Old 05-05-2006, 11:57 AM   #1
tucsonron OP
tucsonron's Avatar
Oddometer: 38
Complete 950 Tool & Parts List-TOURING
I'm looking for complete tool and parts list for touring. (bike related-not camping) Anybody have a well documented list of necessities/niceties for touring and extended touring both on-road and off?
tucsonron is offline   Reply With Quote
Old 05-05-2006, 12:45 PM   #2
Teckhardt
Teckhardt's Avatar
Oddometer: 323
If you look on the KTM site under Journey / Technic there is an interesting list. I am using this as my starting point.
Teckhardt is offline   Reply With Quote
Old 05-07-2006, 08:44 AM   #3
tucsonron OP
tucsonron's Avatar
Oddometer: 38
Thanks for the start. I'm suprised there isn't any other input to this question. I would think that there would be more help for preparedness since everyone here is supposed to be experienced offroaders and tourers. Maybe they all have sagwagons for their equipment.
Old 05-07-2006, 09:10 AM   #4
Tim McKittrick
Oddometer: 1,760
This is a nice list to start from-
http://www.micapeak.com/info/mclist.html
It's from the ibmwr site. There is a lot of other useful stuff there as well- try
http://www.ibmwr.org/faq-files/links.shtml
Tim McKittrick is offline   Reply With Quote
Old 05-07-2006, 01:32 PM   #5
tucsonron OP
tucsonron's Avatar
Oddometer: 38
I'm really looking for specific 950 tools and parts list. Everything else I'm good to go.
Old 05-07-2006, 02:54 PM   #6
kerhonky
Adventure Poser
Oddometer: 1,158
Not to rag on you too much, but it might have helped if you had mentioned that in your initial post, since neither your profile nor your signature indicate that you ride a 950.
You learn something new every day if you're not careful.
"When you have to shoot, shoot, don't talk."
Tuco Benedicto Pacifico Juan Maria Ramirez, otherwise known as "The Rat."
kerhonky is offline   Reply With Quote
Old 05-07-2006, 03:19 PM   #7
GaelicDog
Lesser of Two Weasels
GaelicDog's Avatar
Oddometer: 7,322
For each new bike purchase I go to the local Lowes or Home Depot and buy the basics.
(I am sure I will forget something here)
Multi purpose 4 in one screw driver.
Plier set: needle nose, small pliers and small wire cutters.
Zip ties.
Metric or SAE wrenches, low or medium grade. (this is a road side repair kit, why drop the big bucks when you got those at home, I only need in once)
Torx drivers as needed
Allen wrenches.
Can of spray paint that closely matches your bike. Close is good enough.
I start on the front of the bike and tighten EVERY nut, bolt, screw and fastener. This builds confidence and lets you learn the bike. As I use a tool I set it aside. Tools I do not use I add to my junk drawer. After I am through I add some paint to the tools that are going to stay with the bike and be bike specific. WHY carry shit you do not need and does not fit your bike?
I also keep a note pad close by for notes of specific tools I did not get on my first run, ie: nut drivers, maybe a few sockets and cheapo ratchet.
I add tire tools, patch or plug kit, a few wire connectors. I also wrap a few tools in electrical tape and duct tape (way carry the whole roll??)
A few years ago I started adding an LED headlamp and some extra AA batteries (midnight repairs suck)
Political Correctness is a doctrine fostered by a delusional, illogical, liberal minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end.
GaelicDog is offline   Reply With Quote
Old 05-07-2006, 04:37 PM   #8
ilmostro
Under Da Sea
ilmostro's Avatar
Oddometer: 29,256
Credit card, cell phone, flask of Woodfords. The rest is unnecessary weight.
I've got stay the fuck out of it written on a stone tablet in my bedroom. - Con Stapleton
ilmostro is offline   Reply With Quote
Old 05-07-2006, 05:50 PM   #9
Arch
Incurable Gearhead
Arch's Avatar
Oddometer: 11,705
Yea, might have been a good idea to mention that from the start. Otherwise, this wouldn't have been moved out of Orange Crush to begin with. I'll move it back and tweak the title.
Arch
Arch is offline   Reply With Quote
Old 05-07-2006, 11:17 PM   #10
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,480
The stock tool kit actually is very good. The only thing I could not do with the stock tool kit was pull the case oil plug. I have fixed the fuel pump, checked the sparkplugs, disasembled the stator, and fixed front and rear flats. Every thing is there except the tire Irons. Practice fixing a rear flat, it takes some know how.
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is offline   Reply With Quote
Old 05-07-2006, 11:30 PM   #11
taco
Guest
Oddometer: n/a
Thumb
Gak,condoms,one dollar bills,a phone with no signal and a buddy to pretend to know how to read the GPS and take you the wrong way.Thats all you can hope for.
Old 05-08-2006, 12:06 AM   #12
Louge
silence of the limbs
Louge's Avatar
Oddometer: 1,554
The tool kit lacks a 19mm main drain plug wrench (the right side screen works), 11mm brake bleed nipple wrench and 3mm windscreen wrench.
I carry 4" and 8" zip ties, 4mm tubes / tire repair kit and clip-on headlamp.
Just how deep do you believe?
Will you bite the hand that feeds?
Nine Inch Nails
Louge is offline   Reply With Quote
Old 05-08-2006, 04:19 AM   #13
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,214
Suprising room to store stuff
In my tool bay under the seat:
Stock tool kit
32mm 1/2 drive socket for axle nuts
Allen wrench assortment
3/8 drive socket assortment
3/8 drive ratchet
zip ties
emergency length of duct tape
tube patch kit
Cyclepump
epoxy sealer for tank and cases
small vice grip
In my KTM LC4 Tailbag side pocket:
1 HD 18" inner tube
3 tire irons
Cooper Tool bead breaker
tire guage
1/2" drive T bar
Headlamp flash light
plastic rain slicker for ground cloth or whatever
small cannister of WD40 (4 oz.?)
spare clutch lever
lighter
In my tank box:
Leatherman
Xtra fuses
Spare loaded flashcard for my GPS
In my front fairing:
Spare 21" HD inner tube
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 06-30-2006, 03:07 PM   #14
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,137
The Best Tools to Carry
I just want to ID what I think are a few of the best tools to add on any toolbox.
#1 the small 4" needle nose vise grips. These are the ultimate clamp, wire cutter, cable repair, universal open end tool. You can 'get by' using this over ten other tools. I've fixed a broken clutch cable and rode normally using these. I've fixed a broken shift lever by clamping this on to the remainder. You can clamp this on screwdrivers for more leverage. You can clamp broken parts back togather. Don't bother with other brands. Usually $9
#2 Malcom Smith (MS) brand 6-in-1 screwdriver. This looks like all the others, but Malcom had it made special. The sockets for the tips are 8 mm and 10 mm. Just right for most of the bolts. All other screw drivers have a 1/4" socket, not useful. It's only $10.
"Son, you can't do both"
Times are GMT -7.   It's 03:34 PM.
