Old 05-05-2006, 07:56 AM   #1
Robin Webster OP
Robin Webster's Avatar
Oddometer: 241
O/E 990 Tank Protectors fit 950
I have been running with the H&B tank guards and they are very good but add more weight.
When the 990 came out it had large O/E tank protectors in plastic fitted as stock. We all know the carbon ones you can get are lovley but they are 130! ($220).
I bought the 990 ones and have fitted them to my 950.
GET THIS - THEY ARE 6.78, YES 6.78 EACH!! ($11.50)
They have an extra boss at the rear (near you're shin) which would attach to the 990 tank. Obviously the 950 does not have this and so it has to be removed. I used a hot wire but a Drimmel would be ideal.
Once I had removed this I added two holes underneath as the stock 950 small bummpers have three holes in them. One big one to attach the tank to the frame and two little ones to attach the bumper to the underside of the tank. The 990 ones do not have these so I drilled them.
I filled the hole left from removal of the rear boss with a 3/4" blind rubber grommet and it looks quite stock.
I also added a few strips of double sided stiky tape to tighten the fit a little front and rear.
The part numbers are 60107013050 L/H and R/H
Two tabs go under the (lower) fairing allen bolts and you will have to get longer ones of those (15mm)
Not as sexy as Carbon, nor I feel as durable but at the price very worth it and expendable. And they look stock!
Hope it helps someone!
Robin.
Robin Webster screwed with this post 05-05-2006 at 08:03 AM
Robin Webster is offline   Reply With Quote
Old 05-05-2006, 08:03 AM   #2
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,971
Very nice! Great usable info. Hope we can ge them in the US.
Thanks Robin
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 05-05-2006, 08:17 AM   #3
Mikas
Mikas's Avatar
Oddometer: 714
Very good info indeed! Thanks!
Mikas is offline   Reply With Quote
Old 05-05-2006, 08:49 AM   #4
jsrider
Oddometer: 3,495
Hopefully they provide more than $11.50 worth of protection. The H&B's, and the Carbon Performance carbon fiber guards, have proven themselves. Remember that a new tank is about $1200.
jsrider is offline   Reply With Quote
Old 05-05-2006, 09:42 AM   #5
Robin Webster OP
Oddometer: 241
I don't realy expect them to protect the tank in a big get off - they are just for those slow speed spills on trails that scratch the paint and scrape the tank. Also stone chips.
It might be that I refit the H&B's for later in the year, they may fit at the same time with a bit of modification, but the type of riding I'm doing at the moment I fancy less weight.
There are some enduros for large trail bikes which I fancy a go at. Fast fire roads, hill climes etc.
It's all just an experiment my life!
Robin
Old 05-05-2006, 10:34 AM   #6
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,470
Looks great. Nice write up and pics.
Is the whole thing the same thickness as the edge we can see here?
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is offline   Reply With Quote
Old 05-05-2006, 11:06 AM   #7
Foto Veloce
The Free Radical
Foto Veloce's Avatar
Oddometer: 376
Very cool. I have the KTM crash guards which I intend to keep, and was considering adding the carbon protectors too but this might be just what I need in combo with the crash guards.
Do you think if I roll into the local KTM dealer they can get these with the supplied part numbers or do they have restrictions like other manufactures that prevent the Euro parts from being ordered/sold in the US?
THX for the post!
'05 KTM Adventure
Foto Veloce is offline   Reply With Quote
Old 05-05-2006, 01:47 PM   #8
Robin Webster OP
Oddometer: 241
Yogoi,
I'd say pretty so, all the same thickness. My original small protectors took reasonable knocks and scrapes and I would imagine that these would be the same material and thikness.
The two extra bulges on the sides are hollow but stand proud of the surround so they would have to be ground down before you got to the tank.
For the price they are less to replace than getting your crah bars re stove enamelled.
Robin
Old 05-05-2006, 01:55 PM   #9
Robin Webster OP
Oddometer: 241
I don't know the situation in the states with that but I'd give it a try first.
Many of the retailers in the UK will do Mail Order so I'd look into that also. Do a internet search for Redline Motorcycles, Loughborough - Premier Bikes, Didcot or Fowlers of Bristol just to name a few.
By the time you add shipping it's up to you if they are worth it to you then(and your tank/paintwork!)
Failing that I'm sure you could chat up someone over the pond to get them for you and post on to you - not exactly financially risky!
Robin
P.S. you guys get Euro headlights so why not!
Robin Webster screwed with this post 05-05-2006 at 02:05 PM
Old 05-05-2006, 02:31 PM   #10
adventure950
Anglo-Saxon
Oddometer: 568
I also have fitted a set of these plastic 990 guards to my 950 to help cover the stone chips and minor scrapes, However I modified them the same as Robin but also removed the bottom bolt lug completely and have fitted the Hepco Becker bars back onto the bike over the new fitted plastics. The Hepco becker bars are far far stronger and better braced than the original bars and with the additional plastics offer good alround protection. If the bike is very badly damaged after a fall with this lot on I doubt I will be in a state to care cos it will probably be a big one anyway.
'A tourist sees what he went to see,
a traveller sees what he sees'
adventure950 is online now   Reply With Quote
Old 05-11-2006, 03:31 AM   #11
barbasma
100% CAROTONE
barbasma's Avatar
Oddometer: 1,821
good info!!!
"Dakar must be a race for few people, Dakar is a dream, the dream of the Rose Lake, if everybody finish it, the dream is over" Fabrizio Meoni
ciao Matteo
www.barbasma.smugmug.com
www.lc8.org
www.adventureschool.it
KTM 950 ADV S 2003 80.000 KM..... and gooooo...
barbasma is offline   Reply With Quote
Old 06-08-2006, 03:41 PM   #12
Misery Goat
Positating the negative
Misery Goat's Avatar
Oddometer: 75,173
can one get these in the states?
"So what you gonna do when the novelty is gone.."-- Joy Division
Same as it ever was
My Wanderlust
Misery Goat is offline   Reply With Quote
Old 06-09-2006, 04:55 AM   #13
Robin Webster OP
Oddometer: 241
See post 9.
Has any one from the good old usa managed to get any yet?
Robin.
Old 06-09-2006, 06:25 AM   #14
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,971
My dealer said he can't get them, they come up as unavailable. That seams odd that we can get the euro light but not these.
Old 06-28-2006, 04:51 AM   #15
Piipz
Oddometer: 131
Thumb
Hi.
May I correct those partnumbers.
60107013050 - Left side
60107113050 - Right side
They were 10 euros a piece from our dealer in Estonia and will arrive within a few weeks. Ill be using those with KTM original crash guards.
Thanks again for good information.
Piipz
Piipz is offline   Reply With Quote
Times are GMT -7.   It's 03:24 AM.
