Old 08-23-2007, 03:48 PM   #46
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,553
Originally Posted by overlandr
Bumping this 'cos it needs to be turned over once i a while.
Good idea, all the inmates who have posted in this thread way back should go & update their mileages & info too.
40 000 km & still crankin'
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 08-29-2007, 11:36 PM   #47
searchin oz
Sand, Gimme more sand
searchin oz's Avatar
Oddometer: 1,169
1. Bike: 640 Adventure
2. Year: 2006
3. Bought used or new: Used
4. Current mileage: 11500km
5. Modifications done: Staintune exhaust, High front gaurd, Heated hand grips, Fork bleeders, Rim pins, Low octane fuel switch, GPS.
6. Mechanical work done: Replaced a few oil seals and RH sight glass
7. Upgrades done: see #5
8. Current tires on the bike: Michelin Desert front and Baja rear
9. Percentage of road versus dirt use: 1% road, 99% dirt
10. Would you buy another one?: ???
11. Did you replace the main shaft bearing (if applicable): Is there a problem?
12. Pic of the bike if available:
searchin oz is offline   Reply With Quote
Old 08-30-2007, 01:52 AM   #48
gen
gen's Avatar
Oddometer: 804
1. Bike: LC4 Supermoto Prestige
2. Year: 2003
3. Bought used or new: used
4. Current mileage: ~8300 km
5. Modifications done: KTM Comfort Seat, KTM rack, Givi carrier & box, Ego Barkbuster handguards
6. Mechanical work done: none
7. Upgrades done: none
8. Current tires on the bike: Pirelli Scorpion Sync
9. Percentage of road versus dirt use: 100% road
10. Would you buy another one?: would like to try the 690
11. Did you replace the main shaft bearing (if applicable): unsure
DoD#1458
gen screwed with this post 09-02-2007 at 06:50 AM
gen is offline   Reply With Quote
Old 08-31-2007, 08:52 AM   #49
alpiv
Sr. nOOb
alpiv's Avatar
Oddometer: 2,173
1. Bike: 640 Adv
2. Year: 2003
3. Bought used or new: Used Summer 2006
4. Current mileage: PO Had 4,00 miles on it. I've put on 7000 = 11,000
  1. 41MM FCR Carb
  2. MXTech suspension tuning for my weight 220lbs
  3. Renazco Racing Seat...Ordering soon.
  1. Sprocket Seal/O-ring
  2. Clutch Cover Looking glass replacement.
  3. Fork Seals Synergys
8. Current tires on the bike: MEFO
9. Percentage of road versus dirt use: 40% Road and 60% Dirt/gravel/two track.
10. Would you buy another one?: Yes, yet waiting on the 690.
11. Did you replace the main shaft bearing (if applicable): N/A
Colorado
Michigan:
Wisconsin
alpiv screwed with this post 08-31-2007 at 09:08 AM
alpiv is offline   Reply With Quote
Old 08-31-2007, 10:16 AM   #50
dorkpunch
Oops...
dorkpunch's Avatar
Oddometer: 5,361
1. Bike: LC4E
2. Year: 2002
3. Bought used or new: Used, with about 5,000 miles on it
4. Current mileage: About 8,900 miles
5. Modifications done: Cored exhaust, 147.5 main jet, trail tech vapor computer, cyclops headlight, LED signals, comfort seat, happy trails rack with pelican cases, the "pretty" front fender, new plastics, going to be doing the air box mod.
6. Mechanical work done: Just the general maintenance- oil changes, sprockets, tires, etc. Havent had to fix anything else.
7. Upgrades done: See #5.
8. Current tires on the bike: Pirelli MT21's
9. Percentage of road versus dirt use: 60% road 40% off
10. Would you buy another one?: HECK YEAH! I dont think i'll need to though...
11. Did you replace the main shaft bearing (if applicable): Nope.
http://www.mobilemrt.com http://www.dorkpunch.com
"I've been going to this high school for SEVEN YEARS. I'm no dummy!"
-Charles De Mar.
dorkpunch is offline   Reply With Quote
Old 08-31-2007, 01:18 PM   #51
txrider
txrider's Avatar
Oddometer: 370
1. Bike:620 RXC
2. Year:1996
3. Bought used or new:New
4. Current mileage:~8000
5. Modifications done:Temp guages
6. Mechanical work done:Regular Maint
7. Upgrades done:Tail rack, forks, triple clamp
8. Current tires on the bike:TKC 80's
9. Percentage of road versus dirt use: 50/50
10. Would you buy another one?: Already did
This bike is for sale over in the flea market section.....
1. Bike:625 SXC
2. Year:2004
3. Bought used or new:Used with 278 miles on it
4. Current mileage:~10,000
5. Modifications done: Tail rack, KTM Dual sport kit, 18L tank, Renazco seat, Fork seal skinz, HID lights, rear disk fin, steel sprockets...
6. Mechanical work done:Normal Maintenance
7. Upgrades done:Motard wheels, swap on and off
8. Current tires on the bikeunlop Rallye raid/Terraflex
9. Percentage of road versus dirt use:20/80
10. Would you buy another one?:Yes
12. Pic of the bike if available: New...
And not so new... (click pic for the ride report)
2004 KTM 625 SXC
2004 Yamaha FZ-1
1996 KTM 620 RXC
txrider screwed with this post 09-02-2007 at 09:52 AM
txrider is offline   Reply With Quote
Old 09-02-2007, 09:17 AM   #52
humdinger
bp
humdinger's Avatar
Oddometer: 616
1. 640 Adv.
2. 2005 model
3. Bought new
4. 9000kms
5. Mods. hi guard, Single disc, Full Akro exhaust, FCR 41 mx carb, Excel front rim
6. Normal maintenance shcedule; oil changes (frequent), air filter etc.
7. Upgrades: see above plus lots of scratches and gouges.
8. Tyres: Dunlop 908 rr front- Michelin Baja rear
9. 90% dirt - 10% road usage
10. Would like the 690 when available
11. Mainshaft replacement: N/A
'05 640 Adventure
humdinger is offline   Reply With Quote
Old 09-02-2007, 10:52 AM   #53
boney
Ride > Post
boney's Avatar
Oddometer: 1,406
2. Year: 2002
3. Bought used or new: Used at ~3000 mi
4. Current mileage: 8500 mi
5. Modifications done: Previous Owner(s) Akra full pipe & jet kit
6. Mechanical work done: Re-greased steering bearings, new fork seals & oil
7. Upgrades done: Roller bearing upgrade (it's an upgrade because OBs didn't fail) Scotts under bar stabilaizer and 50mm bar risers
8. Current tires on the bike: Michelen Desert F&R
11. Did you replace the main shaft bearing (if applicable): Yes- see above
boney is offline   Reply With Quote
Old 10-05-2008, 10:53 PM   #54
AWOL
Desertsurfer
AWOL's Avatar
Oddometer: 41
. Bike: LC4 Adventure
2. Year: 2002
3. Bought used or new: used @ 5000 kms
4. Current mileage: 41,500 km
5. Modifications done: 35mm bar risers, Acerbis Rally handguards, Touratech following - headlight protector, rear luggage rack extension, Vp45 Tankbag, pannier rack, roadbook holder, ....Rally footpegs, 12V power outlet, Stealth sprocket, Z-Ring 'Orange' chain, Kaoko throttle lock, Acerbis fork skins
6. Mechanical work done: religiously routine maintenance, replaced clutch cable at approx. 20,000 km and 38,000 km. fork oil and seals approx. 25,000 km
7. Upgrades done: see mods (?)
9. Percentage of road versus dirt use: 75% offroad, 5% road, 20% air
10. Would you buy another one?: Yes, but would track down a 660 or 690 Rally beforehand.
11. Did you replace the main shaft bearing (if applicable): Negative
'02 KTM 640 Adventure(gone but not forgotten)
AWOL is offline   Reply With Quote
Old 10-06-2008, 01:46 AM   #55
izom
izom's Avatar
Oddometer: 378
Thumb
...this is my 4th lc4 !
-first was a 94 (no problems)- a 96 e-start(battery failure)- a 99 six days- no probs...
now: 2003 adventure
bought used (9000km)with garantee
km 11.000
modifications: as usual- bar raisers, sidestand, spring preload...
techn. probs: new front wheel- front brake
motor, clutch OK by now
tires: conti tkc 80
drive 80% offroad
-the best lc4 ive ever head- driving easy- good power-lots of fuel stored- good seat etc.
would i buy another one???
DONT like the vibrations and miss 6th gear-
SO- waitin for a six gear 690 adventure?!
or change to 950/990 maybe........
03 640 adventure....still lovin it!
82 xr 500 - love those old thumpers
92 XTZ 750 rally style
izom is offline   Reply With Quote
Old 10-16-2008, 04:46 AM   #56
ginginacchi
ginginacchi's Avatar
Oddometer: 8
Bike: LC4 Adventure
2. Year: 2005
3. Bought used or new: new
4. Current mileage: 26000 km
5. Modifications done: 35mm bar risers, Touratech following - headlight protector, rear luggage rack extension, pannier rack in the box :), roadbook holder, ktm fork skins, sommer side stand, sommer engine protection with tool boxes, high mudguard, brake tubes, ortlieb rackpack and saddlebag.
6. Mechanical work done: routine maintenance, fork oil and seals approx. 22,000 km
7. Upgrades done:
8. Current tires on the bike: Michelin T63
9. Percentage of road versus dirt use: 40% offroad, 60% road
10. Would you buy another one?: Yes, a small sister only for dirt
matteo
"ghigno" Ktm 640adv '05
"frau blucher" bmw R1100gs '98
"pasturona" vespa PX'84
ginginacchi screwed with this post 10-16-2008 at 05:38 AM
ginginacchi is offline   Reply With Quote
Old 10-16-2008, 12:55 PM   #57
Soda Cracker
Oddometer: 18
1. Bike: 600 D\XC
2. Year: 1991
3. Bought used or new: used, from Original Owner
4. Current mileage: ~unknown
5. Modifications done: Changing over to 1996 Plastics and tank
6. Mechanical work done: Lots
7. Upgrades done: Upgraded to RXC Forks (original Mueller forks .. I didn't like the way they reacted), Pro Taper Bars
8. Current tires on the bike: Frt: Bridgestone , Rear: Maxxis IT Desert
9. Percentage of road versus dirt use: 99.999% Dirt, the rest road.
10. Would you buy another one?: Without Question
Soda Cracker is offline   Reply With Quote
Old 10-31-2008, 01:56 PM   #58
Luke
GPoET&P
Luke's Avatar
Oddometer: 4,232
2. Year: 2002
3. Bought used or new: Used, at 10k miles
4. Current mileage: 27k miles
Electrical: HID lights, extra taillight, heated grips+jacket, upgraded wiring
Ergonomics: bar weights, bar risers, Renazco seat, rallye pegs
Suspension: Resprung and valved front and rear, lengthened rear shock, steering damper
Motor: FCR carb, stainless mesh oil filters, SXC muffler. 17/40 gearing
Other: Homemade luggage rack, sidestand
6. Mechanical work done: Scheduled maintenance, subframe un-bending, new fork seals
8. Current tires on the bike: TKC80 front, MT18 rear
9. Percentage of road versus dirt use: 70/30
11. Did you replace the main shaft bearing (if applicable): Yes- PO did it
Luke is offline   Reply With Quote
Old 10-31-2008, 04:36 PM   #59
dirty_sanchez
Dirty_Sanchez
dirty_sanchez's Avatar
Oddometer: 2,999
Bike: LC4 Adventure
2. Year: 2003
3. Bought used or new: Used/Fleabay
4. Current mileage: 24,000 miles
5. Modifications done: 35mm bar risers, Touratech headlight protector, TT Pannier Rack, TT Zegas 35 & 41l, TT 60csx mount, SW Motech side stand, FCR 39mm w/JD kit, SXC Comp. Can w/ Pro Moto Billet SXC endcap w/o Spark Arrester, Ceramic Coated Head Pipe, Wolfman Tank bag and Tail bag, Upgraded wiring feeding Centech w/relays controlling HID's, LED Blinkers, LED Tail bulb, Fastway Pegs, Datel Voltmeter, Jet 4 Power, Kacokao (sp?) throttle lock, 17/42 or 15/42 gearing depending on terrain, Heated Grips, wired for Gerbings Jacket, Soon: Electrosport H/O stator w/950 Volt/Reg
6. Mechanical work done: Rebuilt waterpump before it failed at 18k~ miles, Replaced head gasket-23k~ miles, Head porting, valve seat grinding, multi-angle valve job- by Munns Racing just because, new cam bearings
7. Upgrades done: Cop Shocks, Cop Tires
8. Current tires on the bike: TKC front, 980RR on the rear
9. Percentage of road versus dirt use: 30% offroad, 70% road
10. Would you buy another one?: Oh, Yeah. but waiting for a 690A a few years into production
11. Did you replace the main shaft bearing (if applicable): Not Needed
Dirty
No, really, the mustache means I love you.
dirty_sanchez screwed with this post 10-31-2008 at 07:30 PM
dirty_sanchez is online now   Reply With Quote
Old 10-31-2008, 06:59 PM   #60
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
2. Year: 2003 (the best one)
4. Current mileage: 12,000 and change
5. Modifications done: Renazco seat, Garmin 76S in Touratech mount, KTM tank bag, Dual Star mirrors, Dirt-Bagz, SW Moto side stand, IDS2 'Trapp quiet can, open airbox side cover, etc. etc.
6. Mechanical work done: fork seals under warranty, nothing more
7. Upgrades done: see above
9. Percentage of road versus dirt use: 60% dirt - 40% street
10. Would you buy another one?: in a fuckin' heartbeat
11. Did you replace the main shaft bearing (if applicable): n/a
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC screwed with this post 10-31-2008 at 07:22 PM
ChrisC is offline   Reply With Quote
Times are GMT -7.   It's 04:59 AM.
