Old 08-10-2013, 07:49 PM   #79831
Ever Onward
Time Killer
Ever Onward's Avatar
Oddometer: 857
Yep, by all means leave it alone if its running just fine at all throttle positions.
But......if it has that lean "Surge" at steady throttle settings around 1/8 to 1/4 throttle position.....its the needle. Call Derek directly at Motolab and he will hook you up. Replace all the orings and gaskets to be sure that wont be causeing any problems when you do the carb work....cheap insurance to avoid confusing frustration.
Its a fairly simple tuneing process, Derek can explain.
By the way, I dont know what my MPG was before the non USA needle......it surged so bad on the 30 mile ride home, I parked it till I did the carb setup. Initially I was in the mid 50's, and with fine tune on the slow speed screw and being sure the enrichener plunger was fully seated with a little extra slack in the enrichener cable, I jumped up to a average of 60 MPG in a combo of all types and speeds of rideing.
Ever Onward is offline   Reply With Quote
Old 08-10-2013, 08:34 PM   #79832
zdiver1
zdiver1's Avatar
Oddometer: 471
Thumb Mail man came! PC Stuff from Warp 9.
https://www.facebook.com/photo.php?fbid=10200999493861627&set=a.10200999492101583.1073741830.1595374349&type=1&theater
zdiver1 is offline   Reply With Quote
Old 08-10-2013, 08:40 PM   #79833
zdiver1
zdiver1's Avatar
Oddometer: 471
Warp 9
Warp 9 clutch and front brake levers, 320 mm front brake rotor and starter bearing cover.
Old 08-10-2013, 10:03 PM   #79834
ER70S-2
ER70S-2's Avatar
Oddometer: 6,893
Originally Posted by tlmaffucci View Post
It's more like this: If somebody is telling me I can get an extra 5-10 mpg, that makes a pretty big difference. You're right, it isn't broken. However, it can be better. Right?
I'm just another guy on the internet, but I can damn near guarantee that if you screw with your carb, your mileage will go DOWN, not up. Suzuki has the DR jetted to pass EPA regulations and the EPA doesn't give a crap how your bike runs. They do this by jetting LEAN. If you decide to make the bike run better, you'll be putting in larger jets = lower mileage.
I live and ride at 6,000 feet + altitude. I get to run the very lean jetting Suzuki provides as stock. If somebody is telling you that you can get an extra 5-10 mpg at an altitude lower than mine, they're 'stretching the truth'.
With the stock tank, I didn't hit reserve until 160 miles (+or- 5 miles), almost every tankful. 60 mpg on a regular basis, Scouts Honor. I also ride like
If mileage is important to you, check your mileage for several tanks before changing anything. Then check your mileage after you make changes.
Just another guy on the internet.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 08-10-2013, 11:36 PM   #79835
motolab
motolab's Avatar
Oddometer: 2,776
If the engine runs poorly at the opening the EPA tests at, the operator is likely to open the throttle in order to get out of that zone. If the carb is jetted correctly, the same motive force can be achieved at a smaller opening, which serves to improve efficiency.
You will need to open the throttle further for a given road speed than the guy at lower altitude who has carb jetted correctly for his altitude.
Regards,
Derek
motolab is offline   Reply With Quote
Old 08-11-2013, 02:54 AM   #79836
Ever Onward
Time Killer
Oddometer: 857
Partially true.
At 6000 feet vs sea level, ALL fixed jet carburetors will make ANY engine run richer without changing anything. Ever note how back in the old carb days, cars and trucks chugging along at the top of Rocky Mountain national park were puffing raw black smoke out the tailpipe ? Usually the ones with license plates from down at sea level ?
The DR is jetted super lean from the factory to pass emmisions at sea level. If you take it up to say 6000 feet like that, it just like jetting richer by simply going up where the air is less dense.
For those with the factory jetting setting down at sea level, its so lean it "surges" at partial throttle openings. This in turn makes the engine ineffecient to a degree by not produceing steady power, I also suspect it makes the CV part of the carb overcompensate as it cycles through the surges.
When jetted richer, (just to the point of getting rid of the lean surge, not much if any richer) I think it may get it into the clean running power delivery area that makes the maximum fuel effeciency.
Remember, Im not changeing jet sizes....just a needle with a better taper and positioning. That and the proper adjustment of the low speed circut mixture screw.
Old 08-11-2013, 04:46 AM   #79837
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
Originally Posted by Low Budget View Post
Partially true.
Suspecting and guessing are how people learn about carbs,I think lots of people throw bigger jets in their DR carb based on what they read right here on this thread.
Bigger is better,more power just like supercharging almost.........
And lots of them spend many hours changing jets to get the bike jetted perfect for the sea level they live at,then a nice ride in the mountains means black smoke blowing out the pipe and a slow bike.
Yet others put 50,000 miles on a DR with out changing anything in the carb and it runs just fine.
Some folks like to mess with stuff till its fixed,even if it aint broken.
My stock DR starts easily in cold or hot weather,runs fine,warms up quick and gets great mileage,the 60+ mpg some get is hard to believe but I guess they have better gas then the swill they sell here in CA.
In the long run I can find way more fun things to do then jack around with the carb on a DR650.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 08-11-2013, 05:56 AM   #79838
epix1718
epix1718's Avatar
Oddometer: 729
For you guys running HID lights, do you have the issue of when you are cranking the bike the light sometimes will shut off? To turn it back on I just need to turn the ignition switch back off/on quickly (engine won't die, but does turn the light on).
I've even tried letting the HID light "warm" up where it is full brightness with the key set on accessory, but when I crank the engine over it sometimes will turn off/flicker. I'm using the stock H4 connector.
97 Suzuki DR650
2011 Ural Gear Up 2WD
98 Honda XR250R
85 Yamaha BIG Wheel 200 & 88 BIG Wheel 350
Travel Blog: http://peteandluna.wordpress.com/
epix1718 is offline   Reply With Quote
Old 08-11-2013, 06:19 AM   #79839
TrophyHunter
Oddometer: 2,263
Nope. I have PC's HID kit and never had a problem. I don't know enough about electrical to even suggest where to start.
'07 WR450 2013 HD Road King '73 Hodaka Wombat
TrophyHunter is offline   Reply With Quote
Old 08-11-2013, 06:20 AM   #79840
psmcd
Oddometer: 1,000
range & performance
I ride between 4,200' & 10,000 plus with stock carb, snorkel removed, with nary a problem. Initially I was disappointed it doesn't pull smoothly at a lower rpm but that seems to have improved. Maybe because I'm generally at 7 - 9k' when torquing up some hill too steep and rough for my gearing. Actually I get surprised that it keeps pulling and has never stalled when I half expect to while throttling down and threading rock gardens on a climb.
Mileage mostly comes in at 48 - 51 though I've seen as low as 44. Early in the game I picked up a used FCR but I'm not about to fiddle with that stuff the way it's running now. Eventually I'll install the mixture screw and an adjustable needle in the BST. If the FCR would give smoother pull at 500 rpm less that could warrant the effort but right now I'd rather use the time to ride than tinker.
If 55 to 60 mpg is attainable that would appeal for extended range though I've only hit reserve on one ride. For future desert rides the margin would be a plus but I don't need it on local rides.
psmcd is offline   Reply With Quote
Old 08-11-2013, 06:25 AM   #79841
Mambo Dave
Backyard Adventurer
Mambo Dave's Avatar
Oddometer: 5,789
I actually do live at 11 feet above sea level.
I bought the ProCycle jet kit, put the needle and the largest jet in, and have been happy up until the point at which I start considering fuel economy.
Now Don't get me wrong - none of what I did was the kit's fault. I chose the largest jet because I really am at sea level, and because I don't think I understood that I may not have needed it. I was just worried about being too lean while trying to push 90 MPH and droning on and on for highway commuting.
The bike runs great, and the original surging is gone, but now I'm wondering if I could go a main jet size smaller and pick up any better fuel economy (without any loss in power, nor with re-introducing surges).
Or do I have it wrong, and I could keep the larger jet (DG pipe, open airbox) and instead should go for one of the adjustable European spec DR needles?
"After reading through this thread I've come to the conclusion
that more people cruise the internet looking for reasons why
X bike won't work in Y scenario rather than actually riding
their motorcycles
RyanR
Mambo Dave is online now   Reply With Quote
Old 08-11-2013, 06:33 AM   #79842
TrophyHunter
Oddometer: 2,263
http://sandiego.craigslist.org/csd/mcy/3984700669.html
2001 GSXR pipe $100 Not Mine.....just cruzin' CL.
Old 08-11-2013, 06:44 AM   #79843
JTB488
Oddometer: 152
I'm using the HID kit from ProCycle, but using the Shorai battery and no issues so far. How is your battery??
JTB488 is offline   Reply With Quote
Old 08-11-2013, 06:55 AM   #79844
barko1
barko1
barko1's Avatar
Oddometer: 3,405
I have a cheap HID and it does the same. I just switch it from low to hi and that puts it on.
DR650, 98 Bimota SB6R, Kawasaki 14, 67 X-6 Scrambler (apart), SL350K1 (apart), 77 Goldwing 1000, Triumph Thunderbird Sport, Triumph Daytona Super III, DR650, MZ Skorpian Sport Cup, 71 Triumph Daytona 500, KDX220
barko1 is offline   Reply With Quote
Old 08-11-2013, 08:11 AM   #79845
vicster
Oddometer: 1,104
Yep. HID low beam in a BC Lynx. It's a PITA. What I've taken to doing is not making the first start of the day until the ballast has quit buzzing. I'll have to try the idea of just switching to the non HID high beam and back to low. Checking to make sure the light came on is now just part of the ritual.
vicster is offline   Reply With Quote
Times are GMT -7.   It's 01:17 PM.
