Old 05-04-2006, 09:58 PM   #1
Huber Tuber OP
Beer is good
Huber Tuber's Avatar
Oddometer: 166
Stalling and Cutting out?
Any one know about the 2005.5 stalling out or just dying while driving along? Any thoughts?
Remember you are unique and special, just like everyone else!
Some wise dude
748s
749s
R1200GS
R1150GS
Aprilia Tuono
KTM 950 Adventure
MV 750 Brutale
Huber Tuber is offline   Reply With Quote
Old 05-05-2006, 08:03 AM   #2
TipOver
TipOver's Avatar
Oddometer: 405
Idle speed?
Some things to check:
Check your idle speed first (1400 rpm Minimum). If that doesn't fix it check for fuel line routing (pinched, crimped). Following that check the carbs for fuel contamination in the idle & slow speed circuits, blow them out. A drop of water in a jet can cause great frustration. And no, that drop of water will not clear itself.
Do a search of the forum w/r to stalling, ect. Good Luck.
TipOver is offline   Reply With Quote
Old 05-05-2006, 09:00 AM   #3
Conner
Formerly everything
Conner's Avatar
Oddometer: 295
Electrical?
Mine used to cut out, then die. Turns out I had a short in the wire to the fuel pump. Fixed and problem solved.
Conner is online now   Reply With Quote
Old 10-28-2006, 05:02 PM   #4
950 Adventurer Nut
Lunatic
950 Adventurer Nut's Avatar
Oddometer: 94
I know if the choke is out or comes out after the bike has warmed up it will cut out.
950 Adventurer Nut is offline   Reply With Quote
Old 10-28-2006, 05:17 PM   #5
BLUE(UK)
BLUE(UK)'s Avatar
Oddometer: 3,404
Carb balancer pipe if you've recently had a service or any work done.
BLUE(UK) is offline   Reply With Quote
Old 10-28-2006, 08:55 PM   #6
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,107
If it happens when trying to acccelerate, too rich mixture!!
Whenever I turned the gas handle, while in idle, the motor died! The mix at the low rpms was too rich!!
Some have reported bad electrical connections to the battery, or fuel pump problems if submerging it occasionally...
Try to give us more hints!! Did you drop it before all these happened, did you have a wild riding weekend???
There is always a reason!!
gefr screwed with this post 07-16-2009 at 11:03 PM
Old 10-29-2006, 10:59 AM   #7
XsilverGS
Always on two wheels
XsilverGS's Avatar
Oddometer: 83
Send a message via Skype™ to XsilverGS
My 950 stopped cutting out / stalling once the needles were returned to the original positions, previous the needles were raised one as suggested by KTM when used with Akras.
With the needles in the standard position fuel economy improved and the bike has cutout once in about 4,000 miles, with needles raised it would stop without warning when the throttle was closed, at junctions or on down changes approaching hairpin bends etc.
XsilverGS is offline   Reply With Quote
Old 10-29-2006, 11:15 AM   #8
ephemeris
UYPL
ephemeris's Avatar
Oddometer: 663
Mine will stall at 2,000 rpm, somewhat intermittent and annoying in tight turn/transition situations.
Haven't figured it out yet.
Fuel and vent lines clear, canister gone, SAS capped, Akra's, stock main jets, needles at 3rd, 70 air correction jets, fuel screws at 1.25.
Runs very well though the range except it will hiccup and stall right at 2K rpm.
ephemeris is offline   Reply With Quote
Old 10-29-2006, 12:01 PM   #9
TipOver
TipOver's Avatar
Oddometer: 405
idle jetting?
Unles you increased the size of the idle jets the idle screw setting of 1.25 sounds like it may be lean unless you run high altitudes.
Old 10-29-2006, 12:03 PM   #10
APBlack
nOOb on a fly
APBlack's Avatar
Oddometer: 188
Interesting..Mine stalled alot up untill it's 600 mile service.. removed all the emissions crap, raised the needles and installed Akros and it has not stalled once in the last 1500 miles. makes me think there are other reasons maybe.
11 Husaberg FE570S
08 Husky SM610
06 KTM 950 Adv (orange one)
05 Honda 650L
APBlack is offline   Reply With Quote
Old 04-15-2007, 04:59 PM   #11
Katoomich
Oddometer: 3
950 adventure fueling
Tell me more about 950 adventure carb challenges. After a long minnesota winter, the bike lags & cuts out while accelerating off idle to perhaps 5500rpm. Feels like an air bleed is dirty causing poor fuel atomizing? Lots of exhaust popping. I have burned a couple tanks of fuel and no improvement. Time to take the carbs apart or?
Katoomich is offline   Reply With Quote
Old 04-15-2007, 07:21 PM   #12
drwet
Oddometer: 24
Thumb
I had the problem so bad the bike finally wouldn't run at all. Had it in at the dealer for eight months!!! Fortunately they were all winter months. KTM finaly sent their troubleshooter into town to check it out. Turns out there is a problem with some of the fuel tanks (mine is an 04). Aparently they react with some fuel additives and produce a precipitate which is variously described as a gel or slime or cobweb like substance. This stuff gums up the carbs and causes fuel starvation. KTM put new tanks on my bike and it runs better than it ever has.
drwet is offline   Reply With Quote
Old 04-15-2007, 07:39 PM   #13
woodsrider
woodsrider's Avatar
Oddometer: 587
Send a message via AIM to woodsrider
Keep us updated on what you find. Mine's doing something similar. It idles fine, but right off idle up to about 1/4 throttle it seems to be loading up. I figure the carbs got some gummy action going on over the winter. Maybe some clogged pilots?
2008 KTM 450 XCR-W
2008 KTM 690 Enduro
1997.5 KTM 200LE Jackpiner
'75 Bultaco 250 Alpina (M137)
woodsrider is offline   Reply With Quote
Old 05-02-2007, 07:22 PM   #14
Katoomich
Oddometer: 3
the answer, I think...
Old 05-02-2007, 07:30 PM   #15
Katoomich
Oddometer: 3
Well, It;s obvious I'm not computer savvy here. The Answer to my surging symptoms turned out to be fueling related. I found an almost sheet-rock dust like deposit or dried toothpaste-like deposit down the throat of both carbs. A tan colored film. It probably restricted the jets as well as the main off idle air bleed. Did the work myself and was amazed to recall just how jewell-like the throttle response can be on that bike. Backed the idle mix screws out 2 7/8 turns. life is good.
Times are GMT -7.   It's 02:51 PM.
