Old 01-30-2011, 11:00 PM   #1951
Kai Ju
Kai Ju's Avatar
Oddometer: 1,891
Powder coating stock Honda CRF Rims and Hubs
Hey Woody,
A friend of mine asked what I knew about powder coating stock hubs and rims on his '05 CRF450 Honda.
I said I didn't know anything but that I would try and find out.
Looked on this thread and found a comment about the rims weakening (KTM or BMW) but couldn't find anything Honda rims or their hubs.
Any info/advice would be appreciated.
Kai Ju is online now   Reply With Quote
Old 01-31-2011, 02:47 PM   #1952
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,431
powder-coating rims and hubs..
Originally Posted by Kai Ju View Post
Hey Woody,
FYI,,,this applies across the board to any high tensile strength alloy rims,,,,we've noticed that powder-coating the high tensile strength alloy rims appears to soften the rim,,you are baking it circa 375-475 degrees F for an hour,,,,steel rims aren't affected,,why i notice it is folks send in their powder-coated rims and shortly thereafter they are here with rims that look like the notoriously soft Behrs of KTM LC-4/8 or BMW F800GS .
nor are the cast hubs,, we usually only powder-coat rims for show bikes ,,cast mags,,an dth eoccassional X-laced BMW wheels if they are kept mainly on the road...[the X-lace pattern holds the wheels together/creates more structural support than standard rims
bottom line for you MXers powdercoat the hubs if ya want but re-anodize the rims
w
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 01-31-2011, 08:25 PM   #1953
Kai Ju
Kai Ju's Avatar
Oddometer: 1,891
Thanks for the quick answer.
Just want to clarify one more time since you wrote: "nor are the cast hubs,,"
Rims: no
Hubs: yes
Old 01-31-2011, 10:10 PM   #1954
Built to Last
Oddometer: 3,431
Rims: no
Hubs: yes
you got it!!!
woody
Old 02-01-2011, 03:01 PM   #1955
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Ok I did search but found some conflicting info... So I thought I'd ask the pro.
What is the recommended torque tension on Ktm 9x0 adventure spokes?
And in case the torque wrench goes crazy, how do you approximate it?
Sharp "dings" as opposed to dull ones?
I've been checking mine and they vary in a huge way from one to the next
Thank you!!!
bikyto is offline   Reply With Quote
Old 02-01-2011, 08:23 PM   #1956
Built to Last
Oddometer: 3,431
how tight to twist them nipples..???
Thank you!!!
well,,, till they scream uncle!!!!!,,,,,duhhhh
ok a nice high pitched ding is ok,,, a ting is better but no dongs or doiiiiings...
FYI,,,10Nm=7ft/lbs= 84 inch/lbs
most folks use 4-5Nm=2.8-3.5 ft/lbs=33.6-42inch/lbs
FYI,,we never use a torque wrench,,i trust the feel of my wrist and the pitch in my ear....as i twist them nipples...
you know,,ting,,ting,,ting for Superlace and ding ,,ding ding for regular spokes
Pssst a lil secret,,,that torque wrench will tell ya the amount of resistance....between your nipple and your spoke,,that's all,,you can have the perfect reading and yet have spokes too tight and /or too loose,,now why's that???...contemplate the following scenarios,,,,
what will it tell you if you have rusty/dirty threads on spoke or nipple,,,???
what will it tell you when you have clean spokes and nipples???,,
what will it tell ya if you used anti-seize on your threads or 3in 1 oil or bearing grease???,,,[OBTW,,,i always use chain saw bar oil for ss spokes and zartan nipples and the special anti seize jism buchanans has concocted for keeping ss n ss from seizing
think on these things
at days end a good nights sleep comes from the sweet lullabye of ding,,ding ding ding ding ding ....
as well as your rim neither hopping nor wobbling more than circa .020'' in any direction
w
woody's wheel works screwed with this post 02-01-2011 at 08:44 PM
Old 02-01-2011, 08:38 PM   #1957
bikyto
bikyto's Avatar
Oddometer: 2,190
Originally Posted by woody's wheel works View Post
what will it tell ya if you used anti-seize on your threads or 3in 1 oil or bearing grease???,,,[i always use chain saw bar oil for ss spokes and zartan nipples and the special anti seize jism buchanans has concocted for keeping ss n ss from seizing
w
Ding ding ding..ting ting... Ok I'm gonna train my ears. I don't have a torque wrench for spokes so...I'll follow your advice! Thank you thank you
And yes, i thought about the nipple/rust/thread. I've been cleaning them.
I was going to seal them using your technique for tubeless...so no oil in there.
I don't have any wobble but had a DING on the front rim which is now straight (it's a spare set that I've been experimenting with).
You should have a donation email/paypal or something for all your advices. When I can afford it..... I'll get a nice set from you ... I've been lurking at your work for quite a while.
Thanks again!
I'm going back to ding ding ding.... Hopefully I'll sleep well after that
Old 02-03-2011, 12:45 AM   #1958
jamesgs4
jamesgs4's Avatar
Oddometer: 480
Woody,
Is there a discount on services for forum members? A secret password maybe?
jamesgs4 is offline   Reply With Quote
Old 02-03-2011, 05:43 PM   #1959
jamesgs4
jamesgs4's Avatar
Oddometer: 480
ok thanks for the novel
Old 02-03-2011, 06:14 PM   #1960
johnwesley
wanta be
johnwesley's Avatar
Oddometer: 1,639
thanks for the info over the phone hub ships out tomorrow
johnwesley is offline   Reply With Quote
Old 02-03-2011, 07:33 PM   #1961
Built to Last
Oddometer: 3,431
hope i didn't scare ya away
woody
PS,,what novel??
Old 02-03-2011, 08:32 PM   #1962
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 974
Woody,
Tough economy these days, so I understand asking for a discount, most of the time I do too... but I feel it is important to recognize the level of quality and service Woody provides.
If you've never seen one of his wheels, I suggest asking a few inmates here to provide you with a few adjectives, or better yet get your hands on one; I would say he elevates the wheel to an art form. Then take the time to read through all his posts offering technical support and advice to the ADV community. Sure, he makes sales here, but they are earned.
My point is, in this day and age there are very few places where we can turn for a quality product and the level of service and expertise Woody offers. We have to support the good guys when we see them, or soon they'll all be gone.
Peace.
Cogito ergo sum
Taki is offline   Reply With Quote
Old 02-06-2011, 06:48 AM   #1963
nat_han
2 Wheelers By Choice.. =]
nat_han's Avatar
Oddometer: 200
Peace.
Agreed. One of the most genuine post i've read so far this year!
He addresses your concerns/queries well enough even before you commit your hard-earned monies to him...
It's been 30+ email exchanges between us, and he hasnt earned a single penny from me yet... But it's so gonna change by the month's end..
nat_han is offline   Reply With Quote
Old 02-09-2011, 06:21 PM   #1964
Yooper-at-heart
Moto Adventurer
Oddometer: 141
Woody, I sent you hubs and you guys made me these. 17 rear, 19 front supermoto-ish set up. They look sweet.
I also own one of these. Aprilia Dorsoduro
I would love to have a wheel set like one of these for more light offroad and adventure riding. I'm not really a streetbike guy but love the Aprilia Dorsoduro. I have no idea if spoked wheels(17 and 19) are possible fit due to lack of hub match but if you found a way I would be very interested and so would alot of other owners. Any thoughts?
Yooper-at-heart screwed with this post 02-13-2011 at 09:29 AM
Yooper-at-heart is online now   Reply With Quote
Old 02-09-2011, 07:32 PM   #1965
Built to Last
Oddometer: 3,431
19/17 for an aprillia Dorsoduro???,,why not????
Yooper at Heart and all your buddies...
send me very good drawings with dimensions or both wheels with all the spacers /discs etc in place and i'll bet i can put something together for ya
woody
PS i like the look of your set-up much better than the SM version,,,same goes for that Moto Morini combo,,,,,how about you??? a lil ride report would be in order
hey,,,i even started a new thread recently,,,perhaps you can initiate it,,,my thoughts are:
1,,, make a post ,,,of you ,you n your bike,,,
2,,then add and modify /edit it so folks can see all the variations and your experiences ove rthe long haul
3,,please DO NOT turn it into a big long discussion thread... there are plenty of them out there already
here it is:
http://www.advrider.com/forums/showthread.php?t=646947
woody's wheel works screwed with this post 02-10-2011 at 08:53 AM
Times are GMT -7.   It's 04:57 PM.
