Old 05-08-2006, 09:33 AM   #1
unaweep OP
Uses lotsa band-aids
unaweep's Avatar
Oddometer: 18,929
Bluhduh New 950 Rear brake pedal
Twisted my rear brake pedal like a pretzel last night when I highsided into a boulder on the trail. No crash. I tried beating the hell out of the brake pedal to reshape it- absent heat, I don't think it will conform. Any suggestions for an aftermarkwt brake pedal? I've pissed away 2 hours at work looking this am, but am unsuccessful.
unaweep is online now   Reply With Quote
Old 05-08-2006, 10:11 AM   #2
wsmc99
wsmc99's Avatar
Oddometer: 389
I think OEM is the only choice.
I tweaked mine a bit on a boulder but it easily bent back into shape after a little work with a vice and rag.
I'm thinking of buying a spare for the trail though!
wsmc99 is offline   Reply With Quote
Old 05-08-2006, 03:25 PM   #3
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,373
Would the standard offroad cable keeper setup that basically ties the brake pedal via braided steel cable to the frame have saved you on that particular get off ? That is one of the add ons I keep on the "to do" list.
2004 KTM 950 Adventure S
2007 Ducati 999S Parts Unlimited
2012 Ducati Multistrada 1200 Pikes Peak
Goss is offline   Reply With Quote
Old 05-08-2006, 03:50 PM   #4
unaweep OP
unaweep's Avatar
Oddometer: 18,929
cable keeper
Hi Goss. I'm not sure. I don't think I have seen the cable set up on a bike yet. On my bike, a rock caught the tip of the brake pedal and twisted it around under the peg. I was able to use a rock to get it out so I could ride home. Would the cable have prevented that???
Old 05-08-2006, 06:19 PM   #5
Goss
LC8 Adventurer
Goss's Avatar
Oddometer: 1,373
Probably. The cable ties off to a place in the frame then the other end loops thru a hole in the brake pedal or thru the pedal webbing itself. It is suppose to be slack enough to allow operation but not so long as to allow it to be caught by a stick or rock and bent out away from the bike. I think you can get a kit with the parts already together or I have seen some make their own with parts from the local hardware store. I bet one of our riders here or in the thumper section has an example they can show you.
Old 05-08-2006, 09:22 PM   #6
Louge
silence of the limbs
Louge's Avatar
Oddometer: 1,554
Pedals-R-Us
http://cgi.ebay.com/ebaymotors/NEW-K...spagenameZWDVW
Just how deep do you believe?
Will you bite the hand that feeds?
Nine Inch Nails
Louge is offline   Reply With Quote
Old 05-08-2006, 09:28 PM   #7
Pete156
I love to eat!
Pete156's Avatar
Oddometer: 1,440
Goss is correct . The cable may have saved the pedal. There are also circumstances in which no cable could save a lever and the high side you describe may be one. Is the OEM lever that pricey?
Pete156 is offline   Reply With Quote
Old 05-09-2006, 08:30 AM   #8
unaweep OP
unaweep's Avatar
Oddometer: 18,929
pricey pedal?
Don't know. I just bid 50.00 on ebay for the one suggested in this link. Thanks for the heads up.
Old 05-11-2006, 09:06 PM   #9
Katoum
Katoum's Avatar
Oddometer: 711
Goss have you found a suitable place to mount the cable, there is no frame there to mount cable to that I could see, and the cover plate is not strong enough, when I get my Touratech skidplate, I think it will provide a good mounting point. The 950 is my only bike that I have not mounted a brake snake to and I really miss it, saved me a lot of levers over the years.
Katoum is offline   Reply With Quote
Old 05-11-2006, 09:13 PM   #10
Louge
Louge's Avatar
Oddometer: 1,554
Some nOOb with zero feedback just took you out. Surely yer next bid at 10 seconds will send him back to the PW50 forum.
Nine Inch Nails
Old 05-12-2006, 12:02 AM   #11
soundasleeprecording
genuine pleather seating
soundasleeprecording's Avatar
Oddometer: 515
If you want to win anything on ebay - one word... esnipe.
www.esnipe.com do us a favor - don't tell everyone.
Ahhh, the internet, where all things go to die.
R1200ST and some expensive bicycles.
soundasleeprecording is offline   Reply With Quote
Old 05-12-2006, 10:20 AM   #12
unaweep OP
unaweep's Avatar
Oddometer: 18,929
Nice! I had planned on sniping him anyway. This just makes it easier.
Old 05-12-2006, 10:40 AM   #13
Chipper
Oddometer: 709
Folding brake tip
I saw one of these somewhere for 9fiddy, can't recall where. May save your new pedal from bending next time.
Chipper is offline   Reply With Quote
Old 07-20-2014, 02:07 PM   #14
pingvin
pingvin's Avatar
Oddometer: 504
Just bought a SE so scanning through the Orange Crush Thread Index and Links thread to check what to do with the bike.
Anyway, know seriously old thread but Touratech got a folding lever (ref above post), http://shop.touratech.com/vehicle-eq...-1190-adv.html. 950 not mentioned but had this from the 690 just sold and it fit and works just fine on the SE OEM lever.
Also bigger than OE so nice and simple upgrade.
2006 KTM 950 SuperEnduro
2010 KTM 530 EXC-R
2006 Suzuki RM-Z 250
1981 Husqvarna 420 AE
pingvin is online now   Reply With Quote
Old 07-21-2014, 01:25 PM   #15
Colorado Uli
Motociclista Non Elegante
Colorado Uli's Avatar
Oddometer: 2,550
I used the TT pedal for a little while, but it didn't stand up to the challange. Once bent and cracked, I tossed it onto the same pile as old copies of Dianetics and then proceeded to put the OEM pedal back on. Happy relation with my break since then.
Just my two pfennige.
Something, something, something ... in latin.
"Now with more SE then ever!"
Das KTM520
2004 KTM 625 SXC - Sick. Getting better
Colorado Uli is offline   Reply With Quote
Times are GMT -7.   It's 04:25 PM.
