Old 07-27-2011, 12:04 PM   #2131
rc mad
Physycotic gecko
rc mad's Avatar
Oddometer: 1,469
Originally Posted by woody's wheel works View Post
well ya got me on that one too
i know the le mans was able tto swap their Mags with othe wire wheeled models,,,i'll check my Guzzi guru for advice,,you do like wise and the rest of you inmates please chime in on this..holler nthanks
woody
PS,,we can always build em from scratch but that =$$$$$
Thanks woody, if you don't know i'm guessing it's not possible. No great loss.
I have to get my dakar wheels over to you at some point in the future
"Mad Science" means never stopping to ask "what's the worst thing that could happen?
http://advrider.com/forums/showthread.php?t=1017669
It's Santa time folks
rc mad is offline   Reply With Quote
Old 07-28-2011, 06:43 AM   #2132
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
KTM 640 ADV Wheel
Hello Woody,
I have fixed my front wheel myself after it was bent and generally bad condition.
now it is balanced OK but its about 3 mm off center.
when I measure the distance from the two front shocks to the rim edge, the right side is 3 mm bigger then the left side.
I assume it should be right in the middle.
the question is if it is so bad? should I fix it or is it in the normal range of "OK" ?
Thank you.
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
erdsh is offline   Reply With Quote
Old 07-28-2011, 12:37 PM   #2133
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,362
wheel off-center OK????..NOOOOOOOO
Originally Posted by erdsh View Post
Hello Woody,
Thank you.
FYI erdsh...
your wheel should be centered between the forks,,, to move the rim over,,,loosen the spokes on the one side and tighten em on the other till you end up where you need to be ...final runout in all directions shouldn't exceed .020''/.5mm in ny direction...for dirt bike bike only use you can double th erun-out without noticeable effects..
woody
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 07-28-2011, 01:21 PM   #2134
Honkey Cat
Tailights Fade!
Oddometer: 1,089
woodys
I just sent my rear wheel there, they called me as soon as they got the wheel and worked fast to get it back to my for a trip. They were awesome.
Honkey Cat is offline   Reply With Quote
Old 07-29-2011, 11:36 AM   #2135
Parx400
Oddometer: 1,670
PM sent about 18 inch wheel on Dakar
Parx400 is offline   Reply With Quote
Old 07-30-2011, 11:00 PM   #2136
Idle
Oddometer: 700
Thanks for your help on the wheel swap. It dropped right in, but had to adjust it over,
Idle is offline   Reply With Quote
Old 08-01-2011, 09:59 PM   #2137
me3
Oddometer: 126
Tiger XC 21" Tubeless?
Hi Woody
What's your thoughts on either
a) Making the new Tiger XC Tubeless?
b) Making an F800GS Tubless?
Possible?
Costs?
Thanx
Paul
me3 is offline   Reply With Quote
Old 08-01-2011, 10:28 PM   #2138
Turkishexpress
Groper
Turkishexpress's Avatar
Oddometer: 36
Hi Woody,
Just got my MTS 1200 S and within 300miles somehow managed to dent the right side of both front and rear wheels with one bump. I got two questions. I will eventually send these out to you to get them fixed. For now though, do you think it is ok to ride on these? They are holding pressure fine and unknowingly I have been riding the bike pretty hard for the past 100+ miles without any issues. Also, how much would you charge to get both of these straightened? Do you straighten the wheels with bearings in there or do you require that they are pulled off? I ask because if removed I would need new ones which would add another $100+ to the cost. Thanks in advance!
2011 Ducati MS1200S Touring - Street
K7 GSX-R 600 - Track Only
Turkishexpress is offline   Reply With Quote
Old 08-02-2011, 08:49 AM   #2139
Built to Last
Oddometer: 3,362
tubeless Tiger XC or F800GS,,,can do???
Originally Posted by me3 View Post
Hi Woody
Possible?
Costs?
Thanx
Paul
here's the same old mantra,,,we are willing to seal for tubeless any rim that has a safety bead,,on these bikes the front rims have no safety bead and are too soft anyway,,,,if your rim dents too easy,,then going tubeless is a total crapshoot.... we have done quite a few rears though both oem as wellas the stronger Excel replacements.
w
Old 08-02-2011, 08:52 AM   #2140
Built to Last
Oddometer: 3,362
straightening mags,,do able??? cost????
Originally Posted by Turkishexpress View Post
Hi Woody,
they look fairly uncomplicated,,,without seeing em i'd say circa $80-120ea should get ya within +/- .010''run-out again,,,and ya can leave the bearings in too.
woody
Old 08-02-2011, 11:18 AM   #2141
greatnortoni
Oddometer: 432
Color question
Hey Woody;
I know that you have an option for different colors on rims, these I assume are "anodized". What about powder coating? Can your rims be powder coated without any harm done to the rim from the heat applied to them during the baking cycle of the coating process?
Also, I was reading somewhere about anodizing the spokes? Is this a possibility?
Inquiring minds want to know!
greatnortoni
greatnortoni is offline   Reply With Quote
Old 08-02-2011, 12:00 PM   #2142
Turkishexpress
Groper
Oddometer: 36
woody
Awesome thanks buddy!
Old 08-02-2011, 02:33 PM   #2143
Built to Last
Oddometer: 3,362
to anodize or powdercoat rims/spokes????
Originally Posted by greatnortoni View Post
Hey Woody;
greatnortoni
we have no problem powdercoating street machinery rims/mags...for offroad use/competition we always prefer anodizing...i've seen too many hi tensile alloy rims come in powdercoated,,,we lace em up and they are toast after a few riaces,,,oops,,i think the heat anneals the temper in the metal turning em to butter
the spokes we usually either polish em and /or powder-coat @ $60/set
holler
woody
a freebie definition from Wikipedia
Annealing, in metallurgy and materials science, is a heat treatment wherein a material is altered, causing changes in its properties such as strength and hardness. It is a process that produces conditions by heating to above the recrystallization temperature, maintaining a suitable temperature, and then cooling. Annealing is used to induce ductility, soften material, relieve internal stresses, refine the structure by making it homogeneous, and improve cold working properties.
In the cases of copper, steel, silver, and brass, this process is performed by substantially heating the material (generally until glowing) for a while and allowing it to cool. Unlike ferrous metals—which must be cooled slowly to anneal—copper, silver[1] and brass can be cooled slowly in air or quickly by quenching in water. In this fashion the metal is softened and prepared for further work such as shaping, stamping, or forming.
in my race engine building heyday i'd always re-cycle my expensive copper head gaskets by heating em til they glowed and tossing em into the toilet bowel:>),,,worked for me
woody's wheel works screwed with this post 08-03-2011 at 08:39 AM
Old 08-02-2011, 04:26 PM   #2144
me3
Oddometer: 126
w
I take it there is a replacement Excel rim for the front with safety bead available?
Thanx
Paul
Old 08-02-2011, 06:22 PM   #2145
Built to Last
Oddometer: 3,362
Thanx
Paul
sorreee,,nada,,squat...well,,that's not true,,,Sun has a 2.15x21 same as the oemm ,,it has a safety bead BUT is a 6000 series aluminum rim,,they bend rather easy in hard core dirt riding,,,bend the lip and Voila ya have an instant blow-out
hence we often downsize the rim to a2.5x19 which has the safety bead,,,,and allt heimproved road handling characteristics....
i'm looking into paying for my own die to sport beaded 1.85 rims
holler,
woody
Times are GMT -7.   It's 05:33 AM.
