,575
Originally Posted by Adv Grifter View Post
I'm not certain if an intermittent Regulator/Rectifier could cause that sort of total cutting out or not? Perhaps one of our resident EE's could chime in?
Not likely as the ignition and charging systems are completely separate.
thump! is offline   Reply With Quote
Old 07-17-2013, 03:13 PM   #78782
ER70S-2
ER70S-2's Avatar
Oddometer: 7,022
Gas cap may not be venting properly.
My first guess would have been the inlet filter, but you BTDT.
If you're jetted for the open airbox, just closing the opening (closer to stock), you'll be jetted way too rich.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 07-17-2013, 03:43 PM   #78783
Ever Onward
Time Killer
Ever Onward's Avatar
Oddometer: 875
Seat decisions
Sargeant vs Seat Concepts kit.
I need a comparison. Both in how the long term feel is and their shape / construction. How they effect seat width and height between the two would be great.
Ever Onward is online now   Reply With Quote
Old 07-17-2013, 04:11 PM   #78784
Graniteone
3,2,1...Beer me!
Graniteone's Avatar
Oddometer: 463
Sargents is very comfortable. But I prefer the Seat Concept seat I have now. I like a little narrow seat profile and I like the texture of the SC seat better. Just my .02.
Graniteone is offline   Reply With Quote
Old 07-17-2013, 04:28 PM   #78785
procycle
procycle's Avatar
Oddometer: 2,421
Originally Posted by Emmbeedee View Post
Sounds like a sidestand switch problem to me.
+1
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 07-17-2013, 04:41 PM   #78786
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,820
I have no comparison to make.
My purchase (today, in fact) of my first Sargeant saddle was determined by them creating a whole new seat pan from which to build off of. Sounds like a reasonable idea to me.
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 07-17-2013, 04:44 PM   #78787
barko1
barko1
barko1's Avatar
Oddometer: 3,403
Water in fuel can cause a sudden cutting out. It really can mimic an electrical problem. And sometimes if takes full throttle (and enough vacuum) to suck the water up from deep in the Carb Bowl. (water sinks in gasoline)
Draining Carb bowl or tank worth a shot ... can't hurt!
Did that to no avail, but thanks. There was some remains of an IMS gas cap in there which I removed and replaced but it still had the miss. May be that pesky sidestand but it sure would seem that it would be an issue in rougher terrain
DR650, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), Triumph Thunderbird Sport, Triumph Daytona Super III, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 07-17-2013, 06:56 PM   #78788
tlmaffucci
tlmaffucci's Avatar
Oddometer: 257
Passive, cheap modifications
For example:
  • Magnetic oil plug
  • Fuel cap, fuel filter bag
  • Lucas fuel treatment (not as passive, but quite helpful)
Can anyone think of more?
tlmaffucci is offline   Reply With Quote
Old 07-17-2013, 07:28 PM   #78789
WhichWayNow
WhichWayNow's Avatar
Oddometer: 160
Thanks for all of the replies. I have checked the fuel tank cap and vents, no clogs there. It has an IMS tank. The petcock came with the tank. It's a basic three position one; off, on and reserve. The stock vacuum operated one was removed.
I've had the carb apart so many times, the float bowl is clean. I also replaced the float assembly not long ago. I took the bike to a local shop and they put a rebuild kit in the carb (needle, emulsion tube, o-rings, etc...) None of that helped either.
I fiddled with the side stand this evening and don't think that is it, but I will try a bungee cord on it next time I ride it.
I'll look into more of the electrical side as well. I had to replace the stator at the end of '11 because it lost spark completely. Fortunately, I am an EE so if it is electrical, I can probably track that down.
WhichWayNow is offline   Reply With Quote
Old 07-17-2013, 08:34 PM   #78790
8gv
Oddometer: 2,490
Here's how you bypass the sidestand switch:
http://www.google.com/url?sa=t&rct=j...nHPE6RokJqOt_g
8gv is offline   Reply With Quote
Old 07-17-2013, 10:09 PM   #78791
ER70S-2
ER70S-2's Avatar
Oddometer: 7,022
That's a good video explanation and belongs in Krusty's Index.
http://www.advrider.com/forums/showt...=636395&page=5
2013 WR250R
Old 07-17-2013, 10:45 PM   #78792
WhichWayNow
Oddometer: 160
Thumb
I have to give a big thanks to everyone who said to check the side stand switch.
I jumpered it out this evening and took the bike for a test ride. It ran great! No stumbles at all.
The way it was acting, I don't think I would have guessed that would have been the problem.
Once again, Thank you everyone!
Old 07-17-2013, 10:57 PM   #78793
ER70S-2
ER70S-2's Avatar
Oddometer: 7,022
2013 WR250R
Old 07-17-2013, 11:13 PM   #78794
procycle
procycle's Avatar
Oddometer: 2,421
Yep, it's decieving but your symptoms were exactly what we see when the switch is just starting to fail.
Old 07-18-2013, 03:07 AM   #78795
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,861
Uh, it's not the switch that failed in my case; it's the sidestand springs which were weak. $6 for a new set, and all is well now.
Times are GMT -7.   It's 04:55 PM.
