Old 03-01-2011, 09:54 AM   #2011
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,362
Originally Posted by 257bob View Post
Ruined the wrenching surface, they seem softer than one would like...
I tried heating a couple of them without making much difference. The one I have out so far has blue locktite on it. The problem is the hex button head screw with minimal tool engagement depth. A torx would work better.
I'm going to take the impact screwdriver home with me tonight and I think I'll get one of those pinpoint torches like you mentioned.
FYI,,,if it's as difficult as you describe,,,then alternate the tip of the inner blue flame right into the socket hole and then the tip of the overall flame in circular motions around the back sie of the hub where the threads and loctite are ,,we sometimes have 2 guys doing this ,,one keeps steady pressure on the bolt,,ie just on the verge of stripping....we know the idiocy of having too small socket heads,,,Harley sportsters with their little 3/16'' in pot metal disc mount screws gave us constant fits,,now these beemer disc bolts are doing the same thing,,,,at least we were able to learn from the past,,,,good luck
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 03-03-2011, 12:04 PM   #2012
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,199
More work on the way.
Laconic screwed with this post 03-03-2011 at 03:55 PM
Laconic is offline   Reply With Quote
Old 03-07-2011, 10:59 AM   #2013
MoxNix
Stuttgart Germany
MoxNix's Avatar
Oddometer: 1,166
Originally Posted by MoxNix View Post
My XR is a 09.
I don't have any hubs, so... will you use XL1200R hubs (twin discs up front)?
I'm snow-bound so no hurry.
I know I'm quoting myself but..
Woody- Seems the stock 2006 HD Dyna (Mid Glide 5.010") hub will fit the XR and has the twin discs up front and is ~$200 assume the same $$ for a rear.
What would the cost be for-
Tubeless wire wheels, black spokes, excel rims, HD hubs (you source the hubs-- I'm in Africa right now) and associated spacers, bearings (- brake discs and belt drive components) for a bolt and go?
Hope is not a course of action.
MoxNix screwed with this post 03-08-2011 at 12:13 AM
MoxNix is offline   Reply With Quote
Old 03-09-2011, 08:07 AM   #2014
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,609
Thumb
Just wanted to send out kudos to Woody and his crew for their help. The previous owner of the bike was their customer, yet they have provided stellar service for me and have shown a remarkable attention to customer care and quality assurance.
I look forward to sending more business their way.
Thanks guys!
This is The Internet. Confirm for yourself anything you may see while visiting this strange and uncertain land.
MotoTex is offline   Reply With Quote
Old 03-12-2011, 04:14 AM   #2015
Built to Last
Oddometer: 3,362
HD-XR custom wheel set..
2 x cost of hubs circa$250=$500
2 x ss spoke kit $120=$240
2 x powdercoat spokes black @ $50= $100
2 x excel rims circa $225= $450
2 x seal for tubeless @ $99= $198
2 x custom lace n true @99= $198
spacers= $??
plus S&H
w
Old 03-17-2011, 07:23 PM   #2016
pedalmike
Horizontally Opposed
pedalmike's Avatar
Oddometer: 142
2007 R1200GS Front wheel before and after Woody's
Folks: I just thought I'd drop a note to the forum re: my experience with Woody's and the cross-spoke front wheel on my 2007 R1200GS which I have owned from new.
Before
I was using DynaBeads as the balancing medium.
With the DynaBeads in front, I was getting a significant vibration thru the handlebars, most noticeably in the 70-75 mph range.
Because of that I dismounted the tire, removed the DynaBeads, and rebalanced using a static balance technique and ¾ oz. of stick-on adhesive weight.
Now I get a pretty noticeable handlebar shake at around 40-45mph. It tends to be less noticeable above that, but I can still feel it.
I do not detect any issues with steering head bearings or wheel bearings.
I checked the front spokes for any that have obvious low tension. I tightened two that had a lower tone, but none that sounded “dead” I think.
There is a possibility that the tire is defective, or it could have worn in in a way that is now giving me this problem.
With the front wheel still installed, I attempted some rather crude measurements on rim runout.
Lateral runout: 1.75mm (beyond acceptable BMW spec I think per Woody's posts ?)
Radial runout: 0.50mm
After wheel was trued by Woody & crew
Woody trued my GS front wheel back in January 2011. I marked the tire and rotors before I sent the wheel to Woody's and put them back in the exact same place on the rim. Static balance was right on after truing.
I took the GS out last Saturday for a 40 mile ride..…marked improvement in the stability of the front with the trued front wheel. I was blaming the balance beads and my conti trail attack tire.
Before, I had a little shimmy in the bars that would start at 40-45 mph…that is gone. I took it on the Interstate and got the speed up in the 80-85 mph range. Held the grips with my thumb and index finger only on each grip. No shimmy at all.
I pulled in the clutch at 80 mph and coasted just to feel it without any engine vibration…dead smooth.
So I guess I would say that the front rim being out of true by 1.75mm was the source of my shimmy, because everything else is unchanged.
My bike has never been as smooth in the previous 18,000 miles I have ridden it. I’m certain that the front wheel is truer than when it left the factory in Berlin in 2007. I’m a happy guy.
pedalmike is offline   Reply With Quote
Old 03-17-2011, 10:33 PM   #2017
Built to Last
Oddometer: 3,362
and that's what it's all about,,,,,
Before
thank you for sharing and re-confirming what i've been trying to let ya all in on,,THERE IS A DIFFERENCE in getting your wheel trued to the original wheel specs or less[ie:.5mm/.020''] that every wheel in BMW's history has been speced to....'cept your GS wheels for whatever reason have the loosest wobbliest specs i've ever run across[ie: 1.5mm/.060''],,,,
and i assert we have a team that can beat their machine
w
Old 03-18-2011, 06:39 AM   #2018
nat_han
2 Wheelers By Choice.. =]
nat_han's Avatar
Oddometer: 200
Woody,
How are my rims coming along? Ready for shipping?
Eagerly awaiting updates on their completion...
thks
nat_han is offline   Reply With Quote
Old 03-18-2011, 08:44 PM   #2019
Assfault
Exposed Member
Assfault's Avatar
Oddometer: 2,157
Picked up my Wire Wee-Strom Woody's Wheels today.
They look great. Further details will be forthcoming.
* Assfault, Ass-Fault, Ms Ass, thier neighbors or friends, are not responsible for any incidents, accidents, or accusations, that might result from you using this forum in the pursuit of adventure greatness. Avoid taking ADV before bed time. Do not use if you experince faintness, dizzniess, inversness, difficulty urinating or an erection lasting longer than 4 hours. Thank you*
Assfault is offline   Reply With Quote
Old 03-19-2011, 09:09 AM   #2020
Built to Last
Oddometer: 3,362
RAD is finally sending the hubs,,,,
Originally Posted by nat_han View Post
Woody,
thks
hi,,am on the road with my sis for a few weeks,,will be back in denver at end of month,,,zach,,told me that for some reason un-beknownst to us your hubs were delayed,,should arrive on monday and he'll drop the hammer on them,,sorry,,,
sometimes the best laid mice of men and,,,,something like that:>)
woody
Old 03-19-2011, 09:15 AM   #2021
Built to Last
Oddometer: 3,362
checking on where the ooops occured,,
will have zach check why they didn't get sealed,,,who knows ass much as i was zooming around trying to interview potential service managers,,,get ready for my sis' visit,,am in park city,,who knows i may i even have spaced writin git down myself:<(....
will keep ya posted mike
woody
Old 03-23-2011, 07:23 PM   #2022
wavygravy
Stupid Hurts
wavygravy's Avatar
Oddometer: 308
Cast bmw wheels
Dear Woody,
Do you have any sweet hook ups for cast wheels for my 2005 R1200GS. I have spokes now. I want to get cast wheels for the street and save the spokes for the dirt.
Eventually send the rear spoke wheel to you to true up.
Thanks,
wavy
-You can't get beat up with your feet up-
"My Bride Says I'm An A$$hole To Ride With"
Current stable: R1200GS, G3-TR 90 Bushmaster
Past times: GS450L SV650 VF500F KE125 SL125 XL500 DR350 CR125
"Come visit me in the hospital, I dig carnations."
wavygravy is offline   Reply With Quote
Old 03-23-2011, 08:32 PM   #2023
omnivore
SuperSportTourer
omnivore's Avatar
Oddometer: 1,013
Is it Possible to lace up wheels in SM sizes (120 F/150 or 160R) for a KTM 950 SM?
Keeping in mind the bike has 2 front rotors etc, what would be req'd?
XR200R
KTM 950SM
CBR Fireblade-GTU Endurance racebike
1996 YZF 600-Lost Era racebike
1999 R6-Rookie Challenge racebike
omnivore is offline   Reply With Quote
Old 03-23-2011, 09:48 PM   #2024
Built to Last
Oddometer: 3,362
ktm 950SM wire wheels???,,,,no problem
we can build anything ya may want or need for that bike,,whatever color etc,just holler,,woody
Old 03-29-2011, 08:13 AM   #2025
MotoTex
Miles of Smiles
MotoTex's Avatar
Oddometer: 1,609
Hey Woody,
Thank you for the fast turn-around on the front wheel rebuild, and for finding that black T in LG.
I've already showed off the T and had someone ask about your work. They received a glowing endorsement.
The wheel is beautiful.
Now to continue the testing program, .
Times are GMT -7.   It's 02:11 AM.
