01-22-2010, 02:04 PM
#1456 | |
Built to Last
Oddometer: 3,088
the Alpina STS system
currently there are no 21 inch rims in the size ya need that have been speced for tubeless ie exact rim circumference PLUS a safety bead..we do not make rims tubeless without a safety bead... ![]() i was over at Alpina about a year ago and thought i'd be able to lock in some sort of deal,,BUT??????...too long a tale... and ihave yet to see one here in usa ,,so we are working on our own to complement our sealing techniques that have been getting better. woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W |
01-22-2010, 02:23 PM
#1457 | |
Oddometer: 0
hmmm, thanks for the reply. In that case, would it be possible to use the Alpina ADV rims with the SE hubs? Or would I be better off going for a 19/17 set up if Alpina (or FABA, or...) do rims in that size? Basically I'm trying to figure out the best tubeless set-up for 60/40 street/dirt that doesn't involve sealing standard tube-type wheels.
01-22-2010, 07:54 PM
#1458 | |
Built to Last
Oddometer: 3,088
well we have a genuine tubeless solution for your 950SE
http://www.advrider.com/forums/showthread.php?t=284243 then holler woody
01-26-2010, 08:08 AM
#1459 |
Daypass Adventurer
hey woody,
love your work! how can you help me get tubeless tires on my bmw r80g/s? let me know! dlew
2005 R1200GS 1993 R100GS PD 1986 R80 G/S PD |
01-26-2010, 07:57 PM
#1460 | |
Built to Last
Oddometer: 3,088
how to make R80GS tubeless
woody
01-27-2010, 03:15 PM
#1461 |
Oddometer: 1,016
Hi Woody!, Hope my wheels are coming along. I've got a couple of dumb questions in the meantime. When I get them back from you I figure I need to chase the rotor & abs ring mounting hole threads in the hubs with a tap to clean out any old loctite residue. Should I use a bottoming or plug tap or will a gun tap go deep enough? Also, will blue loctite be sufficient on the rotor bolts (re-using original hardware by the way) & is the wave washer supposed to compress all the way? And finally, I re-painted the ABS rings so they wouldn't ugly up your work, but I did put a small center punch mark on them & the hubs so I could re-mount them where they were originally. I hope the powder coating didn't cover up the center punch mark as of course the original plan was to leave the hubs with the stock paint. But if it did, do I need to use a dial indicator to find the tooth on the abs ring with the widest axial runout so as to correctly measure the gap between the ring & the sensor? thanks for your time & wisdom, Bruce
late-braker Guaranteed not to cause eternal torment in the place where the guy with the horns & pointed stick conducts his business...Frank Zappa |
01-27-2010, 05:13 PM
#1462 | |
Built to Last
Oddometer: 3,088
,,,i wouldn't worry about he punch mark because it isn't necessary ,,,,your brake discs of course would work better to return to the same pads that they have been seated to....as to needing dial indicators for clerance issues??perhaps overkill,,,and yes you do want to get the ABS ring sensor adjusted for optimal oem specs.hope that steadies your concerns..holler if ya need more info woody
01-27-2010, 05:49 PM
#1463 |
Oddometer: 1,016
Woody, all I did to the ABS rings was buff them with a small brass brush in a Foredom (jewelers handpiece) & painted them with a rattle can. I can easily buff the paint off if I need to. The dial indicator business was not in reference to brake rotors, if I caused some confusion, rather the ABS rings, as my Clymer manual says that when the rings are re-moved from the wheels or a new ring is installed, that you must check each individual tooth untill you find the one with the widest runout & mark that one to use for checking the gap at the sensor. As for my rotors i lightly wet sanded them using dishwashing soap & water & painted the inside, or carrier part with caliper paint to snazz em up a little.
01-27-2010, 08:34 PM
#1464 | |
Built to Last
Oddometer: 3,088
regarding th epaint on the ABS ring ???..like i said all ya can do is check if the system works or not... ![]() woody
01-29-2010, 11:13 AM
#1465 |
EasyRider
Oddometer: 31
Just picked up an R1100R in nearly mint condition. One problem. The wierd three-prong wheels that it's riding on. I am trying to find some used spoke wheels for it. I am unsure of the size, maybe 18 in the front and 17 in the rear? How much for them and do they still exist?
- 2006 KTM 625 SMC (TRADED) - 2000 BMW R1100R "the only thing different between you and me is a couple of drinks." - Mr. Leahy
01-29-2010, 04:47 PM
#1466 | |
Built to Last
Oddometer: 3,088
X-lace wire wheels for R1100R
these oem wire wheels do exist circa $1100 each... we can either build you a set and you can have em custom color/anodizing etc or i'm sur we did not sell aset we reconditioned in super nice shape.... the front is a 2.5x18 and the rear a4.0x17..i may even have a police special set with like new tires on... holler,,,woody
01-30-2010, 10:22 AM
#1467 |
FunHog
Oddometer: 3,455
Wheels for 03 Dakar...
About a month ago my 03 Dakar ABS with stock wheels was rear-ended, causing significant damage to, among other things, both wheels.
The right front of the Dodge Durango SUV that hit me went between the top of the rear wheel and the underside of my rear fender. This has caused an oblong-ness bend to the wheel, although the hub appears to be find. The out-of-roundness is slight, but clearly noticeable when sighting on a jackstand placed on the floor beside the wheel whilst rotating the wheel. After the collision the bike was propelled forward well over 100 feet before leaving the road into a wooded ravine. The right side fork tube broke at the axle and the wheel has at least one bent (flat) spot. Again, the hub appears to be fine. My question is how much it would cost to replace these bent wheels with 18/21 combo wheels laced to my original hubs? The other driver's insurance has refused to fix the bike (they want to total it) but is not offering me enough to buy another comparable bike so I'm exploring fixing the old one. BTW, if I do this I'll probably install forks from a Yamaha or KTM instead of the stock Showas (something I was considering anyway). I realize this might affect which front hub I choose as well. If I go the repair route I'd also remove the ABS system altogether, so the ABS sensor would not be an issue. Thanks!
My book's website (Now Available) 2003 BMW F650 Dakar (Back from the Brink) 2003 Victory V92C + Velorex sidecar chassis + Harley sidecar body (Canine Chariot) ![]() 2010 WR250R (Twiggy)
01-30-2010, 05:34 PM
#1468 | |
Built to Last
Oddometer: 3,088
you are asking a Broooaaaaad question..
![]() woody
If you have any questions... Post Em Here ..For more info check our website... www.woodyswheelworks.com ....Wanna e-mail us... woodyswheelworks@gmail.com ......Wanna talk,,,call us toll free... 1-866-936-0232 ........If you're lost???... GPS = 39*40'33.86N x 104*59'54.69W woody's wheel works screwed with this post 02-02-2010 at 12:09 PM |
02-01-2010, 03:02 PM
#1469 |
Oddometer: 1,016
Hi Woody!, just wanted to ask if you could send me a PM or call me & let me know when my wheels ship out & give me a tracking number? If I know the day they're supposed to arrive i'll probably call in sick so i'll be sure to not to miss the guy (or gal) in the big brown truck.
02-01-2010, 08:22 PM
#1470 |
Born again
Oddometer: 1,077
Woody- 09 Xcountry... I want to go 21/18 and never look back. TT sells complete wheels with hubs and excel rims $$$. Would I save a signifigant amount of money having you redo my current hubs or should I just buy a complete set and sell the 19/17's?
Thanks, Mike
09 Xcountry-the money pit 75 CB400F Supersport-close to stock and for sale 79 CB400T2- so I don't cut up the 400F Why do I want a CBR250R so bad? ![]() www.dakotadualsportriders.com |
