Old 07-22-2013, 09:11 AM   #78961
barko1
barko1
barko1's Avatar
Oddometer: 3,405
Originally Posted by bonnyc View Post
I am
1. a beginner rider (don't have a bike yet, am considering a DR650 for my first bike)
2. not mechanically adept or inclined and
3. I live in NYC, where there is a good chance the bike is going to be in storage for 6-8 months, and maybe ridden only on weekends during summer months.
How hard will it be to own a new or close to new, completely stock DR650? Will the carbs need much fiddling and work?
How much time should I expect to spend per week on maintenance, and how hard will it be to pick the skills up?
Find someone inclined . But really if you get a newer/low mileage DR it should be easy but with the storage and crappy gas you'll have to get some fuel stabilizer for those periods of non use. Here in the great American Southwest I drain my carb and tank if I'm not going to use the bike (rare!) but given your location and humidity I would guess that leaving the tank full with stabilizer is the better option. Run the carbs empty or drain them, not a big deal. The fuel will go bad, without stabilizer, whether the bike is injected or carbed. I'm sure others will chime in.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 07-22-2013, 09:50 AM   #78962
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I am
True, Fuel injected bikes can be even MORE problematic if let to sit too long without fuel stabilizer. But with stabilizer in the fuel, all should be OK on the DR650.
Ideally, even in Winter, try to start up the bike once a month or so, Run it for 15 minutes. Store it Full of fuel, and add Marvel Mystery Oil to the fuel as well as Stabil (fuel stabilizer). Also, buy a Battery Tender and keep your bike plugged in ALL WINTER. Simple.
As a new rider ... first priority would be to enroll in an MSF rider course. (Motorcycle Safety Foundation) You'll learn a lot, it will really help develop good riding habits early on. A "must do", IMO.
The DR650 is really nearly maintenance free. Oil and clean the chain once in a while and replace tires when worn out. Over time you may want to make a few upgrades to the bike ... but for your first year ... just ride and enjoy and concentrate on your riding and getting BETTER on the bike.
Old 07-22-2013, 10:24 AM   #78963
barko1
barko1
barko1's Avatar
Oddometer: 3,405
And if you don't have an electrical connection where there bike will spend the winter pull the battery and bring it home with you and keep it on the tender.
Old 07-22-2013, 11:08 AM   #78964
FatChance
Road Captain
FatChance's Avatar
Oddometer: 10,502
Originally Posted by sandwash View Post
Isn't Durango home of million dollar highway?
After inflation it is now the 1.26 Billion Dollar Highway.
Technically, the Million Dollar Highway is US550 between Silverton and Ouray, Colorado.
Pain in the Butte Ranch
Durango, Colorado
- Calculated risk or forbidden fruit?
FatChance is offline   Reply With Quote
Old 07-22-2013, 11:28 AM   #78965
bosley1980
Oddometer: 162
Originally Posted by Mambo Dave View Post
Thanks for the replies on the lowered footpegs guys.
Hello Dave maybe can help you?
Look at this thread
http://www.advrider.com/forums/showthread.php?t=879707
bosley1980 is offline   Reply With Quote
Old 07-22-2013, 12:38 PM   #78966
shu
Oddometer: 1,053
I am
Good choice for first bike, I think. Not too heavy, very easy to maneuver once you learn how. Do take a riding course, but understand that if you ride infrequently, you will remain a beginner for a long time. It takes a lot of miles to get a real feel for the mechanics of riding and a lot more to be safe in traffic.
Start easy, by doing oil changes. Have someone there to confirm that you're doing things right and not over or under- tightening bolts.
It sounds like your bike might sit for 4-6 weeks without being ridden even in the riding season. Given this kind of use I would plug it into a Battery Tender Jr. whenever I parked it and I would keep the gas dosed with Stabil year round. Installing the wiring harness for the Battery tender is another easy project you could tackle early on, again with someone assisting. Lots of little things you can do on this bike that will turn it into something you understand, rather than just a mechanical mystery.
Shouldn't need much fiddling, at all.
[There is a lot of discussion here that starts out this way: "my bike runs great except when I ........." but you will notice after a while that mostly it's the guys who are modifying things who are having carburetor problems and they eventually seem to get it all straightened out. Those of us with unmodified carbs seem to mostly do just fine. There are a couple of things you might eventually decide to do to your carb: extended fuel screw so you can adjust it without trying to get a tool in there, and possibly putting a carb mounted choke (enrichener) on- the stock enrichener cable from the handlebar has been known to corrode and stick.]
For the amount of riding you're talking about you will probably need to do next to nothing per week. Clean and lube your chain every few hundred miles, put gas in it and go.
.............shu
shu is offline   Reply With Quote
Old 07-22-2013, 03:22 PM   #78967
BergDonk
BergDonk's Avatar
Oddometer: 3,809
Originally Posted by Albie View Post
What did you use? I'm with you, I don't like the flex when I stand. I really can't feel any difference in vibes between my DR and the other bikes I have that aren't rubber mounted.
I originally cut down and rearset the stock hangers, then made my own solid ones. Both with the same Fastway F6 pegs.
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 07-22-2013, 05:25 PM   #78968
refokus
Just Learning
refokus's Avatar
Oddometer: 2,514
BergDonk, help me out here.............please..............or anyone else that has a good solution. I have seen the brackets where they drop the peg and also set it back an inch, but I don't want nothing lower then what the frame/skip plate is.
I have not had my DR for too long but I have taken it on two rides that knocked the new off of the suspension. But, the peg position on this bike sucks. I was in the middle of a nasty climb yesterday and the position and the flex of the pegs was pretty bad. I have been trying to figure out a way to fix this problem. Lower and back.............
"Single Trac is like Scotch, you have to aquire a taste for it!"
refokus is offline   Reply With Quote
Old 07-22-2013, 08:47 PM   #78969
tlmaffucci
tlmaffucci's Avatar
Oddometer: 257
This is my upper chain roller which I just removed. It looks like it has some wear, should it have this much wear for a bike with 1600 miles? Just checking. thanks
tlmaffucci is offline   Reply With Quote
Old 07-22-2013, 08:56 PM   #78970
ER70S-2
ER70S-2's Avatar
Oddometer: 6,926
No, it shouldn't have that much wear and that's why some of us remove them; before they do this:
I think this is MotoScooter's photo.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 07-22-2013, 09:03 PM   #78971
tlmaffucci
tlmaffucci's Avatar
Oddometer: 257
Yeah, thanks. My thoughts were that if it had this much wear, it must be doing something it's supposed too. Guess not. What IS an upper chain roller supposed to do?
Old 07-22-2013, 09:10 PM   #78972
ER70S-2
ER70S-2's Avatar
Oddometer: 6,926
The answer to that question may go on for several pages. It couldn't be too important, mine has been out for 40k + miles.
Oh, and welcome to the site.
2013 WR250R
ER70S-2 screwed with this post 07-22-2013 at 09:17 PM
Old 07-22-2013, 09:58 PM   #78973
tlmaffucci
tlmaffucci's Avatar
Oddometer: 257
Thank you very much! I'm happy to be here.
Old 07-23-2013, 01:06 AM   #78974
Kommando
Kommando's Avatar
Oddometer: 7,389
I am
The DR only has one carb, and it's a simple one. Mine has a Procycle jetting kit and I hardly ever mess with it since initial install, unless I'm changing mufflers. The DR is pretty simple too. Get yourself a decent service manual...book form is usually easiest for me to use. The factory toolkit actually works, but you're likely to want tools that are more comfortable to your hands. You may also want a torque-wrench. See Harbor Freight's website and read reviews before buying. Do the MSF pre-ride inspection...T-CLOCS. Be careful not to over-torque fasteners, especially ones that thread into aluminum. Ask an experienced local guy to show you how to follow the manual. Loc-Tite and anti-seize are your friends. Consult us beforehand if you need any help. Lots of DR owners here are a wealth of info, and they can save you from breaking your bike. Keep the chain lubed/adjusted, tires properly inflated, fasteners properly torqued, and google the common DR650 "fixes".
Put the battery on a tender if it's parked long, as mentioned. I use SeaFoam in my fuel, and it cleans/stabilizes the whole fuel system. Put the bike on a stand, to get it off the tires. Put decent tires on the bike and ride it all year.
Definitely take a Beginner Rider Course (BRC). With a dualsport, you can practice on dirt AND large empty parking lots before attempting traffic.
Check out the DR650 section of www.procycle.us for DR parts/upgrades. wwww.kientech.com also sell DR items. I also shop classifieds for used parts...here, DRRiders.com, Ebay, craigslist, etc. The websites for Motorcycle Superstore, Bike Bandit, Iron Pony, Cycle Gear, and many others are good for new tires, apparel, and other items.
Kommando is offline   Reply With Quote
Old 07-23-2013, 04:16 AM   #78975
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,841
My DR had been "fiddled" with when I bought it and it ran like a piece of crap, fouling plugs and smelling of unburned gas. I made it run much better now but I can't get more than about 350 kms on a full IMS tank. My wife's bike was bought completely stock, unmolested. Her bike starts much faster than mine and never misses a beat. She can go 450 kms on the same size of fuel tank.
So based on that, the next DR I buy will probably not have its carb played with. So if I was you, I wouldn't worry about anything more than putting fuel conditioner in it when you store it.
Times are GMT -7.   It's 02:51 AM.
