05-11-2006, 09:06 PM
#1 |
Oddometer: 56
The truly EXCESSIVE KTM tool kit
This winter I did a COMPLETE engine tear down. Split the cases. I tried to just use the tools I had put together for my bikes tool kit. I go overboard on the tools I keep on my bike. Anyway here is the list of everything you
need to tear apart your engine -- and how to carry it all INSIDE of your bike. KTM TOOL BAG (for under the seat tool space) 1/4" hex bit driver (Slim handle and just the width of tool box) 3/8" rachet (S&K -- because the round handle fits snugly in the KTM spark plug extension pieces. It is just the width of the tool box, but with extensions I have about a 15" leverage handle -- and can add to that for about 30 inches of leverage with a tire iron from my tire wizard. It worked for me.) KTM pliers Small pair of side cutter pliers KTM spark plug socket, extension and handle KTM allen wrench T nandle and KTM hex extension (6 mm) stubby 14 mm combination end wrench 3/32" drift KTM allen wrenches (5 and 8 mm) mini needle nose vise grips 1/4" socket extension 3/8" socket extension KTM wrenches (8x10 and 10x13) 2 Large KTM wrenches for axle removal (27mm and 19?? mm) full set of socket reducers and expanders (1/4 to 3/8 -- 3/8 to 1/2 -- 1/2 to 3/8 -- 3/8 to 1/4) ************************************************** *************************** PLASTIC SOCKET BOX (Small Sucrets cough drop box worked GREAT - holds 28 items) (This fits under the seat in the tool space) 1/4" hex bits include 3 mm allen 4 mm allen 5 mm allen 6 mm allen 8 mm allen narrow slot screwdriver wide slot screwdriver #1 philips #2 philips T25 torx adaptor for 1/4" square drive Sockets include 19 mm 17 mm 14 mm 13 mm 12 mm 10 mm 8 mm 7 mm 6 mm Adaptor from 3/8 square to 1/4 inch hex drive KTM sockets include (driven by 6 mm T handle) 6 mm 8 mm 10 mm A 3 cm length of 14 mm allen wrench (driven with 14 mm socket) A 3 cm length of 10 mm allen wrench (driven with 10 mm socket) Small button magnet with keeper ************************************************** *************************** OTHER ITEMS UNDER THE SEAT Electric air compressor (Cycle pump) Tire gauge Credit card multimeter Leatherman wave multitool (has knife, scissors, and needle nose pliers) In the slot under the seat is the KTM extension for the large KTM wrenches ************************************************** *************************** UNDER THE REAR FENDER Using some hose clamps I have a Tire wizard bead breaker/tire irons attached to the rear sub frame. I have broken the front and rear beads with this tool. ************************************************** *************************** LEFT FRONT SIDE PANEL (Removed the charcoal canister and built a tool box) Small Butane torch (Cost 4 or 5 dollars. Can solder or heat something) solder Small epoxy kit Extra bolt assortment (10 bolts with nuts and washers) Spare tube (21" tube -- can put in back in real emergency) Tube patch kit KTM Engine blocking bolt A small feeler gauge set (with sizes needed to adjust the valves) Small roll of Electrical tape Extra clutch lever (actually an already broken one, but usable in a pinch) ************************************************** *************************** RIGHT FRONT SIDE PANEL (Built tool box after removal of charcoal canister) 15' nylon tow strap 12' roll of mechanics wire 12' roll of electrical wire aluminum space blanket chain saw (about 16 inches of light chain saw) 27 mm socket (fits the swingarm bolt) 30 mm socket (engine internals) 32 mm socket (engine internals) M20 bolt with 1.5 pitch threads (fine). 20 mm long (generator removal) 13 mm crows foot (used on the cylinder head nuts) 1/4 drive universal wobbler (just makes life easier in 1 or 2 tight spots) ************************************************** *************************** 'GLOVE BOX' in between tanks Really bright LED head lamp. 4 or 5 zip ties A few first aid kit items. ************************************************** *************************** ************************************************** *************************** ************************************************** *************************** ************************************************** *************************** TOOLS REQUIRED TO DISSASSEMBLE AND REASSEMBLE THE ENGINE THAT ARE NOT ON BIKE Impact wrench Large torque wrench Small torque wrench rubber mallet circlip pliers ************************************************** *************************** COMMENTS I really did do a COMPLETE tear down of my engine. I hit a rock hard enough that I put a hairline crack in the left engine case, and also had the main case gasket leaking. Using just the tools listed above, I was able to split the engine, and put it all back together again. I didn't pull the transmission shafts out, but I was looking at them and it would have been another 3 or 4 minutes. Note that ALL this stuff is INSIDE the bike. There is no tool bag on the rear fender or anywhere else. The tool box under the seat is REALLY big if you choose your tools right. After a canisterectomy, some work, good plastic pieces and plastic welding on the inside converts the side panels into capacious storage spots. Great spot for a spare tube even without any work. 1) These 4 tools are REALLY excessive. Only needed if you want to dissemble your engine. Of course, if you were in some really out of the way place, I bet you could find a tire shop with an impact wrench and rubber mallet, but much less likely to find these 4 tools. I only put these items in after I dissembled my engine. I might take them out since they are kind of heavy. There was PLENTY of space though. The T25 torx bit (holds bearings inside engine) The 32 mm socket The 30 mm socket (although this is needed for the clutch pack) M20 bolt for pulling the alternator 2) Tools and other items that might get added to make the tool kit __REALLY EXCESSIVE__. The left side panel tool bin has lots of space left :) The circlip pliers A small chain breaker and press A master link and 3 or 4 links of chain Water pump shaft, seal, and circlips Spare o-ring for the clutch. Set of valve shims (just one in each size would take MINIMAL size and weight) The clutch o-ring and water pump seem to be the only real problems with the LC8 engine. Small and light to carry. Much lighter than the rotor and diode boards I saw lots of BMW airhead riders carry around. 3) I have replaced several otiker clamps on the oil lines and coolant lines with reusable stainless steel clamps. 4) Tricks in the tear down with these tools. I wired the clutch hub to keep it from turning when I was removing the bolt that holds it. Make sure the mechanics wire is small enough to fit through the holes in the hub for this to work. For a garage tool, I would order the special tool before I did this again. Getting enough wires on to hold a nut tightened to 200NM took 35-40 minutes. The special tool would take about 35 seconds. My tire wizard tire irons were good to drive out the pivot arm bolt in the swing arm. I suspect most tire irons would be too big of diameter or not long enough. I LIKE my tire wizard. Timing is EASY to set on the KTM if you have a bright light and remove the engine blocking bolt so you can look for the indents on the crankshaft counterweight. Get the official KTM engine blocking bolt. It is cheap, and really works well. 5) Not yet on the KTM, but on my R100GS that I have had for 16 years, I've done all sorts of crazy repairs in motel parking lots. opened transmission cases, replaced bearings (pivot,paralever,steering head), lots of other stuff. So far the KTM is WAY better about not breaking. If I had not put the crack in my engine case, it would have been nothing but owners manual maintenance in 17,000 miles. Wendell |
05-11-2006, 10:18 PM
#2 |
Oddometer: 711
Excellant report, lots of great info, thanks for taking the time to share with us.
Cheers, Katoum
08 KTM 530 EXCR 2011 1200 Super Tenere (ordered) Katoum screwed with this post 05-12-2006 at 07:36 AM |
05-11-2006, 10:39 PM
#3 |
SUA* SPONTE
Oddometer: 149
Outstanding
I see you only have 53 posts. I guess this is just proof that you do not need 10,000 post's to provide excellent information. Thank you Duncan, for your time and effort.
Powerslider powerslider screwed with this post 05-11-2006 at 10:50 PM |
05-11-2006, 11:33 PM
#4 |
100% CAROTONE
good info!!!
"Dakar must be a race for few people, Dakar is a dream, the dream of the Rose Lake, if everybody finish it, the dream is over" Fabrizio Meoni ciao Matteo www.barbasma.smugmug.com www.lc8.org www.adventureschool.it KTM 950 ADV S 2003 80.000 KM..... and gooooo... |
05-12-2006, 02:11 AM
#5 |
READZ
Oddometer: 81
all I can say is BLOODY HELL very impressive report, your obviously a serious Adventure Rider. Thanks for all the information, I have saved it in my KTM file just in case I ever get round to doing that proper journey (one day). Would love to see a few pics of your modifications.
Many thanks Joe
The future is bright – the future is ORANGE J |
05-12-2006, 09:06 AM
#6 |
Ancien
Oddometer: 16,346
The large flat area under the seat is perfect for tools also. Get some closed cell foam and carve outlines in it of the tools you want to carry there.
05-12-2006, 09:20 AM
#7 |
Oddometer: 1,405
So sorry
Too bad you have to carry that many tools when you ride your KTM.
Socialism works good until you run out of other people's money to spend.
05-12-2006, 09:50 AM
#8 | |
Ancien
Oddometer: 16,346
05-12-2006, 02:19 PM
#9 | |
Bazinga!
Oddometer: 11,660
Great report. Pic's please? Especially the tools stored in the side panels?
Dave
dunno..... |
05-12-2006, 02:35 PM
#10 |
Oddometer: 3,162
Damn fine job, Wendell!
For the folks that don't know, Mr. Duncan has been of tremendous service to those of us who worked on our own airheads. He's done it quietly and modestly and effectively, and I'm really really glad he got a 950. Perhaps I should make it policy always to own the same kind of bike as he. As in the past, thank you, sir. |
05-12-2006, 03:56 PM
#11 |
Just killing time
Oddometer: 2,083
Well done, thanks (I only did posted this to get my post count up)
06-25-2006, 03:25 PM
#12 |
Old Git
he he he
tis a nice tool kit u got
White pig |
06-25-2006, 03:51 PM
#13 | |
Ancien
Oddometer: 16,346
06-25-2006, 07:09 PM
#14 | |
Bazinga!
Oddometer: 11,660
dunno..... |
06-25-2006, 07:32 PM
#15 | |
Oddometer: 178
