Old 03-29-2011, 11:02 AM   #2026
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,756
What is the cause of this and is there any way to prevent it in the future..
Every nipple hole has it. Some real bad spots with lots of material missing.
I live in the desert to.. Its a dry out here with very few water crossings. I do not wash it very often (never).....
07 950SE 44,000 hard miles..
DID Dirt Stars..
No pics of the front but it is cracked and needs replaced also..
Rear..
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is offline   Reply With Quote
Old 03-29-2011, 11:17 AM   #2027
Johnf3
Oddometer: 1,055
KTMSER,
Did you run Slime in your tubes? It can be very corrosive, although that damage is the worst I have seen.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is online now   Reply With Quote
Old 03-29-2011, 12:24 PM   #2028
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,756
Originally Posted by Johnf3 View Post
KTMSER,
Never used any slime, no fix a flat..
Always had a rim strip no tape..
The front is doing it also just not as bad..
KTMSER screwed with this post 03-29-2011 at 12:32 PM
Old 03-29-2011, 02:43 PM   #2029
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,431
so what's with all the corrosion on my anodized rims???
DID Dirt Stars..
Rear..
hi,,just got back in town after driving through the very deserts you speak of a week ago,,,
let me tell you,,those desert floors have accumulated a potpourri of corrosive chemical ingredients that i bet have more than enough power to do this to your aluminum rim,,,the dust get's in there,,you wash your bike and the process starts,,,,there may be other contributing factors like the galvanic action taking place between dissimilar metals in your case you have galvanized/zinc plated nipples to boot,,they do not like salts and such,,
i've seen this happen to every chrome plated rim after 2-3years of use in the east coast,,, the rockies,,,anyplace that uses salt and chloride for ice removal,,,
the only thing that i have seen work faster is SLIME,,,,visualize your wheel looking 4x as bad in half the time
FYI by the time you media blast it and re-paint/re-anodize it you may as well start with a new rim,,,,running it through the anodizing stripper should remove most of the mung....that would have to be done to see how deeply the corrosion has attacked.....
does that help ya ???
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 03-29-2011 at 03:53 PM
Old 03-29-2011, 02:55 PM   #2030
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,756
The corrosion has compromised the area around the nipples, there is a lot of material gone..
No saving these...
Have a look at them when they arrive..
Boxed and shipped...
Old 04-02-2011, 01:06 PM   #2031
pbreisch
Oddometer: 85
F650GS Question
I have a standard F650GS that I want to switch to a 21" front. I have a DID wheel that came with my front forks for another project and I was wondering if the BMW hub could be laced to that DID rim. There are no markings on it other then:
DID JAPAN 76 --07 10--
From this info can you tell me if these 2 are compatible?
Thanks,
Phil
pbreisch is offline   Reply With Quote
Old 04-03-2011, 12:11 AM   #2032
tileman
tileman's Avatar
Oddometer: 882
Hi woody.
I have just got spokes (from buchannan) for a YZ talon hub for a behr rim. I have laced the spokes up to the Behr rim with the entire combo in the forks. Its the offset that looks very wierd. The rim is centred in the forks but the hub/rim is quite of centre. How much offset would be normal? from the look from the eye it looks to be about 10-12mm. Is that normalish or have I got the incorrect spokes? (I may have given the wrong details). When you build a wheel using a talon hub to a behr rim does the rim look centred in the hub?
cheers
If ignorance is bliss, why aren´t more people happy?????
tileman is offline   Reply With Quote
Old 04-03-2011, 04:31 AM   #2033
Built to Last
Oddometer: 3,431
rim centered???
Originally Posted by tileman View Post
Hi woody.
cheers
FYI,,before we take a wheel apart we always meaure the offset with a carpenters square...usually using a surface like the disc mounting surface as the reference point...it's an easy way to re-locate the rim in the same spot...
the object of course is that the rim theoretically should be centered on the bike/between the forks in front..
so if your wheel is centered between the forks ,,i wouldn't worry too much
woody
Old 04-03-2011, 04:36 AM   #2034
Built to Last
Oddometer: 3,431
converting f650GS front to wire 21''
Thanks,
Phil
your best bet is to send everything you have and we'll see what we can salvage /swap...we have a big inventory of good used/like new stuff,,,that we can reach for to achieve the desired objective,,,
we know lot's of tricks to keep cost down,,,send it in we'll sove the problem
woody
Old 04-03-2011, 06:32 AM   #2035
tileman
tileman's Avatar
Oddometer: 882
woody
Cheers woody!!!
Really though, what could go wrong with shortened YZ forks, an axle that comes from ???, a YZ talon hub from ebay (maybe), spokes from the other side of the world, and a rim that came from a triumph. hehe
Old 04-12-2011, 01:10 PM   #2036
bcdaum
bcdaum's Avatar
Oddometer: 143
Tiger800 XC wheels
Woody,
Has anyone expressed any interest in making the wheels on a new 800 Tiger XC tubeless. I believe they come with excel rims, so you will have a good starting point. Approximately what would the cost end up being? Thanks for all of the info you provide to us.
Bob
Stupidity Should Hurt
'98 S1W
'00 1150 GS
'03 1100S BCP(traded)
'08 XB12X
bcdaum is offline   Reply With Quote
Old 04-13-2011, 06:41 PM   #2037
Built to Last
Oddometer: 3,431
making 800 Tiger XC wheels tubeless....
Originally Posted by bcdaum View Post
Woody,
Bob
hi bob once again the deciding factor is if the rim has a safety bead,,i have no qualms in making them tubeless...i do have some standards on what rims that have safety beads that i am willing or not willing to seal..
the other factor is making sure the spokes are all tight /and /or the wheel needs to be true...or else you are wasting your $$$
bottom line ,,,no problem
woody
Old 04-14-2011, 10:41 AM   #2038
Sasquatch
Sasquatch's Avatar
Oddometer: 4,770
Just got my new superlaced LC4 wheel all balanced and ready to mount and ride (waiting patiently for cooperative weather). Got to give a thumbs up to Woody's and his work. My 01 LC4 enuduro kept breaking spokes like they are prone to do. Sent it in for superlacing. Woody also discovered that the cheap assed KTM rim was also cracked at the weld.
So, new rim, new superlace, and I topped it off with new bearings. Fast turn around and fair pricing for an excellent product. I will be using them in the future for other repairs.
Sasquatch is offline   Reply With Quote
Old 04-15-2011, 05:15 AM   #2039
overlandr
Dystopist
Oddometer: 5,899
Originally Posted by Sasquatch View Post
Just got my new superlaced LC4 wheel all balanced and ready...
This post is useless without photos.
overlandr is offline   Reply With Quote
Old 04-15-2011, 08:55 AM   #2040
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,011
Thanks Woody
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is online now   Reply With Quote
Times are GMT -7.   It's 02:08 PM.
