Old 04-22-2007, 07:14 AM   #61
paochow
Bye bye desert
paochow's Avatar
Oddometer: 1,177
Instead of mashing pennies, is it possible to access the crank/stator nut from the other side like in this pic?
http://www.thumpertalk.com/forum/gar...chmentid=15804
BTW:A few DRZ's have had similar issues with the primary nut, hence my fix on it.
paochow is offline   Reply With Quote
Old 07-29-2007, 10:42 AM   #62
Hoder
Card carrying greeny
Hoder's Avatar
Oddometer: 1,015
Well, I thought I'd revive this one because I just went from what was to be a glorious 5 days in the Olympic mountains
To this
Because of this
This happened at about 3700 miles & luckly I wasn't 50 miles up in the hills somewhere. I had checked the nut on my 2nd oil change but didn't know to stuff a penny in the gears & so I did the best I could with it in gear. It seemed tight to me. I thought the bottom end had been a lot noisier lately especially since my daughter thought it would be fun to put the garden hose in the exhaust & fill 'er up . The fix only cost 65 cents & she runs smoother & quieter than ever but I really should have checked it properly in the first place. The nut went about a 1/8 turn past where it was originally so obviously it was nowhere near tight enough.
See my pics
Dave:
The 610 really makes me want to ride like a punk everywhere I go.
bikefrk:
You now understand supermoto.
Your training is complete.
Hoder is offline   Reply With Quote
Old 07-29-2007, 02:37 PM   #63
buffallodan OP
buffallodan's Avatar
Oddometer: 1,702
Sorry to hear of your badluck, thankfully you weren't in a really isolated area...hopefully others will learn from your misfortune and make sure the nut is checked. When mine failed I tightened the nut and it ran fine afterwards. Thankfully Jim made me check it to be sure the Woodruff key was intact and he was right, once you get the rumbles you definately have a sheered key.
Dan
buffallodan is online now   Reply With Quote
Old 07-30-2007, 08:49 AM   #64
Watercat
Web Footed Adventurer
Watercat's Avatar
Oddometer: 1,269
Eek
Hoder,
Too bad about your trip being cut short . . . . Guess it's all part of the adventure. I'll definitely be checking mine for this issue.
Thanks for the reminder.
Get your motor runin' . . . . . "Seek an erection for medical help lasting longer than four hours"
" . . . discovery channel has been shit for over a decade . . . this (ADVrider) is actually good." - OldAndBusted
Expect the unexpected! - Skunked & DfunkD
2006 Husky TE 610
2005 Big Strom
2010 THRUXTON
Watercat is offline   Reply With Quote
Old 07-30-2007, 02:15 PM   #65
dlorenz
dlorenz's Avatar
Oddometer: 15
I thought I had the dreaded "loose nut vib" going on. I felt a unusual vibration and heard a new noise so I checked it out. It turned out to be the forward engine mount bolts were loose and the engine mount bolts (2) on top of the head were completely missing. Checked and tightened eveything and she's smooth as butter, well maybe not that smooth, but she sounds good.
Look over your bike!
Dave
dlorenz is offline   Reply With Quote
Old 11-05-2007, 12:28 PM   #66
MrDude_1
Loser says Duc?
Oddometer: 35
i dont own a 610, but i can give you guys a common tip for motorcycles..instead of mashing pennies ( ) or unbolting other things.... just stuff a rag inbetween the gears.. its that easy.with a rag jammed in there, the gears wont turn, and you can tighten... or put the rag on the other side, and you can loosen.... and theres zero chance of hurting the gears or anything.this is common for clutch changes on other bikes.... it also lets you use a torque wrench instead of an impact.
MrDude_1 is offline   Reply With Quote
Old 11-05-2007, 08:33 PM   #67
jsuhr
Oddometer: 8
Is this nut still a problem on the 07's?
Just picked mine up a few weeks ago and would like to head off any potential problems
jsuhr is offline   Reply With Quote
Old 11-05-2007, 09:11 PM   #68
buffallodan OP
Oddometer: 1,702
I don't recall reading of any 07' bikes having this issue.
Dan
Old 01-05-2008, 09:43 AM   #69
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,777
Another one
I just picked up (another) used 06 TE610 with 1900 miles on it. The first thing I did was ride it home after the purchase, rip it apart and torque the nut down. Sure enough, I got a good 1/8th of a turn more out of it.
drrags is online now   Reply With Quote
Old 01-05-2008, 04:32 PM   #70
Conner
Formerly everything
Conner's Avatar
Oddometer: 295
Hi Arno!
...And now a Husky? Wow, the paints not even dry on your 990 is it? Which one are you gonna take to Mexico??
Conner in Sacramento
Conner is offline   Reply With Quote
Old 01-09-2008, 05:17 PM   #71
Thinc2
Paciugo
Thinc2's Avatar
Oddometer: 4,319
Just looking for an update - any evidence that this affects '07's, or does it seem to be an '06 issue?
Me: You should think before you speak.
Daughter: That always backfires on me.
F800GS review.
Thinc2 is online now   Reply With Quote
Old 01-09-2008, 06:27 PM   #72
ThatGuyEd
Mud Lover
ThatGuyEd's Avatar
Oddometer: 591
There has yet to be any reports of issues with the 07's.
I ripped my 07 open when I got it to check... It didn't budge.
What I lack in skill, I make up in reckless abandon.
ThatGuyEd is offline   Reply With Quote
Old 01-11-2008, 04:22 PM   #73
drrags
Dorkus Malorkus
drrags's Avatar
Oddometer: 1,777
My shame for all to see
When I got my 06 TE610 the first thing I did was to torque down the nut, but it was bugging me that I didn't actually check if I had sheared the woodruff key and got things out of sync, so today I decided to take a look-see.
First, I stuffed a rag between the gears, but all I got was a shredded rag and bits all over the place.
Second, I tried two pennies. One for each gear (clutch and counterbalancer). I mangled both of them completely and still didn't get the nut loose.
Finally, I stuck a screwdriver between the two gears. And guess what, I broke a tooth.
So let that be a lesson to all you boys and girls - don't stick hard stuff between the gears!
Oh! And I broke the screwdriver too!
Old 01-11-2008, 05:16 PM   #74
buffallodan OP
Oddometer: 1,702
Perhaps an impact gun would have broke it loose without placing as much leverage on the gears...aluminum also suggested in the manual I think, would be the next step up from the pennies. Sry about the mishap and hope you get it sorted
D
Old 01-11-2008, 05:32 PM   #75
Hoder
Hoder's Avatar
Oddometer: 1,015
Doh! Bummer man.
See my pics
Dave:
bikefrk:
Times are GMT -7.   It's 09:12 AM.
