Old 07-23-2009, 08:43 AM   #1261
andrewgore
Team MGH
andrewgore's Avatar
Oddometer: 3,477
Originally Posted by woody's wheel works
hey you're at the wheel works,,we can make anything happen for a 21'' front conversion
holler when you are ready
woody
woody
Sounds good. What kind of rough price if I supplied a wheel?
Andrew
andrewgore is offline   Reply With Quote
Old 07-23-2009, 07:18 PM   #1262
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,397
19 to 21 conversion for BMW G650 X country cont'd
Andrew
i recommend a 1.85 x21 for all around service
excel rim..$179
anodize black $75
ss spoke and ss nipples circa $115
Superlace n true $99
several day turnaround when we have everything here..
holler n thanks,,
woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 07-26-2009, 05:22 AM   #1263
Built to Last
Oddometer: 3,397
woody is off to vermont to do summer chores on the farm
hi guys,,
it's off to vermont,,,Chris and Zach and Jill will field most of your questions and take good care of you....
catch you back in denver after the 25th of August...
you can contact me up there or even stop by,,,have 80 acres for you to camp out...
1-802-368-7149
witte
95 collins road
west halifax,vt,05358
thanks ,
woody
Old 08-03-2009, 02:03 AM   #1264
Warthog
TeutonicChronic
Warthog's Avatar
Oddometer: 845
trueing by ear
Woody,
I use my stock wheels for road tours... and I noticed some very loose spokes on the OE front when I was switching back to my Woody Superlites this weekend.
After tightening the 2 spokes that were rattling around...I was "pinging" the other spokes with a small screwdriver, listening to the sound. I went around the wheel a few times, tightening 4 or 5 spokes, and loosening one spoke that sounded way too tight.
I haven't had a chance to put it on a trueing stand, or the wheel balancer at the garage (just to spin it up and eyeball the rim). I'm curious to see if I made it better ... or worse.
Anyway. My Superlites are holding up. Front is a bit out of true, but I think it's still round. Its all relative anyway....at 80km/h on potholes or washboard, it doesn't matter if your front wheel is out 3mm. :-)
Also, the hub anodization is holding up very well. I have other anodized parts that are sun-bleached after 6 months (can you say Wunderlich Vario Levers....oops, did I say that?). Not the hubs. Tough stuff, Dude!
Keep up the good work.
Warthog
2006 HP2
Warthog is offline   Reply With Quote
Old 08-03-2009, 02:06 AM   #1265
Warthog
TeutonicChronic
Warthog's Avatar
Oddometer: 845
Question drill 'em out!!
one more thing
Have you ever tried drilling out the unnecessary mass on a GS hub to lighten it and make it look better? Is all that aluminum mass really necessary in the hub, between the raised web ridges? (Do you know which part I'm talkin' 'bout here?)
Just thought I'd ask. I was thinking about drilling mine out...but I haven't. I don't want to ruin them.
Warthog
2006 HP2
Old 08-03-2009, 01:16 PM   #1266
Shenger
Oddometer: 1
DID rims
Hi Woody,
Is it possible to identify the bike(s) that following DID rim will fit? It is stamped D.I.D. Japan 86--13 16--J 18 * 2.50 6 05 DOT. Can anyone identify what these notations mean???
Please help!!
Shenger
Shenger is offline   Reply With Quote
Old 08-03-2009, 04:44 PM   #1267
Fishyhead
Eremikophobic
Fishyhead's Avatar
Oddometer: 3,143
Woody,
I ran off track last year at Willow Springs and put a dent in my RC51's rear wheel. The center of the dent now has a crack. Do you do that kind of repair?
Duy. You know, like the decimal system.
Spot shared page: http://share.findmespot.com/shared/f...FogjjtYMdOqF2n
Fishyhead is offline   Reply With Quote
Old 08-04-2009, 06:40 PM   #1268
Built to Last
Oddometer: 3,397
rim identifying
The first three are manufacturer identifiers and the middle tells you that it's a 2.50"x18" rim. The last three I believe are for DOT.
It's most likely a jap drilled rim and depending on the number of holes(32 or 36 most likely) would be used for a rear dirtbike hub.
Hope that helps.
Originally Posted by Shenger
Hi Woody,
Please help!!
Shenger
Old 08-04-2009, 06:42 PM   #1269
Built to Last
Oddometer: 3,397
We removed as much as we thought we could without sacrificing strength. We tried one by removing the center and it did not look as good as you would think.
Glad you're enjoying the wheels.
Originally Posted by Warthog
one more thing
Old 08-04-2009, 06:46 PM   #1270
Built to Last
Oddometer: 3,397
straighten, weld, etc.
We can straighten, weld, and machine. Cost depends on how bad the bend is. We would leave some meat on the visible portion of the wheel because it makes it stronger. As long as you don't mind the look, then send it in. We will blend any minor paint as part of the cost.
Straightening is anywhere from $80-180, welding and machining is usually $60. So anywhere from $140-240 total.
Feel free to e-mail or call us with any further questions: woodyswheelworks@gmail.com
Thanks,
Originally Posted by Fishyhead
Woody,
Old 08-21-2009, 05:58 PM   #1271
Built to Last
Oddometer: 3,397
A lil' eye candy
Woody's nephew 'Rudy Ciarfella' sent this painting he drew our way and wanted to share it with some fellow motorheads.
woody's wheel works screwed with this post 08-28-2009 at 10:42 AM
Old 08-21-2009, 06:38 PM   #1272
overlandr
Dystopist
Oddometer: 5,866
Hey Woody - re the 19" x 2.5" Excel rims - is there only ONE model or style from excel which will fit a ktm front hub? Am looking at sourcing one myself
overlandr is offline   Reply With Quote
Old 08-22-2009, 09:20 PM   #1273
AtomicGeo
Chile Eater
AtomicGeo's Avatar
Oddometer: 4,216
Bent my front rim - XR650R
Hello Woody:
Well it finally happened....hit a good sized rock with my front tire...came home to see my rim dented...2005 XR650R stock D.I.D 1.6x21 rim. What approach should I take (bend back, straighten, etc)? If I take a pic of the dent so that you could judge the severity, then can you say to send it in to fix or just buy a new rim? Thanks.
2003 KX250 - plated
2014 WR450F - plated
AtomicGeo Videos
AtomicGeo screwed with this post 08-27-2009 at 07:00 PM
AtomicGeo is offline   Reply With Quote
Old 08-22-2009, 09:57 PM   #1274
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
Woody your nephew has talent thanks for sharing. encourage him to continue...
Woody's nephew sent this painting he drew our way and wanted to share it with some fellow motorheads.
There's a fine line between "RED ASS" and "DUMB ASS"
"Life isn't about waiting for the storm to pass... It is about learning how to dance in the rain" - HAWK
kellyk7 is offline   Reply With Quote
Old 08-22-2009, 10:00 PM   #1275
kellyk7
Who knows
kellyk7's Avatar
Oddometer: 1,746
Wheel / Spoke question on a BWM Dakar
I have a 2002 F650 Dakar I just picked up, one of the previous owners swapped a 19" wheel up front. everything else is Dakar...
I have been wondering first if I will gain anything by swapping back to a 21 inch wheel.
and second how is the budget way to do it.. The wheel is 36 spokes like a Yama YZ250 so I figure that might be one available used option. What would be a solution for the spokes..
ZThanks for any info
kelly
Times are GMT -7.   It's 07:45 PM.
