Old 05-15-2006, 07:13 PM   #1
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
how do I know if i have a burnt valve
What are signs of a burnt valve?
When i took off the cover, one "chamber" is clean as a whistle (the back one...intake) and the exhaust is...well, charred kinda. Like a little soot in there.
The pushrod-rocker arm gap was pretty good, no major adjustments.
Just wondering.
thx.
datchew is offline   Reply With Quote
Old 05-15-2006, 08:39 PM   #2
R-dubb
Dubbious Adventurer
R-dubb's Avatar
Oddometer: 4,855
Not a problem. Just like comparing inside a carburetor to inside an exhaust pipe. One clean, the other dirty. Signs of a burned valve will be ragged edges and low compression readings, out of balance running on a twin, hard starting (or more likely no starting) on a single. Very unlikey based on what you describe.
R-dubb screwed with this post 05-15-2006 at 08:49 PM
R-dubb is offline   Reply With Quote
Old 05-15-2006, 08:54 PM   #3
RocketJ
Oddometer: 674
On the exhaust side, the oil gets hotter and, I think the word is carbonizes. No big deal, maybe bad if it doesn't.
Probably the first thing you would notice on an airhead is the exhaust valve clearances would be tighter each time they are checked/adjusted. In my experience the next would be high rpm missing/backfiring. They don't so much burn as receide. The seat just disappears. I have a good example of which I will take some pictures tommorrow if anyone wants.
RocketJ is offline   Reply With Quote
Old 05-15-2006, 09:19 PM   #4
Hltoppr
GS Adventurer
Hltoppr's Avatar
Oddometer: 504
I found out mine were fried when I did a compression test and came up with 50 psi in one cylinder and 20 in the other, pulled the heads and yup...toasty.
Symptoms were stalling at idle. Adjusting the carbs was next to impossible and did not cure the problem.
....new heads with valves, guides, seats and springs should cure the issue...sitting atop a rebuilt engine and new cylinders is nice too...
-H-
Quamquam ridentem dicere verum quid vetat?
-Horace, Satires 1
2003 BMW R1150GS Adventure
Hltoppr is offline   Reply With Quote
Old 05-15-2006, 09:42 PM   #5
hogmolly
Dude
hogmolly's Avatar
Oddometer: 3,142
thx.
A warped or cracked valve face. Low compression without oil consumption.
10 FLHCUSE-BLK, 09 FXDL, 08 FXDWG, 98 FLHR, 07 R1200GS Adv, 95 R100GSPD Classic, 93 R100GSPD, 92 CB750
hogmolly is offline   Reply With Quote
Old 05-15-2006, 09:47 PM   #6
Mugwest
Mugwest's Avatar
Oddometer: 6,343
Dat: go for a compression test, it'll tell you a few things. Just disable the electronic ignition first 'cause you have to spin her over w/ the plugg leads disconnected of course-- can't fire the ign ungrounded on these
check Haynes, Snowbum etc for proc
you mentioned having a VW 1600cc, you prolly already have a tester-- if not i've had fine results with the Sears unit. Has the correct spark plug thread adapter, and a good quick-release fitting
Mugwest is offline   Reply With Quote
Old 05-15-2006, 11:46 PM   #7
LoFlow
Oddometer: 990
How about a leak down checker. This just pumps air into your cylinder (while on top dead center) through the spark plug hole and measurer's the percentage of air escaping. If I recall it should be no more than 10 percent.
If you have a large amount of leakage you can hear it out the exhaust...exhaust valve, or carb...intake valve, or oil fill cap...compression rings. Just another way to diagnose a problem. I think you could probably rent one. A little expensive to buy from Snap On. bye
LoFlow is offline   Reply With Quote
Old 05-16-2006, 05:43 AM   #8
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
thanks guys.
Feel better.
Mug, my 66 bug is a 1300cc. Just don't remember it being that dirty on the exhaust side, but... (shrug)
RocketJ I would like some pics if you get a chance.
I've done leakdown checks on more modern cars (my 85 318i) but i borrowed the tools. Mebbe i'll invest in the tool you mentioned from sears.
thx all.
Old 05-16-2006, 07:10 AM   #9
Mugwest
Mugwest's Avatar
Oddometer: 6,343
here's the one i've used for years:
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
but these days you can get well-made examples many places-- like all Pet-Boys, Advance, etc. If you like to give yr bizness to WallaceWorld they probably have it for $2 less than anywhere else.
Old 05-16-2006, 11:48 AM   #10
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
sears has been good to me. i'll probly pick up one of those.
thanks for the link.
Appreciate all the help guys.
Old 05-16-2006, 05:30 PM   #11
RocketJ
Oddometer: 674
If the top one looks like your discoloration, no worries.
[IMG][/IMG]
If your exhaust valves look like this, worry.
[IMG][img=http://img49.imageshack.us/img49/1765/1230057hz.jpg][/IMG]
Old 05-16-2006, 06:23 PM   #12
RocketJ
Oddometer: 674
valve recession
First one didn't take.
[IMG][/IMG]
Old 05-16-2006, 06:30 PM   #13
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
I didnt' take the heads off to look at the back like that.
However, mine is a bit darker. Going from performance issues that you guys said would arise if i had valve problems, I think i'm good to go.
I'm not sure what i'm looking at on the second picture.
I mean... i'm not sure what part of the picture shows damage.
Old 05-16-2006, 08:34 PM   #14
RocketJ
Oddometer: 674
The exhaust valve, on the right. should be flush, like the intake. This one has recessed about 4mm. You should not be able to see any seat around the valve.
Old 05-17-2006, 05:18 AM   #15
datchew OP
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
oh, i see it now. thanks.
sheesh that ain't good.
Times are GMT -7.   It's 04:30 AM.
