Old 03-21-2009, 11:20 PM   #76
braaap!
braaap!'s Avatar
Oddometer: 2,452
Originally Posted by meat popsicle
You've got double the mileage I do, so I can't feel sorry for ya. Jealous maybe. Remember mine's an 03 (bought in 04).
Hey there Meat
! just didn't need this right now... s'pose I'll pull it right down and refresh all the bits that go round and round and in and out....
It can't be attributed to poor fuel either... I'll be checking the bypass valve for a sticking spring too, last month had a little gearbox oil in the airbox (never had that before, well maybe after some foolish wheelies)... it might be a early warning sign of impending engine damage on these things?...
engine oil not reticulating 100%.... high temperatures... hard running.... metal fatigue on bits that have been pumping up and down for many hours... tinkle, tinkle... kaboom!
I'm still amazed how these motors continue to run with such damage!
braaap! is offline   Reply With Quote
Old 03-21-2009, 11:56 PM   #77
jfn68
Oddometer: 620
have a good look at the oil pumps,any gouges/grooves cause lost displacment....my 2 were rooted from contamination...expensive and hard to get (in oz )
jfn68 is offline   Reply With Quote
Old 03-22-2009, 12:17 AM   #78
braaap!
braaap!'s Avatar
Oddometer: 2,452
will do! thx for the heads up...
Old 03-23-2009, 09:23 AM   #79
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,238
Originally Posted by braaap!
... I'll be checking the bypass valve for a sticking spring too, last month had a little gearbox oil in the airbox ...
I am very curious too about that bypass valve; Its the only thing I can think of that might be responsible for my unreliable oil sight glass levels.
I too am amazed at how much abuse the LC4 can take and keep on running. Either that or I am a better mechanic than I give myself credit for...
meat popsicle is offline   Reply With Quote
Old 03-23-2009, 12:30 PM   #80
Pendragon5
Carress of Steel
Oddometer: 44
Talking Best Dual Sport
1. 620RXCe
2. 1998
3. new
4. 15k miles
5. shorter suspension (29"inseam),Edelbrock off-road only mods+pumper kit , skid plate, opened air box, rear disc gard, 95 model tool box@charcoal can mount, geared down=1 in front+add 6 in rear (way down)
6. normal maint., water pump+brgs, wheel brgs/both ends many times,fork seals, all cables+speedo 10+ times?, petcock, rear axle replaced when permanent side came off, new DOT5 every year!, radiator fan, left bar switch, chain gard
7. water pump seal, blue fork seals, fork seal skins, monster hvy duty tubes , brush gards, spare set of wheels
8. Kenda DS+Bridgestone Knobs
9. 80% dirt
10. yes but, newer
11. not yet
Pendragon5 is offline   Reply With Quote
Old 03-23-2009, 05:45 PM   #81
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,840
on my rebuild the bypass piston seemed stuck at the top of the bore and took some work to get down, guess thats why they have the holes drilled to the side of it... dont know if that was an issue or not on my conrod melt.
wrk2surf is offline   Reply With Quote
Old 03-23-2009, 09:18 PM   #82
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,804
1. Bike:
2. Year:
3. Bought used or new:
4. Current mileage:
5. Modifications done:
6. Mechanical work done:
7. Upgrades done:
8. Current tires on the bike:
9. Percentage of road versus dirt use:
10. Would you buy another one?:
11. Did you replace the main shaft bearing (if applicable):
12. Pic of the bike if available:
1. 660 Rallye
2. 2002
3. Used, in boxes
4. Mileage unknown. 2, maybe 3 Dakars + who knows what else.
5. Pretty much none? High fender!
6. None, all, depends on how you look at it.
7. New Renazco at builds' end! CA plate.
8. Michelin Baja F & R
9. 90% dirt, 10% road
10. A newer one, If I could.
11. No. I actually know nothing about this.
12.
When I first got the bike I was posting questions like "what is this part" and "where does the battery go", but I pretty much have the bike all figured out now.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 screwed with this post 03-24-2009 at 05:40 PM
brents347 is offline   Reply With Quote
Old 03-23-2009, 10:16 PM   #83
meat popsicle
Ignostic
Oddometer: 14,238
Next oil change I'll be pulling mine. Not sure why something with a spring doesn't make the maintenance schedule...
Old 03-23-2009, 11:20 PM   #84
dwayne
Silly Adventurer
dwayne's Avatar
Oddometer: 3,551
Intresting...I noticed some inconsistancies with mine as well.
On the 400 that went boom, there was NO check valve, on the 620 I bought to rebuild and replace the 400 with there was no spring. the spring that was in the 400 was about .880" long (spec is 1"). I KNOW the 400 hadn't been apart since I bought it (I put about 50 hours on it it is a 1998).
Rum Runners Yukon, NWT & Alaska
Roads and Ruins Scotland
Kinbasket Lake Golden B.C.
A "Day" of Dirt Biking Rockies East Slopes
High and Dry Colorado and Utah
"When your only tool is a hammer, every problem looks like a nail"
dwayne is offline   Reply With Quote
Old 03-24-2009, 06:57 AM   #85
meat popsicle
Ignostic
Oddometer: 14,238
KTM LC4 crankcase bypass valve and spring info here:
http://www.advrider.com/forums/showt...=57107&page=12
Originally Posted by creeper
... The bypass valve prevents drain-back of oil from the feed pump and engine oil filter when the engine is not running. ...
I am guessing it allows the oil to build up in the crankcase and allow for oil height measurements (dipstick/sight glass) when the bike is off. I was thinking if it is stuck open the oil height measurements would be off. If it was stuck closed that would be very, very bad of course but it shouldn't eh?
Old 03-29-2009, 08:31 PM   #86
coughinhk
CoughinHK
Oddometer: 83
Katie is my baby
1. 640 Prestige SM
2. 2004
3. Babyed (barely used, still 100% standard)
4. 17,000 Km
5. Tuning (170 main, 1.1 air, 42.5 pilot, open airbox, no SAS or EPC, WRP Lite race can) and rear rack...and .....wait for it....a top box
6. None
7. Vapor Dash
8. Michellin Pilot Power
9. 99% road (there's a short dirt road near my home I have fun on just before I wash her)
10. I love this bike but I want the 690
11. no
12. Before the top box shame and WRP (wow, great can !)
I also want to take the opportunity to thank everyone here. I've got so much good help and advice, especially about which brew to enjoy while I try to sort my bike.
THANK YOU !
coughinhk is offline   Reply With Quote
Old 03-29-2009, 08:44 PM   #87
coughinhk
CoughinHK
Oddometer: 83
......might be responsible for my unreliable oil sight glass levels.
Any idea what causes this ? Did you find out ?
My bike has a cold oil level about 1/3 up the sight glass but when hot it is right at the bottom of the sight glass. According to the manual it should be above the cold level, not below it.
Old 03-29-2009, 09:07 PM   #88
meat popsicle
Ignostic
Oddometer: 14,238
I'm still unsure, but you are right the sight glass should show a higher level when hot than when cold (thermal expansion of oil increases its volume). I am pretty sure the bike must be very level when reading the glass, and always wait a few minutes (5 at least) before reading to allow the oil to drain down and settle in the crankcase, or be diligent and wait for the reading to stabilize.
Old 03-29-2009, 10:10 PM   #89
GodSilla
I did that.
GodSilla's Avatar
Oddometer: 7,878
UPDATE:
2003 640 Adventure, now at 45,000 km's. Last 5,000 k's (4 weeks since oil change and tune up, also replaced coolant pump and thermostat) the bike hasn't missed a single beat, hasn't lost a single nut or bolt, and still runs like a freight train. ZERO problems.
It dragged my sorry arse, plus luggage and spare fuel, through some of the most isolated parts of the planet.
See ya in another 5,000.
PS Hi Meaty
GodSilla is offline   Reply With Quote
Old 03-30-2009, 03:02 AM   #90
braaap!
braaap!'s Avatar
Oddometer: 2,452
Originally Posted by GodSilla
UPDATE:
PS Hi Meaty
Yes, you are truly blessed, and immune Godsilla... the 2003 model is unquestionably, the most reliable and un-problematic of them all...
tick, tick.... KaBoom.
btw, my bypass valve cap was stuck up inside the case too... spring free length measures 24.34mm! and there where several lumps of metal inbetween the spring coils... I got lotsa parts to order and oilways to flush
Times are GMT -7.   It's 08:49 AM.
