10-06-2009, 10:17 PM
#1351 | |
Built to Last
Oddometer: 3,088
repaired wheel jitters...
so if i repaiered it and brought it back to manufacturers specs,,and i sent it out then i wouldn't worry about it...hope it was me who repaired it ![]() as far as ''how carefull you should be",,well ER,,,,you are riding on the notorious 'pretzel' rim,,,i've heard claims that it wilts when people stare too hard,,,,Nah,,,just teasing ,,,,keep it out of chuckholes,,,off of rocks and sharp obstructions you'll be fine,,there are hundreds of riders out there still running on em woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
10-06-2009, 10:45 PM
#1352 | |
Allergic to Asphalt!
Oddometer: 5,986
Originally Posted by Yellow Pig
F%&k......... Just blew apart my rear XR650R wheel and am leaving for the Swell Thurs PM. I'll be by in the morning hoping for a quick fix & turn around. Later Dan Quote:
What great service. Dropped the wheel off at 10AM and told Woody I did not need it till Thursday morning.........well at 3:30PM I get a call from Zack saying my wheel was ready to go: trued, Super Laced and all. They even noticed my disk brake was warped, which I had not noticed and straightened it for me. Now that's what I call service, and the advantage of being local. Thanks guys!
10-07-2009, 12:14 PM
#1353 |
Dirty Hairy
Oddometer: 311
Woody and crew-
I am sending in my F650 Dakar wheels in the near future for you to relace with new rims. Do you need all of the axle spacers and cush drive left on to be able to center things, or do I keep them all to prevent them from being lost? What about rotors? You are reusing spokes. |
10-07-2009, 08:42 PM
#1354 | |
Built to Last
Oddometer: 3,088
what ya need to send and not send for wheel work
and installing the aftermarket ss spokes that we offer.,, custom lace n true is just $80....when i see your stuff i'll call ya if there any anomalies.. later ![]() woody
10-08-2009, 10:14 AM
#1355 | |
Dirty Hairy
Oddometer: 311
Talk to you soon- |
10-09-2009, 04:09 PM
#1356 |
Apathetic
Oddometer: 1,247
Dakar rotor
Woody, noticed you straighten rotors on your web site. I just picked up a 2002 Dakar from an inmate in NorCal and rode it home to PHX and the front brake is pulsating like a MOFO. Putting the bike up on the centerstand the rotor seems to be dragging more in one area so I'm guessing it's bent or warped. Can't see any damage. Don't have the means to measure runout. What's the turnaround on straightening?
Thanks |
10-12-2009, 04:51 PM
#1357 | |
Built to Last
Oddometer: 3,088
we can check the rotors for wear /warpage and being bent
there are a few good articles and threads about the other causes of pulsing caused by build-ups on the disc surface,,,,bead or media blasting will often remove them along with de-glazing your brake pads....then a proper break in procedure should get you up and running again... woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 10-14-2009 at 05:32 AM |
10-25-2009, 09:52 AM
#1358 |
Confused Hack Nut
Oddometer: 2,518
Woody - can you lace a rim from a 15" wired auto wheel to a MC hub such as a heavy duty hub like those used for flat track racing? I am building a rally racing sidecar similar to Hog Wild's Dakar sidecar. I want to run 15" rally racing tires but don't want to make custom hubs and use custom auto wheels.
Ken => I'm a DAMN Rider (No rules, just ride!)
Happiness is a 3-wheel drift! Member of the Maryland OHV Alliance |
10-26-2009, 09:16 AM
#1359 |
Oddometer: 402
f 800 GS rear wheel bearings
Woody
You did work on a f 800 GS and found the disc side bore to tight and found the spacer to long. (and the distance from bearing seat of disc side to sprocket bearing race at 133.69mm ie .63mm/.025'' clearance ..ie spacer was that much longer..eliminating too short spacer as culprit I agree with the bore size being to tight. But isn't the spacer being to long also a problem. Wouldn't that cause outward pressure on the bearing centers after they have be installed and seated? LaPorte
If you don't know where your going don't lead!
10-26-2009, 01:01 PM
#1360 |
Oddometer: 543
03 F650 Dakar
Woody,
I'm planning on sending both my hubs in to have you superlace them with some new black excel rims. Here are a few questions, forgive me if they were asked before. I tried to search the thread but it's just too long. 1. Cost-wise, what would be the difference if I take the old wheel and spokes off myself and send in just the hubs? 2. I know I want 21" front and 18" rear. What are your thoughts in turns of the different rim width? (1.6'' vs 1.85'', 3.0 vs 2.5'', etc.) (stock Dakar wheel sizes are 21"x1.6" and 17"x3.0"). I really want the wheels setup more for off road, however I also do a lot of travelling on highways. 3. My current rear wheel has individual sealed spokes and runs tubeless tire. Because I had success doing this myself, I would like to make the same mods once I get the wheels back from you. Would the new setup take tubeless tires? (I only want to make the rear tubeless) 4. Based on what I described above, what is the rough estimate on cost and turn around time? (I want to send mine in when winter sets in around end of November) Thanks in advance. |
10-26-2009, 05:59 PM
#1361 |
TreeStump
Oddometer: 555
Wow! Not sure how I missed this thread.
Woody, I'm thinking about getting an F800 GS. Because I'm verry lazy I've not read all of the posts. So, if there is already something on here about 17" wheels for the F800 GS please point me in the right direction. From what I have been reading, however, It would seem you'd be able to answer my question. Because I like to have my cake and eat it too, I was wondering if you know of or build a good 17" motard type wheel set for the GS. I would love to have two sets for when I want to DS or scratch in the twisties. What kind of complications might I encounter. What would the approximate cost be. Thanks for any help. -T
2004 BMW R1150R ROCKSTER 2007 Kawasaki KLX140 (da Spawn's),1995 KDX Z00hun 2010 Husqvarna TE450 The more time I spend in this world , the smaller it gets |
10-27-2009, 10:23 AM
#1362 | |
Built to Last
Oddometer: 3,088
F800 GS inner spacer too long????,,,NOT!!!
the spacer bing a bit longer is not a problem because you'll never be able to 'crush the bearings inner race against the outer race laterally...the 800 hub was designed to have the right/disc bearing do all the alignment chores.. hence DON"T WORRY!!!! woody
10-27-2009, 10:28 AM
#1363 | |
Built to Last
Oddometer: 3,088
17''SM for the front of an BMW F800GS
psssst....FYI,,,i'm more inclined to use a 2,50x19 on the front if you want an even more well rounded ride that's not as twitchie,,ie i think it's an all around better investment woody
10-27-2009, 10:35 AM
#1364 | |
Built to Last
Oddometer: 3,088
15'' wire car wheels to motrcycle sidecar rig/hub
remember ya have to mathch the holes,,,,also later rims used 60 and td finally 72 spoke wheels,,,i have few 60 spoke hubs floatin garound,,, basically if we can match the holes we can come up with a workable solution woody
10-27-2009, 10:46 AM
#1365 | |
Confused Hack Nut
Oddometer: 2,518
