Old 05-09-2006, 07:52 PM   #1
mross OP
Oddometer: 124
Question SAS Removal Alternative
Bought my 05 a couple of months ago and have been reviewing the extremely helpful information on this site.
I Installed FMF mufflers and am in the process of re-jetting and thought why not do the SAS removal since the bike was apart? After looking at the threads on this subject and looking at how the system is designed, it seems like plugging the large hose that goes from the reed valves to the valve on the back of the air box would accomplish the same thing without all of the hassle. Others have suggested plugging the individual inlets to the reed valves but it seems to me that I could accomplish the same thing with one plug and all of the components would be there if I had to reconnect it. I just want to stop the airflow into the exhaust ports. I know I would still have all of the clutter but this is not a problem for me. Is there any reason this would not work?
mross is offline   Reply With Quote
Old 05-09-2006, 08:48 PM   #2
Orangetwin411
Katoom Rider
Orangetwin411's Avatar
Oddometer: 292
I believe most here would agree with you, plugging the hose basically accomplishes the same task. Only downside,as you stated, is that you still have the clutter. My evap can is a gonner but the SAS is still intact until I have the first service done, after that I plan on removing the SAS one way or another and then work on the jetting.
Scott W.
2002 KTM 380 SX
2005 KTM 300 MXC
2005 Kawasaki V2K Ltd
2005 KTM 525 SX
2007 KTM 950R
http://bigsaint.smugmug.com/
Orangetwin411 is offline   Reply With Quote
Old 05-09-2006, 09:34 PM   #3
Autostream
Autostream's Avatar
Oddometer: 5,833
All you need to do to make it inoperative is remove & plug the small vacuum hose on the valve behind the airbox. Leaves the clutter but stops it working.
You only need two tools in life: WD-40 and Duct Tape.
If it doesn't move and should use the WD-40, if it moves and shouldn't, use the Duct Tape.
Autostream is offline   Reply With Quote
Old 10-24-2006, 10:41 AM   #4
radiowazee
Golewahz???
radiowazee's Avatar
Oddometer: 421
Anyone have a pic of said vacuum hose? Behind the airbox? Can I get to it from under the seat?
When I'm not rockin' @ radio.wazee I'm screamin' around Denver on my:
- 2006 KTM 950 LC8 Adventure-S GO!!!!!!! **Sold**
- 2003 BMW K1200RS **Sold**
RALLY PAN-AM RIFF RAFF '08, '09, '10 EXTREME Member
radiowazee is offline   Reply With Quote
Old 10-24-2006, 04:19 PM   #5
TipOver
TipOver's Avatar
Oddometer: 405
Right side vacuum ports
When the right side of the airbox and engine are revealed (remove right fairing & tank) you will note two brass barbs on the intake manifolds (there are 2 on each manifold, 1 on each side). One of these is the vacuum port that controls the rear valve for the SAS. The other goes to a blind plug on the same valve.. Retain both lines, just plug the line to the valve with a suitable machine screw & clamp. These lines are the ones used to balance the carbs so don't remove them, just make sure they are plugged & secure.
Have Fun
TipOver is offline   Reply With Quote
Old 10-24-2006, 04:32 PM   #6
scottr
scottr's Avatar
Location: Pedernales R., Tx Hill Country (Ihadthisavatar1st)
Oddometer: 1,768
Talking
I dunno. It sure warmed my heart to see that big pile a crap lying dead on the shop floor at my first service. Bike runs so nice without it. Take it off. Take it all off.
scottr is offline   Reply With Quote
Old 10-24-2006, 06:25 PM   #7
Motobee
Oddometer: 73
Plugging the vacuum hose doesn't stop it from working, it will make it work all the time. The vacuum signal to the valve shuts off the flow of air to the exhaust under high vacuum condtions (decelleration) to prevent backfires.
If you just plug the vacuum hose, the system will work all the time and you will have backfiring on decell.
Brian
Motobee is offline   Reply With Quote
Old 10-24-2006, 06:26 PM   #8
Wado
Oddometer: 13
Saw no reason to keep all that stuff, so I scrapped it all on first service no SAS no Cannister. My only issue with my bike was the sketchy carburation, and now its sweet like it should have been out of the box...
Wado is offline   Reply With Quote
Old 10-24-2006, 07:21 PM   #9
scottr
scottr's Avatar
Oddometer: 1,768
Talking
Wado wise .... for n00b.
Old 10-24-2006, 08:40 PM   #10
APBlack
nOOb on a fly
APBlack's Avatar
Oddometer: 209
Yep.
First service all went bye bye.
I don't even remember what it looked like.
loose that stuff and make room for Farkles!!!!
13 KTM 990 Adv Baja
11 Husaberg FE570S Swedish hotness
08 Husky SM610.. gone
06 KTM 950 Adv (orange one).. gone.. damit
05 Honda 650L.. gone
APBlack is offline   Reply With Quote
Old 10-24-2006, 08:45 PM   #11
jsrider
Oddometer: 3,495
+1. It's easy, too, with one exception: getting the blanking plate onto the front cylinder without removing the oil tank is an effing PITA. It helps a little if you remove oil tank bolts, but you still should make sure the kids are in bed so they don't learn the f-word from you, or get hit in the head by a flying wrench.
jsrider is offline   Reply With Quote
Old 10-24-2006, 09:40 PM   #12
mross OP
Oddometer: 124
Response
I started this thread and in a subsequent response to another thread said that just plugging the one line did not work. You need to disconnect the valve from the air box and plug both sides in order to render the system inoperative. The reasons to do this as opposed to taking everything off are:
1. Ease of completing the task.
2. Being able to re-assemble the system if you have to satisfy future govt. mandates.
I live in the peoples republic of California and cannot predict what the California Air Resources Board may mandate re. emissions requirements for the resale of motorcycles.
Plus it is a lot of work to take everything off, plug etc when you can do it in about 5 minutes if you go the alternative route mentioned.
Old 10-25-2006, 05:56 AM   #13
Reformed DucFlogger
Inventor Of The Wheel Mk2
Reformed DucFlogger's Avatar
Oddometer: 1,445
Plug
I simply epoxied a penny over the inlet of the SAS system of my '05 640A - jetting with taht !@#$ system in place is impossible. Simply too much cold air being injected into the exhaust manifold. I thought of removing the clutter, but decided that the route I chose was better. While I have an xtra x ounces of weight on board, I also only have 1 vacum post modifictaion to worry about vs. almost 1/2 dozen if I'f removed the system.
"...who gives a rat fornication?"
Reformed DucFlogger is offline   Reply With Quote
Old 10-25-2006, 08:41 AM   #14
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,976
I just put FMF's on my 950 also, and as a this is my daily driver I do not have time right now to tackle the SAS removal job. I'll wait until there is a very cold snow spell. Any pics of this quick, temp fix would be greatly appreciated.
thanks
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 10-25-2006, 10:45 AM   #15
Reformed DucFlogger
Oddometer: 1,445
Fix
Too lazy to remove cowl to take pics, but:
1. The system operates by a valve that is controlled by engine vacum. It is designed feed O2 into the exhaust to keep the cat converter happy and to make sure all the tree hugging wankers smile those naive left wing grins of idealism when staring at their emissions testing gear.
The system CAUSES backfires and decel pops (that you hear with a thinner walled more straight thur aftermarket slipon vs the hunks of baffled sewer pipe most bikes come with for exhuast systems these days) thru injecting a sudden volume of air into a hot manifold 'full' of unburned dead dinos.
When open the valve allows fresh air to be sucked in thru a filtered air inlet thru the valve into the exhaust manifold (plural on the 950?). You could use the SAS/SLS system diagram in the repair manual to find the air inlet, but if it's anything like the 640A the air inlet is a rubber hose that terminates thru a large rubber grommet in the downtube on the rhs of the bike frame. Simply yank the hose/grommet out. On the end you should find a small black plastic cylinder with a metal screened inlet. That is the air inlet for the entire system.
I simply took a penny, lathered it with 5 min epoxy and secured it over the inlet port. the next day, reinserted the hose/inlet into the downtube, pushed in the grommet and end of story. KTM-Sommer sells a virtually free plastic or alu plug you can use to snap in place of the inlet filter, but the shipping cost to NA would cost far more than the unit is worth.
With this plugged and an aftermarket slipon, you will notice an improvement in idle smoothness and no more backfiring and popping on decel. You can now tweak your jetting without cursing the sillyservants at the EPA and EU. To test the improvement you see, tweak the throttle of a running bike with the air inlet as is and then with your thumb over it. It does no harm to the system, no vacum leaks to worry about, etc, etc. It is also easy to switch back when the testers come calling or upon resale to the enviromentally conscious.
KTM Sommer has a 'Tip" in their catalog that shows the plugging process. It may differ somewhat for a 950, but the basic operation should be the same.
Reformed DucFlogger screwed with this post 10-25-2006 at 11:01 AM
Times are GMT -7.   It's 05:27 PM.
