Old 09-01-2009, 10:54 PM   #1291
FOXedupONE
Momafox can I ride?
FOXedupONE's Avatar
Oddometer: 2,548
I have a BMW g650Xchallenge and am interested in the 17 inch supermoto wheels you make for this bike.
FOXedupONE is offline   Reply With Quote
Old 09-02-2009, 07:46 AM   #1292
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,475
Hi Woody,
I am the second owner of a 4 month old set of 19/17 KTM 950 wheels, supersized and superlaced w/ SS spokes and nipples. The front wheel was sealed for tubeless while the rear was not. The front wheel is out of round and out of true and needs to be fixed.
What are my options here? Is there any warranty on these wheels? If I take the wheel to someone local, will they be stopped dead by the sealant? How difficult a job will it be to remove the sealant (the rear wheel isn't sealed and I'd rather have tubes at each end instead of a mis-matched set)? I'd rather take care of this locally as our short riding season here in Upstate NY is closing down fast and I don't want to miss any riding time. However, if these wheels are warrantied, I'd rather wait till the snow starts and just deal with it till then.
Please advise?
Thanks!!
~Chuck
For Sale: 2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 09-02-2009, 10:30 AM   #1293
woody's wheel works OP
Built to Last
woody's wheel works's Avatar
Oddometer: 3,447
out of round 19/17 KTM 950 wheel set driven in brooklyn's famous pot-holes
Originally Posted by Chuckracer
Hi Woody,
Please advise?
Thanks!!
~Chuck
chuck,,,i'm rather surprised about the 'out of round and out of true',,,mainly because under most normal and even racing use the spokes on my Superlaced wheels stay tight and maintain their true,,,..now bending rims from hitting rocks and major potholes is a different story
we'd have to see it ourselves,,,,fixing bent rims and re-truing will be done on your dime,,,if the spokes are loose,,, which has happened only once or twice in my 35 years,,i'll do that part under warranty,,,,if it's holding air than the odds of loose spokes are almost nil,,,once you turn the nipples their is a good chance that the seal may be compromised...
if you want to go with a tube ,,,then there is no need to remove the sealant ..it'll be the tuffest rim-band you ever had,,so just remove the 2 nuts holding the valve stem and carefully remove it,,,and install your tube as usual...
in scenarios like yours we usually get your wheel in and out the same day or next day,,so you could be without your bike for 7-10 days max.
hope that clarifies your concerns...
holler,,,woody
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
woody's wheel works screwed with this post 09-02-2009 at 03:40 PM
Old 09-02-2009, 10:39 AM   #1294
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,475
Yes it does, thanks Woody. I'd imagine it was a pothole hit as the wheels came from Brooklyn and they have wonderful roads there!
I'm gonna have a local look at it as soon as the rainy season hits - see if it can be trued up. I'm just concerned the sealant might cause problems for him, that's why I'm interested in removing it if possible.
Old 09-02-2009, 11:39 AM   #1295
Built to Last
Oddometer: 3,447
more wheel straightening info
Chuckracer,,
the sealant will not interfere with truing,,so please do not concern yourself with that,,the nipple will just twist under the sealant,sometimes just slipping under the seal and sometimes grabbing the seal and ripping it a bit,,hence there goes the tubeless capability...
chuck hole hits invariably bend the rims which cannot be cured by truing,,the rim should first be straightened then trued,,,we are one of the premier wheel straightening centers on the planet,,so we can straighten instead of needing new rims
woody
woody's wheel works screwed with this post 09-02-2009 at 02:06 PM
Old 09-02-2009, 12:59 PM   #1296
mag00
Outa Control Dave
Oddometer: 423
Woody I picked up a set of spoke wheels from an 05 GS and need to install them on a 09 GSA. I understand the rear is just bolt on, but the front I think I need new rotors and ABS ring and all mounting hardware is this correct? Is that something I could get from you.
2012 Ducati Multistrada
08 SE Ultra,
2012 Triumph explorer 1200
09 R1200GSA
IBA #25226
mag00 is offline   Reply With Quote
Old 09-02-2009, 02:05 PM   #1297
Built to Last
Oddometer: 3,447
2006 R1200GS to 2009 R1200GSA wheel/disc conversion
here's what i do know ..the hubs are all the same and from 08-2006 onward they used a different ABS ring...also know they discontinued the old front disc brake kits that had that multi shim/washers mounting kit in favor of an integrated floating disc mount,,, i don't foresee any problem in adapting the late model sensor ring and rotors to your 06 wheel..
there was a run of some front hubs that had smaller disc mounting surfaces vs. the more common large disc mounting surfaces. Difference seen below. Both with the proper mounting hardware and ABS ring will work on all R12 GS's.
we have some of this stuff in stock
woody
Photo of what smaller disc mounting surface looks like on early version GS hubs
note bigger surface on late model GS series,,pictured here right side of the single disc HP-2 on the left and the double disc R1200GS & R1200GSA all 3 hubs are same casting..HP-2 has right flanges machined off..NOTE the little directional arrow cast into hub...that's because these hubs are indexed from the left side via the axle spacer with 35 mm seal and right side with 30mm seal for the axle.
woody's wheel works screwed with this post 09-02-2009 at 09:03 PM
Old 09-02-2009, 02:14 PM   #1298
mag00
Outa Control Dave
Oddometer: 423
Thanks for the info & quick reply.
08 SE Ultra,
09 R1200GSA
IBA #25226
Old 09-03-2009, 11:51 AM   #1299
SCflyer
SCflyer's Avatar
Oddometer: 1,654
Could you explain a little more about sealing the wheels to be able to use tubeless tires? I've got a BMW 650 X Challenge, looked at the TUBLISS system but they only make up to 2.15 for rear and as you know mine is 2.50.
SCflyer is offline   Reply With Quote
Old 09-05-2009, 12:34 PM   #1300
Built to Last
Oddometer: 3,447
hi,,i'm on a tight schedule,,my son chris is getting married today,,,go to google advrider motorcycles tubeless tire
you'll get a ton of threads and answers on the subject,,gotta run
woody
Old 09-05-2009, 02:05 PM   #1301
mag00
Outa Control Dave
Oddometer: 423
Congratulations to you and your son.
08 SE Ultra,
09 R1200GSA
IBA #25226
Old 09-05-2009, 02:27 PM   #1302
HighScore
No More, all done.
HighScore's Avatar
Oddometer: 928
I know I have seen a guy around here who has mounted a set of Excel's on a Triumph Scrambler.
I just can't seem to nail it using the search feature.
I would like to lace up a set of Excel tubleless rims to my scrambler hubs.
What would I be looking price wise?
HighScore is offline   Reply With Quote
Old 09-06-2009, 02:35 PM   #1303
Built to Last
Oddometer: 3,447
tubeless excel rims to triumph scrambler
High Score,,,sorry Excel only makes standard style rims,,,,IF they have a safety bead we can usually seal them,,,,
we have redone and upgraded the triumph wheels with better more durable lace patterns and spokes,,,ie "Superlaced' them...and later sealed them....
holler,,
woody
Old 09-06-2009, 10:40 PM   #1304
Chadd
I live in the wrong place
Oddometer: 467
Wr250f?
Is it possible to put a cush drive on one of these?
Chadd Thompson
94 Ducati Elefant
04 625 SXC
03 WR250F
95 GasGas JT25
Chadd is offline   Reply With Quote
Old 09-07-2009, 02:44 PM   #1305
HighScore
No More, all done.
HighScore's Avatar
Oddometer: 928
holler,,
woody
what about just a set of excel standards on a triumph then?
what would I be looking at?
Times are GMT -7.   It's 02:10 AM.
