Old 10-31-2008, 11:02 PM   #61
gunnerbuck
Island Hopper
gunnerbuck's Avatar
Oddometer: 4,176
1- 640 Adventure
2- 2003
3-Bought new in 04
4- 116,000 KM
5- Mods, 155 main jet, 55W acc. light
6- Work history- 4 float needle + seat replacements, 5 needle jet/ 4 jet needle replacements, Replace slide + membrane, replace cam bearing, exhaust follower bearing replaced twice, Intake follower will be replaced a third time, rebuild waterpump 3 times, replace countershaft seal twice + o -ring 4 times, replace crankshaft + bearings, replace piston and replate cylinder, 2 valve jobs, replace leaky headgasket, reseal leaky rocker cover a couple times, fix electrical gremlins periodicly caused mostly by vibration/chafing, Replace rear wheel bearings 4 times/ twice front, Renew fork seals twice, fatigue replacement of front engine mount bolt + L.S. fairing mount bracket, 8th chain/sprocket set combo coming up, rebuild clutch master cylinder....... Update: Replace worn starter clutch, replace clutch slave O-ring
7- upgrades done- Moto-sport frames + yukon bags, homemade tail rack extension
8- tires- Currently on the 17th rear a Mt 21, 13th front VRM 147...
9- Slab VS Dirt- 50/50
10- Same bike again? Sure, best bike out there for my needs....
11- Not yet...
gunnerbuck screwed with this post 06-19-2010 at 03:36 AM
gunnerbuck is offline   Reply With Quote
Old 10-31-2008, 11:59 PM   #62
mikeprod92211
Desert Rat
mikeprod92211's Avatar
Oddometer: 589
Yes I found the longevity thread in the 640 LC4 thread link but I was hoping to get a little more specific.
I would like to see the following information from LC4 owners (past or present).
1. Bike: LC4E
2. Year:2000
3. Bought used or new:used
4. Current mileage:27000+
5. Modifications done:Carb needle adjusted, easternbeaver.com headlight wiring harness with dual relays, 525 exc headlight, my own muffler mods for more airflow, Loaded bar risers, Loaded fuel screw, Spitfire windshield, Komfort seat (2nd), Enduro Engineering rear disc guard, Kissan rear light flasher, LED additional rear brake lights....
6. Mechanical work done:Starter clutch replacement
7. Upgrades done:Soon...rear shock rebuild, new front fork springs
8. Current tires on the bike:IRC GP 110's
9. Percentage of road versus dirt use:60/40
10. Would you buy another one?:Waiting for the 690 Adv
11. Did you replace the main shaft bearing (if applicable):no
12. Pic of the bike if available:need to downsize the pic!
LC4 Rider
mikeprod92211 is offline   Reply With Quote
Old 11-01-2008, 08:50 AM   #63
G.Kennedy
G.Kennedy's Avatar
Oddometer: 1,850
1. Bike: 640 Adventure
2. Year: 2002
3. Bought used or new: Used (had 5000 on it)
4. Current mileage: 22,500 miles
5. Modifications done: Precision Concepts revalve/respring, Seat by Rocky Mayer, SXC can, Pastrana Pro Tapers, Scott Stabilizer, Supermoto fender ... etc...
6. Mechanical work done: Bearing upgrade, carb rebuild .... lube everything
7. Upgrades done: see above
8. Current tires on the bike: Dunlop 606 Rear .. Sahara front (kinda burning though old take offs commuting right now)
9. Percentage of road versus dirt use: 50% dirt - 50% street
10. Would you buy another one?: Absolutely ... would love to have a backup.
11. Did you replace the main shaft bearing (if applicable): Yep ... original looked fine though
'00 R1100RT
'05 525EXC
'08 Hypermotard
IBA#11791
G.Kennedy screwed with this post 03-24-2009 at 04:46 AM
G.Kennedy is offline   Reply With Quote
Old 11-01-2008, 12:26 PM   #64
exiliadodecordoba
Santiago Valinoti Loza
exiliadodecordoba's Avatar
Location: Rio de Janeiro, Brasil - Patagonia, Argentina
Oddometer: 45
Hi, my name is Santiago. Im from Cordoba, Argentina. But im living in Rio de Janeiro, Brasil. I travelled with my KTM from Mendoza (ARG) to Rio de Janeiro (BRASIL) in 5 days... 1000km a day... just cheking oil and tires... the 640 lc4 adventure is a perfect engine for long trips...
1. Bike: 640 LC4 Adventure
2. Year:2006
3. Bought used or new: used with 3000 km
4. Current mileage: 12000 km
5. Modifications done: no
6. Mechanical work done: no
7. Upgrades done: GPS
8. Current tires on the bike: Metzeler Karoo MCE
9. Percentage of road versus dirt use: 50%50%
10. Would you buy another one?: yes.. but i could prefer check the new 690 rally desert
11. Did you replace the main shaft bearing (if applicable): no
exiliadodecordoba is offline   Reply With Quote
Old 11-01-2008, 09:33 PM   #65
SCsurfer
surfing explorer
Oddometer: 170
2. Year: 2007
3. New or used: New
4. Current mileage: 5200 mi
5. Modifications: Standard carb mods , open air box , Leo Vice pipe
6. Mechanical work: Normal service
7. Upgrades: Renazco seat , Scotts steering stabilizer, headlight wiring upgrade ala Eastern Beaver relay harness, Odessy battery, Wolfman tank bag, Pro Moto Billet rear rack.
8. Current Tires: Rear TKC 80, Front Metzler Karoo
9. Percentage Road to Dirt: 70% road / 30% dirt
10. Would you buy another: Without hesitation
11. Did you replace main shaft bearing: N/A
'07 640 Adventure
SCsurfer is offline   Reply With Quote
Old 11-03-2008, 08:50 PM   #66
Tappet
Feral
Tappet's Avatar
Oddometer: 1,451
1. Bike: 640 Adv
2. Year: 07
3. Bought used or new: New in 08 (I have a hang-up about that)
4. Current mileage: 20500km
5. Modifications done: High fender, akra, risers etc etc here
6. Mechanical work done: Removed euro restrictions
7. Upgrades done: here
8. Current tires on the bike: Michelin deserts
9. Percentage of road versus dirt use: 60/40 dirt/tarmac
10. Would you buy another one?: Yes, the 690 version when it arrives
11. Did you replace the main shaft bearing (if applicable): Nope
Tappet is offline   Reply With Quote
Old 11-03-2008, 11:43 PM   #67
braaap!
waiting for the big one
braaap!'s Avatar
Oddometer: 2,406
1. Bike: 640A
2. Year: 2004
4. Current mileage: 48500kms
  • high front guard (SM)
  • ktm side stand
  • barkbusters
  • replaced shit Behr rims with excel / morad rims
  • loaded's underbar damper mount and risers (scotts damper)
  • loaded's bst screw / slide drilled / bst rejetted
  • ktm airbox - open side cover
  • all anti pollution crap removed
  • HID lights
  • heated grips / throttle lock
  • low octane fuel - dash switch
  • dash GPS mount / hardwired power / switch w/led indicator
  • pivot pegs
  • revalved forks / shock - heavier springs added
  • clear hiflow fuel filter
  • motech pannier racks
  • water and fuel tanks
  • home made rack plate
  • regular services / oil changes / loctite
  • replaced front and rear wheel bearings / seals - 25000kms
  • replaced neutral indicator switch - 32000kms
  • replaced all shock linkage bearings / shafts / seals- 35000kms
  • replaced rear caliper - 35000kms
  • replaced inlet valve train - 35000kms
  • replaced starter spragg clutch - 45000kms
  • replaced countershaft o-ring - twice
  • replaced worn slide / needle / mainjet - 45000kms
  • helicoiled case - M12 drain plug (damn ham fisted mechanic!)
  • to do: front to back strip down scheduled @ 50000kms
7. Upgrades done: see #5
8. Current tires on the bike: Dunlop 908RR F&R
10. Would you buy another one?: Nah! hoping for the 690A... or an SE
11. Did you replace the main shaft bearing (if applicable): n/a
13. 640 wishlist: FCR / 6th gear / oil cooler / 2litres oil capacity / +10 hp
braaap! is offline   Reply With Quote
Old 02-07-2009, 03:16 PM   #68
overlandr
Dystopist
Oddometer: 5,863
Keep posting guys!
overlandr is offline   Reply With Quote
Old 02-07-2009, 06:24 PM   #69
billy bee
AAdventurer
billy bee's Avatar
Oddometer: 1,399
1. Bike: 640 E
2. Year: 2001
4. Current mileage: 11,000
  • SW Motech side stand
  • Fastway pegs
  • Motard wheels and tires
  • Airbox screen,
  • jets,
  • Loaded mount and riser for scotts dampner,
  • billet rack
  • KTM supermoto pipe
6. Mechanical work done: basic maintenance
7. Upgrades done: What's the difference between upgrades and mods?
8. Current tires on the bike: Pirelli Diabalo
9. Percentage of road versus dirt use: 99% street since motard wheels went on
10. Would you buy another one?: In a freaking heartbeat
11. Did you replace the main shaft bearing (if applicable): Was done by PO
His way was the way of contentment,
the Middle Way,
to be pursued quietly,
working a little,
playing a little,
and surrounded by friends.
--Ishi: In Two Worlds
billy bee is offline   Reply With Quote
Old 03-06-2009, 02:21 PM   #70
Newner
Buffering
Newner's Avatar
Oddometer: 1,658
1. Bike: 620 SC
2. Year: 1995
4. Current mileage: 4,000 miles ????maybe????
5. Modifications done: Removed instrument cluster and for a GPS only Mount
6. Mechanical work done: Delorto Carb is always fowling up but its fixed now.
7. Upgrades done: added that pretty orange tail rack
9. Percentage of road versus dirt use: 90%
10. Would you buy another one?: Yep anyone want to trade a 690 for a V-strom
11. Did you replace the main shaft bearing (if applicable): Nope (what you don't know won't hurt you)
Also besides that Main Shaft Bearing problem does anyone know of any other mechanical issues I should be aware of with this bike???
"Serious. Just like that scene from the matrix, except the chick was me and the ducati was a klr." -DirtyDog
Newner is offline   Reply With Quote
Old 03-17-2009, 09:40 PM   #71
yazoo
Oddometer: 1
1. Bike: 640 Adv
2. Year: 2005
4. Current mileage: 25K km
5. Modifications done: Stock crb jetted, planning to add extra fan
6. Mechanical work done: not yet, need to replace motor starter
7. Upgrades done: no, but planning to install fcr mx 39mm
9. Percentage of road versus dirt use: 95% Road
10. Would you buy another one?: Depends on the follow up model
12. Pic of the bike if available: will upload shortly
yazoo is offline   Reply With Quote
Old 03-18-2009, 06:19 AM   #72
jfn68
Oddometer: 620
http://i666.photobucket.com/albums/v...g?t=1237379531
1 660 rallye
2 2000
3 used
4 unknown...done 15000km since i got it in 04,did full chassis/engine rebuild on it
5 4860 wp/larger remote resivior with h/l dampning adj,talon hubs/tagasako rims/msc steering dampner,triple clamp,vapour speedo/trip meter
6 general service,run semi syn 15/50 shell oil
7 no upgrades planned
8 99% dirt
9 like a later one,but they are very expensive.
10 yes....but had one in it
jfn68 screwed with this post 03-18-2009 at 07:47 AM
jfn68 is offline   Reply With Quote
Old 03-18-2009, 08:49 AM   #73
1stworks
dude
1stworks's Avatar
Oddometer: 1,615
2003 Ktm 625 Sxc
1. Bike: KTM 625 SXC
2. Year: 2003
4. Current mileage: 5000
5. Modifications done: none
6. Mechanical work done: reseal rocker cover
7. Upgrades done: Lights/GPR/Renzco seat/Big gas tank/peg extenders
8. Current tires on the bike:606 front MT 21 rear
9. Percentage of road versus dirt use:20% road 80% dirt
10. Would you buy another one?: maybe it my 2nd on
12. Pic of the bike if available:yes
when i first got it
then this
firstworks
RS inspired.
Dont be bitchy
Smile.
1stworks is offline   Reply With Quote
Old 03-21-2009, 11:44 PM   #74
braaap!
braaap!'s Avatar
Oddometer: 2,406
so that's what that tinkling noise was at 52500kms....
and the head.... ugly eh!
Old 03-22-2009, 12:04 AM   #75
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,224
You've got double the mileage I do, so I can't feel sorry for ya. Jealous maybe. Remember mine's an 03 (bought in 04).
meat popsicle is offline   Reply With Quote
Times are GMT -7.   It's 06:10 AM.
