Old 05-09-2006, 10:18 AM   #1
Freedomrider OP
B Wall
Freedomrider's Avatar
Oddometer: 66
Send a message via Yahoo to Freedomrider
K&N Air Filters
I read little bits about people modifying the airbox. I was wondering if anyone had tried using two K&N air filters and dust covers instead of the large flat stock filter. I was thinking of going this route. K&N basicly said they could do it knowing the flange measurements. I was thinking the pipe, more air, and some jetting adjustment would bring out some more ponies. What do ya all think? Is this a good way to go? I am a little hesitant to start cutting into the airbox.
Freedomrider is offline   Reply With Quote
Old 05-09-2006, 06:39 PM   #2
Autostream
Gravity flailer
Autostream's Avatar
Oddometer: 5,828
Biggest increase will be in noise from the intake.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 05-09-2006, 07:03 PM   #3
teabagger
teabagger's Avatar
Oddometer: 279
Wink Air filters
See the lengthy previous thread on this topic..The DNA filter especially with the Sommer airbox mods will flow a LOT more air & yes, make a LOT mor intake noise, and also allow much faster revving, better idle, less stalling, easier starting, better response, and of course, more peak HP....
You will need bigger mains and so on, to compensate for all the extra air, but, it's all good.
JM
LA, CA
teabagger is offline   Reply With Quote
Old 05-10-2006, 10:03 AM   #4
K2m
....58....
K2m's Avatar
Oddometer: 2,238
better idle, .......Says Who?
less stalling,...... Less than Zero ?????????????????????????
easier starting,...... Mmmmmm Less vacuum........ Don't think so
better response,....... "As Above" ..........Definitely not !!!!!!
and of course, more peak HP.... Lost performance, but :- more peak HP Then you can go around and tell everybody that their 950 is fucked.
If you want to stick K&N pods on you should consider some non CV carbs
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Times are GMT -7.   It's 08:40 PM.
