Old 04-27-2014, 11:18 PM   #3016
gen
gen's Avatar
Oddometer: 802
Woody/Zach, what is the benefit of a RAD hub vs. an OEM KTM hub? Is there any benefit to OEM KTM, or is the RAD always going to be a better choice?
DoD#1458 | GaijinRiders | 2010 KTM 690 Enduro
gen is offline   Reply With Quote
Old 04-28-2014, 11:19 AM   #3017
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,426
Africa Twin rebuild.
Originally Posted by E-Bum View Post
Hey Woody,
I'm trying to source some Excel rims + HD spokes for my 1988 Africa Twin rebuild. If possible, I would like to get a quote on the following items;
Front 21"x1.85" -36 spoke, black Excel rim.
Rear 17"x3.5" -32 spoke, black Excel rim.
Heavy duty (I believe HD = 8 guage?) spoke set for front rim (36 spokes).
Heavy duty (again, 8 guage?) spoke set for rear rim (32 spokes).
I'm actually unsure of what specs you need for the spokes to be able to source them. Let me know and I'll try to get that info for you.
I am going to have a go at lacing the wheels myself, so the quote would be for the above-mentioned materials shipped to 97068.
FYI- my other source for these is through the UK, and I would be ordering the rims and spoke sets found on this page: http://www.ruggedroads.co.uk/shop/ca...aram=cid%3D%26
Hi,
We can supply you rim's and spokes for your oem hub's to rebuild them with stronger stainless steel spokes/nipples. The only thing we would need is to see the hub's, which you can email us directly at woodyswheelworks@gmail.com.
It would be $925 for the rim's, stainless steel spokes/nipples and UPS ground shipping.
If you wanted to send in your hub's it would only be an extra $222 for us to lace them up with our superlace. If you want 8 gauge spokes you will need to drill/countersink the hub for them to fit correctly.
Thanks Zach
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 04-28-2014, 11:34 AM   #3018
Built to Last
Oddometer: 3,426
what's better OEM hub or RAD hub???
the pro's of the RAD hub are:
1,,they cost about the same as an OEM hub
2,, ya get the bling of various anodized color choices
3,,the cush drive units sport more bearings for carrying the load
4,,they are built out of billet 6061 T6 versus an aluminum of questionable origin casting.
the downside of the RAD units have been intermittent QC problems resulting from some of their machinists running finishing cuts at too fast a speed causing the bearing bores to be tapered ...resulting in bearing seizing issues.
woody
Old 04-28-2014, 12:23 PM   #3019
Stinky151
Stinky151's Avatar
Oddometer: 400
Ask Woody About Your Wheels
Lincoln
"If you're in control, you're not going fast enough." -- Parnelli Jones
Stinky151 screwed with this post 04-28-2014 at 04:03 PM
Stinky151 is offline   Reply With Quote
Old 04-28-2014, 04:02 PM   #3020
Stinky151
Stinky151's Avatar
Oddometer: 400
A big shout out and THANK YOU!!! To woodys. Minor mistake on year and they are going WAY above and beyond to help me get rolling. Living up to their reputation, I can't thank the guys enough for helping me out!!!!
Lincoln
Old 04-28-2014, 04:53 PM   #3021
gen
gen's Avatar
Oddometer: 802
Understood, thank you for the details. Are you able to check the hubs for these tapered bore qc issues if we buy from you?
Old 04-28-2014, 05:44 PM   #3022
E-Bum
E-Bum's Avatar
Oddometer: 715
Hi,
Thanks Zach
Hi Zach,
So if I did choose to go to 8 gauge and sent my hubs in, does that $222 inlcude the price of drilling/countersinking and superlacing? Or does the $222 only include superlacing with standard size spokes?
E-Bum is offline   Reply With Quote
Old 04-29-2014, 08:29 AM   #3023
Built to Last
Oddometer: 3,426
Hi,
The $222 extra is for the Superlacing/truing which includes' the drilling/countersinkig of the hub/rim's and lace/true for both wheels.
Thanks Zach
Hi Zach,
Old 04-29-2014, 08:30 AM   #3024
Built to Last
Oddometer: 3,426
Rad hubs.
Yes we do have them ship the hub's apart so we can check bore's, which the new machinist they have has been very great on this. We also re-pack the bearing's with waterproof Bel Ray grease.
Thanks zach
Old 05-08-2014, 11:21 PM   #3025
Phreaky Phil
Oddometer: 1,832
Hi Zach, some years ago you built a radical offset wheel to adapt the disc brake to my BMW R80 GS. Its still working good.
At the moment I have 2 sets of DRZ400 forks, one on my DR650 and the other maybe for the R80. With the DRZ front wheel the bearings dont seem to last. they are quite small, from memory 37x20x9. In comparison my R80 wheel has much larger bearings 52x20x? They last for ages. However the BMW wheel is really heavy. Is there a lightweight hubb that could be used with the large bearings. ? What size are the bearings in your Superlite hubbs
Cheers Phil
Phreaky Phil is offline   Reply With Quote
Old 05-09-2014, 05:50 AM   #3026
igormortis
igormortis's Avatar
Oddometer: 1,367
Hey Phil - Prutser is using an X Challenge wheel in his forks, without modification I believe. I'd expect those bearings to be bigger.
igormortis is offline   Reply With Quote
Old 05-12-2014, 10:49 AM   #3027
Built to Last
Oddometer: 3,426
Billet hub's for Suzuki's
Cheers Phil
HI,
Glad to hear the R80GS is still working great.
Yes we can use a billet hub that uses 60/28 bearing's with step down spacer's for your front end to fit the hub using the oem rotor.
It would be $279 for just the hub.
Thanks Zach
Old 05-14-2014, 11:44 AM   #3028
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
last but not least the safety bead is that little ridge,,unless ya own a KTM in which case it IS the biggest ridge that your tire has to jump over in order to seat on the bead,,this ridge helps tires from popping/sliding off the bead when you have a loss of air pressure,,,it was mainly used in tubeless applications but has of late been used universally for the same reason,,,
sweet dreams,,,woody
Woody, what manufacturers have a safety bead?
I recently noticed Motostrano is selling DID bare rims. Do you know if a CRF230M is tubeless?
My second question is, can a front (3.5") rim be used in a rear? His "rears" are 5" and I can't swing that...
Sadly I have a rear 16" tire, but it has a cush drive so a rear disc brake is out. I'm gonna use my rear hub... KI$$
Everyday IS 3/11!
Everybody's always talking out the side of their mouths about our "dependency on foreign oil", what about our dependency on cheap china crap? Who exactly again is killing our dollar?
IheartmyNx screwed with this post 05-14-2014 at 12:31 PM
IheartmyNx is offline   Reply With Quote
Old 05-18-2014, 12:21 PM   #3029
koth442
koth442's Avatar
Oddometer: 294
Hi Woody,
I'm interested in building myself a set of 17" wheels for DRZ-125L. I'm very interested in doing the assembly myself as I think it will be a neat project; however I'm a college kid on a tight budget.
My build plan so far:
OEM hubs (used OEM seem to be cheaper than RAD or Talon)
Buchanan SS spokes/Zinc nipples
Excel rims
Front: 2.5 x 17"
Rear: 3.5 x 17"
Any suggestions or details to be careful of when selecting? For example, making sure the number of spokes are correct per the hub and rim? I am undecided on dimpled or undimpled.
Thank you in advance
Leon
AFM #367, Thank you to my sponsors: Galfer, Good Times Motorsports, Woodcraft, Vortex, Riders Discount, RaceTech, Leo Vince, SpeedMob, Precision Trackdays and ARC
www.facebook.com/calsciracing
koth442 is offline   Reply With Quote
Old 05-19-2014, 02:55 AM   #3030
basilis_sti
Oddometer: 3
Hello from Greece. I have a F800GS and would like to change the front with a laced rim (I have the original hub) and placing a 19x2.50 rim.
I have found some in used condition, but I am not sure how can they be laced with the Bmw hub.
19x2.50 are from the older F650 (needs painting) and the same dimension is from a Suzuki Freewind or Aprilia Pegaso (these have almost identical color as the 21' Behr rim). What spokes/nipples would I need? is this possible?
I wish my budget wasnt so low in order to buy a ready wheel from you but...
Thanking you in advance!
basilis_sti is offline   Reply With Quote
Times are GMT -7.   It's 02:46 PM.
