Old 07-19-2013, 11:39 AM   #78856
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
Originally Posted by Mambo Dave View Post
The important part is 'usable' capacity. I swear that while my stock tank has about 3.5 gallons of gas in it, even on reserve I don't have access to it (though I've never tried to run it out... but after hitting reserve and heading to the gas station I'm always miffed that the tank only took 2.5 or 2.7 gallons of fuel).
That is typical of many fuel tanks on various bikes. Always a certain amount of fuel you cannot use.
To know for sure ...pull the petcock out and measure how much fuel is left inside. It's been so many years since I had the stock tank on ... I'm not sure what the range is on stock tank. Range also can be dependent on your individual bike, jetting, riding style, altitude, terrain.
On 100% stock DR650 I recall only going about 130 miles until reserve ... then only about 10 or 15 more miles on reserve (???). I'm sure some will go more or less.
Try this trick when you run out: Lay the bike over on it's left side and slosh some of that fuel over to the petcock. Good for a few more miles. You can do this maybe 5 or 6 times and go a few miles each time.
On my IMS tank, after Reserve was depleted, there was still 2 liters in the tank. (I drained it and measured it) After cleaning the Petcock filters my reserve range went from 15 miles ... to 32 miles. (measured)
With everything clean and running well I now have close to 250 mile range
(including reserve) on the IMS tank. YMMV of course!
Old 07-19-2013, 11:41 AM   #78857
ER70S-2
ER70S-2's Avatar
Oddometer: 7,222
Originally Posted by Low Budget View Post
Quick question, whats the true actual capacity of the stock DR fuel tank ?
And, what a real world distance you can get outta reserve if you ride gentle trying to milk the most MPG outta the reserve portion ?
I always run til reserve (light traffic). I've frequently ridden 35 miles on reserve (with a knot in my tummy ) I never had trouble with fuel remaining in the right tank lobe, I don't know why. I did the run til empty test with a spare gallon on board: I got 39 miles on reserve, milking the mileage. This was on pavement and I didn't have to tip the bike to get the last of fuel across the hump. fwiw: this has me
For reference, 90% of the time I get to 160 before hitting reserve. Disclaimer: I ride at 6000+ feet and am jetted accordingly.
So, to answer the question, my stock DR tank holds very close to 3.4 gallons. The Kalif bikes are advertised at 3.2 gallons.
Luckily I had the camera along when I did this. No coasting but light throttle. Also on pavement, nothing to jiggle the fuel over the hump.
It's been said that this can't be done, but I have pics.
Note odometer:
Originally Posted by davorallyfan View Post
DRF Post#3
Got a TR650 now (6 years later) they are pretty good too (fark they go). Still a DR fan... but.
Originally Posted by barko1 View Post
I decided to do the fix but my connectors were small pins and I didn't have anything to make a good jumper with so I cut/soldered, shrink wrapped and tucked it all away.
Just rode it hard on pavement and dirt and couldn't get the cutting out symptoms to reappear so I think that must have been it.
8gv:
Could you add a note to your post about this in the Index, please. Then guys won't freak out if they find pins instead of blades.
Originally Posted by Adv Grifter View Post
Sota, might i suggest you go to the very beginning of this thread ... and start reading? I've noticed you've started MULTIPLE threads on Thumpers asking basic NOOB questions about the DR650 that have already been answered 10,000 times in this thread. All ya gotta do is read mate.
The real answers are HERE ... and are from actual DR owners, not random idiot NON DR650 riders that populate the Thumpers forum.
Well, there is that.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 screwed with this post 07-19-2013 at 12:15 PM
ER70S-2 is offline   Reply With Quote
Old 07-19-2013, 12:11 PM   #78858
Adv Grifter
Oddometer: 6,128
This is why Im asking. I dont have the bike rideable at this point and short of starting with a bone dry tank, filling it to the top, running it till I hit reserve, setting the trip meter right then, riding real easy till it runs dry, would I know the real world reserve distance its capeable of.
Just gettin ballpark numbers for a referance point.
I'd want more than ball park figures if you ever ride any where off the beaten path. When you get your bike on the road .. ride until reserve, NOTE MILEAGE, Zero out ODO.
Now strap a little 2 gallon gas jug on your bike and ride until reserve runs out. NOTE MILEAGE.
Now, just add minimal amount of fuel to get to gas station. Fill up, note how much it takes minus amount added from fuel jug. From that you can figure MPG (mas o menos)
If you ZERO your ODO at every fill up ... then you will know how far you can go until reserve and at fill ups you can calculate your MPG. And using the method above, you'll know reserve distance as well. With a stock tank, this, IMO, is a must do thing.
When riding the Suzuki DR650 press bike (all stock) I ran the damn thing out of gas 3 times! It won't go far if you hammer it, that much is for sure.
Old 07-19-2013, 12:23 PM   #78859
Adv Grifter
Oddometer: 6,128
DRF Post#3
Lots of time and miles under the bridge eh?
I'd love to hear a long range report on your Terra experience after a season or two of riding. And of course ... you'd be The Man to do a point by point comparo of the Terra vs. DR650.
I'm seriously shopping this bike ... but feeling pressure as I fear they will ALL be gone very soon. For good? Man, hope not. I've only done a brief test ride. Good in every way. Only question for me is how good a long range travel bike would it be? Like RTW. And really, how tough a bike is it?
Anyway, any comments would be interesting once you have some feedback.
Old 07-19-2013, 12:31 PM   #78860
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,723
The one point I can't get past is the weight difference. Like 50+ pounds heavier for the Husq.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 07-19-2013, 12:52 PM   #78861
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,917
Sargent. No welts
Sent from my iPhone using Tapatalk 2
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 07-19-2013, 01:31 PM   #78862
shu
Oddometer: 1,073
NOW you guys post this... one day after me ordering my first Sargeant, and with specific colored 'piping' (or welt).
Is it really that noticeable?!
No worries. Mine has a welt- I never notice it at all.
..............shu
shu is offline   Reply With Quote
Old 07-19-2013, 01:40 PM   #78863
thump!
thump!'s Avatar
Oddometer: 1,634
Range varies substantially with the type of riding. Riding hard I get low 50's mpg (US). OTOH, light usage delivers high 50's. Based on a 4.5 gallon fillup, that can be a 30-50 mile difference. That can be important in some places. There are places on the TAT where there is no gas available for close to 200 miles. I never count on more than 50mpg. More than that is a bonus.
thump! is offline   Reply With Quote
Old 07-19-2013, 02:13 PM   #78864
DockingPilot
Oddometer: 9,917
Denio Junction to Lakeview Ore the longest at 225 if I remember right.
Frank Reinbold
Old 07-19-2013, 03:48 PM   #78865
refokus
Just Learning
refokus's Avatar
Oddometer: 2,549
Yeah.............
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 07-19-2013, 04:19 PM   #78866
Magnum Noel
Magnum Noel's Avatar
Oddometer: 196
Ok mine hits about 190klms before reserve and I have carried on to 260klms. That was driving very carfully. I must admit getting a bit worried until I reached the servo.
Magnum Noel is offline   Reply With Quote
Old 07-19-2013, 04:24 PM   #78867
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,858
Mother of God...
I hit 95 miles, or 102 to - at the most one time - 107 before hitting reserve.
Jetted accordingly for 11 feet above sea level (I think, and the bike and plugs seem to agree).
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is offline   Reply With Quote
Old 07-19-2013, 04:32 PM   #78868
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,858
Better, larger forks (& rear suspension), stiffer frame, and the beefiness to be able to create more power?
That would cover it for me. If the DR650 had 50 more pounds but very high quality suspension I guess I'd be just as happy with it, but it doesn't - which is why I don't own a KLR650 since it seems to give nothing for its weight.
Edit: Oh Jesus, and Brembo Brakes?!! Yeah, I'd be content.
their motorcycles
RyanR
Old 07-19-2013, 05:09 PM   #78869
8gv
Oddometer: 2,521
Here we go again with the km's...
8gv is online now   Reply With Quote
Old 07-19-2013, 05:13 PM   #78870
8gv
Oddometer: 2,521
On my first DR650 trip last weekend I got 148 and 144 statute miles when reserved was required. Almost immediately afterward, I pumped 2.9 gallons to fill it both times. I have the Raptor fuel tap from ProCycle. I wonder if it gives less run and more reserve.
Times are GMT -7.   It's 07:44 AM.
