Old 04-23-2010, 12:55 AM   #121
tHEtREV
tEAM iDIOT
tHEtREV's Avatar
Oddometer: 5,606
1. Bike: 640 ADV
2. Year:02
3. Bought used or new: used in 08?
4. Current mileage: 56000 Klm
5. Modifications done: 9l rear tank, 92 600exc seat and rear plastics, subframe support (also holds rear tank). I think thats all.
6. Mechanical work done: None that I know of.
7. Upgrades done:nil
8. Current tires on the bike:Think I'm trying a Trail wing on the rear, and a Pirelli scorpion on the front.
9. Percentage of road versus dirt use:50/50, it's main use now is out back touring.
10. Would you buy another one?: I did.
11. Did you replace the main shaft bearing (if applicable): not yet, but I will if I do the planed rebuild (just for preventative purposes, it's not on it's last legs, I hope).
12. Pic of the bike if available:
my old 92 600..
tEAM iDIOT.
The original, and still the best.
tHEtREV is online now   Reply With Quote
Old 09-13-2010, 08:03 AM   #122
hg102
hg102's Avatar
Oddometer: 163
1. Bike: 640 Adventure
2. Year: 2002
3. Bought used or new: used 10,500
4. Current mileage: 14,000
5. Modifications done: EXC exhaust, 39mm keihin, led running lights, rewired all lighting circuits w relays and heavier wire, soft lugage w racks
6. Mechanical work done: yes
7. Upgrades, Rich's custom seat,foot pegs, carbon fiber tank gards and garmin 276c.
8. Current tires on the bike: dunlop 606s
9. Percentage of road versus dirt use: 65 road, 35 dirt
11. Did you replace the main shaft bearing (if applicable): yes, failed at 12,500 but shut down before other damage incured
I also have a 99 640Adventure. I really enjoy riding and working on these excellent bikes. Best of all they don't have computers to create problems.
Russ
2002 KTM 640 ADV the best ride ever-1999 KTM
2005 R1200GS sold at 44,000 miles
2002 DRZ400e FOR SALE SOON
1990 K1RS with 106,000 miles
hg102 is offline   Reply With Quote
Old 01-25-2011, 03:46 AM   #123
izom
izom's Avatar
Oddometer: 292
Question valves
...i have now 20tkms on the clock!-
should i open the head and check the valves or not??
or do you think it makes another 10tkms??
and PLEASE can the new 640 adv.riders update this tread with their statistics!?(i know there are many new here!)
greetz peter
03 640 adventure....still lovin it!
82 xr 500 - love those old thumpers
http://www.youtube.com/user/izom
izom is offline   Reply With Quote
Old 11-19-2011, 07:07 AM   #124
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
Ktm 640 adv
2. Year: 2001
3. Bought used or new: Used
4. Current mileage: about 70,000 km
5. Modifications done: build the roadbook holder/ GPS mount, LEDs replaced the original lights.
6. Mechanical work done: Leaky countershaft seal, welded broken rear subframe. Electric wires renew. Electric connectors replaced. balancer shft bearings replaced. the Clutch bearing replaced. Clutch at arount 50,000. Carb rebuild. Cables replaced. A lot of electric work done. Rebiuld Fuel Pump. oil leaks are all over.
7. Upgrades done: Lowered. (this is downgrade)
8. Current tires on the bike: Running the Karoo everyday. use the Kenda carlsbad for long travels and desert races.
9. Percentage of road versus dirt use: 30/70. Nothing too technical. Mostly desert or rocky trails with a little singles.Use it as everyday commuter.
10. Would you buy another one?: It's amazing, no doubt, but I would like a smaller bike like the 300 or the new 350 4 strok for technical riding.
11. Did you replace the main shaft bearing (if applicable): not yet.
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
erdsh screwed with this post 11-19-2011 at 07:19 AM
erdsh is offline   Reply With Quote
Old 11-19-2011, 07:09 AM   #125
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
anothe pic of the bike
another pic of the bike
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
Old 11-19-2011, 08:13 AM   #126
Happe
KTM Nut
Happe's Avatar
Oddometer: 497
2. Year:1998
3. Bought used or new: used 101048Km
4. Current mileage: 101600
5. Modifications done: DAM exhaust, 39mm keihin, led tail light, CEV Switches, Handlebar risers
6. Mechanical work done: yes, 95000Km Piston cracked, known issue with the cast pistons, 101048Km Crank Bearing seized. New 2004 Engine with hydraulic Clutch fitted. Was lying around in the Garage
Adventure Story
7. Upgrades, Rally Seat, carbon fiber tank gards and garmin zumo 660, Paintjob
8. Current tires on the bike: Karoos
9. Percentage of road versus dirt use: 80 road, 20 dirt
10. Would you buy another one?: I have three, isn't that enough?
11. Did you replace the main shaft bearing (if applicable): No in old engine, new one has the uprated one
cu
Stefan
KTM Lc4 Adventure '03 unfortunately nicked on the 29.04.04
KTM Lc4 660 Rally '98 pre e-start Blue/Orange now with FCR41
KTM Lc4 640 E '98 Black/Orange/Silver broken up for parts
KTM Lc4 640 Adventure '98 Blue FCR39MX and DAM Exhaust
KTM EXC450 '04 Black/Orange
Happe screwed with this post 11-19-2011 at 08:35 AM
Happe is offline   Reply With Quote
Old 11-19-2011, 08:21 AM   #127
Happe
KTM Nut
Happe's Avatar
Oddometer: 497
1. Bike: 660 Rally
2. Year:1998
3. Bought used or new: used 18000Km (including 1x Dakar in 1999)
4. Current mileage: 40000
5. Modifications done: 2004SMC high Flow Head and cylinder & Ingnition fitted, 41mm keihin, led tail light, Stenhouse Racing SteeringDamper mount with Handlebar risers, Scotts Steering Damper, Selfmade wiring
6. Mechanical work done: yes, 39000Km Piston tired, shim of Rocker schaft failed and rocker seized, New Piston and Valve drive fitted. Rally Overhaull
7. Upgrades, It is a Rally Bike therefore perfect
9. Percentage of road versus dirt use: 50 road, 50 dirt
11. Did you replace the main shaft bearing (if applicable): Yes, first job done just in case
cu
Stefan
Old 11-19-2011, 11:07 AM   #128
pcvance
Walk Verplank
pcvance's Avatar
Oddometer: 2,300
1. 640-E
2. 2000' the last year with WP 50MM extreem forks
3. bought used w/11000 miles
4. current mileage 19725 miles
5. bst-40 mods/KTM air box side cover and KTM exhaust/bars & risers/rear rack
6. only routine matinance so far...
7. skid plate, Cycra handguards, Wolfman tankbag and side stand
8. D606 front and rear
9. 40 slab/60 dirt
10. yep! great bikes
11. nope... not yet
12. here it is...
KTM 640-E / KTM 525 EXC CENTRAL VALLEY DUAL SPORT RIDES / RIDERS Sequoia-So Cal / STEWARDS OF THE SEQUOIA
pcvance screwed with this post 11-19-2011 at 04:54 PM
pcvance is offline   Reply With Quote
Old 11-20-2011, 12:00 PM   #129
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 2,735
Originally Posted by overlandr View Post
Some threads must not die.
Indeed. I just updated my original post & added a link to my 95K km rebuild thread.
Peter: both my sets of cam bearings have lasted over 45K km, but many have had theirs fail at less. I'm planning to replace the current set when they have done 40K km.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is online now   Reply With Quote
Old 11-23-2011, 01:05 PM   #130
Elefant 900 Rad
Hedley
Elefant 900 Rad's Avatar
Oddometer: 1,007
1. Bike: 640 LC4 Dualsport
2. Year: 2000
3. Bought used or new: New
4. Current mileage: 10,000+...not sure, speedo-odo broke long time ago (I ride my 950 a lot more).
5. Modifications done: Not much, just accessories.
6. Mechanical work done: Crank Bearing (my fault, air filter did not seat properly, allowed dirt into engine), other...typical maintenance.
7. Upgrades done: Modified seat, rear tail rack, modified rear turn signals, Trailtech Computer.
8. Current tires on the bike: Dunlop D606 front & rear
9. Percentage of road versus dirt use: 10% road, 90% dirt, lots of single track (this is my small bike).
10. Would you buy another one?: Yes due to reliability and great motor.
11. Did you replace the main shaft bearing (if applicable): NA for 2000 ?
12. Pic of the bike if available: will post later.
Wooops.....
Randy L.
President & Founder
SAN DIEGO ADVENTURE RIDERS.com
Ducati 900 Elefant
KTM 950
KTM 640
HD XR1200
Elefant 900 Rad screwed with this post 11-23-2011 at 01:19 PM
Elefant 900 Rad is offline   Reply With Quote
Old 11-24-2011, 12:34 PM   #131
Happe
KTM Nut
Happe's Avatar
Oddometer: 497
The models after 2003 have the uprated Mainshaftbearing.
Your 2000 Model still has the normal Ball Bearing. What is sort of a legacy from the older Lc4 Sports Days. The times when the engines got a revision every few races.
The swap is fairly easy.
I wouldn't do it now but next time you plan a large service and maybe some work on the clutch.
cu
Stefan
Old 05-14-2012, 05:29 AM   #132
willembron
willembron's Avatar
Oddometer: 8
Send a message via Skype™ to willembron
cool
1. Bike: KTM 640 Adventure
2. Year: 2005
3. Bought used or new: new
4. Current mileage: 29650 km
5. Modifications done: Akrapovic, Woody's rims, lightning wires for better lights, tank protection, ...
6. Mechanical work done: many, water pump, rockers bearings, chain
7. Upgrades done: ...
8. Current tires on the bike: MCE Karoo
9. Percentage of road versus dirt use: 50% 50% I would say
10. Would you buy another one?: yes with 6 gear!
11. Did you replace the main shaft bearing (if applicable): nope
willembron is offline   Reply With Quote
Old 07-31-2012, 12:04 PM   #133
thisisjess
thisisjess's Avatar
Oddometer: 38
1. Bike: KTM 640 LC4 Enduro
2. Year: 2000
3. Bought used or new: used 3/2012
4. Current mileage: 10,500 mi when purchased now 19,218 miles
5. Modifications done: easily adjustable mixture screw, USB port on bars, X2 headlight
6. Mechanical work done: nothing but oil changes, fork seals, leaky rocker cover...
8. Current tires on the bike: Shinko 705 then back to Michelin T63's
9. Percentage of road versus dirt use: 75% 25%
10. Would you buy another one?: I am in love. but on cross country trips an extra gear would help.
this is jess...
twitter
www.thisisjess.com
thisisjess is offline   Reply With Quote
Old 07-31-2012, 12:33 PM   #134
timolgra1
timolgra1's Avatar
Oddometer: 417
Love it!
1. Bike: 640ADV
2. Year: 2006
5. Modifications done: see upgrades
6. Mechanical work done: Fork seals, preventative maintenance: cam followers, water pump, suspension linkage, swing arm bearings, wheel bearings,
7. Upgrades done: fcr 41 carb, open air box, Akro, Renazco, bar risers, Ohlins steering damper, stiffer fork springs, high mudguard, crash bars, pannier frames, f650 screen extension, Exel front rim, HID lights, heated grips, QR fuel lines, Roadbook, hand guards......probably more
8. Current tires on the bike: F Michelin Desert R Dunlop D908
9. Percentage of road versus dirt use: 80% dirt
10. Would you buy another one?: If only!!
11. Did you replace the main shaft bearing (if applicable): N/A
timolgra1 screwed with this post 07-31-2012 at 12:44 PM
timolgra1 is online now   Reply With Quote
Old 03-07-2013, 07:49 AM   #135
overlandr
Bend it Bend it
Oddometer: 5,433
bumpisch
overlandr is offline   Reply With Quote
Times are GMT -7.   It's 04:19 AM.
