Old 10-19-2010, 07:37 AM   #1561
dozer
dozer's Avatar
Oddometer: 337
Originally Posted by hilslamer
In the aircraft industry we call this "sympathetic fatigue"
Now thats funny
dozer is offline   Reply With Quote
Old 10-19-2010, 10:27 AM   #1562
motorcycledave1000
Speed Thrills
motorcycledave1000's Avatar
Oddometer: 82
Originally Posted by Geek
Crazy coincidence!
I'm going to replace all my levers at 76,000 miles
Lesson learned: More front brake stoppies and clutchless shifts should solve the problem.
-Soup-r Dave
2008 KTM990 Adventure
2002 Suzuki GSX-R1000
2002 Yamaha WR-426
1983 Honda V45 Interceptor
motorcycledave1000 is offline   Reply With Quote
Old 10-19-2010, 11:18 AM   #1563
Leodis41
I wanna Orange one!!
Leodis41's Avatar
Oddometer: 65
I take it you have checked the front brake lever now?
Leodis41 is offline   Reply With Quote
Old 12-10-2010, 02:03 PM   #1564
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,335
Originally Posted by Pyndon View Post
Keen eyes Ned......correct it's not!
Since the bike is down for a major engine overhaul, I took the opportunity to do a few things I've been wanting to do for a while but didn't want to stomach being without the bike for any amount of time. Now I don't have a choice I'm getting things done.
1) Everything that was silver is getting removed, blasted, prepared and hard anodised black by G-It.
2) Building full rally spec 320mm travel suspension for the bike.
The forks are fairly straight forward, just swapping parts out etc, but the shock is a little more challenging! I'm sticking with Adventure forks and twin disks as I like the extra braking power on the road.
Extending the travel to 280mm on the shock is relatively easy with the stock Adventure shock by using a longer rod. The travel then becomes limited by the length of the body. You can use a longer rod but then you only increase the ride height and are still stuck with 280mm travel. I wanted to do it right and so needed to find a longer upper body tube. Problem is, I could not get one to fit the Adventure shock so....
The shock you see in the picture is a Husaberg dirt bike shock (prototype 1). This was the first attempt. The lower yoke is identical on the Husaberg to the 950 so that gets you the lower yoke and longer rod, the upper body has the longer tube but its a bit sporty to get the upper yoke to fit the 950 frame. I did it, but it involved careful hacking / machining of the upper body / casting around the frame attachment. This made the material rally thin around the valve stack oil gallery.....it worked, but I was not 100% happy because should the upper bearing wear or fail, the frame could potentially crack the upper casting. Unlikely but the thought of being stranded on a trip with no oil in the shock did not appeal to me, especially the places I go . So, I had to come up with another way. The shock bearings on the dirt bike shocks are the same but the bushes are different so I just switched them for the 950 bushings/spacers.
To solve the upper casting issue, I wound up choosing a KTM dirt bike top casting because it moves the reservoir to the right hand side, clears the frame and because the oil gallery is at 45 degrees, I can machine the top casting to fit the frame without reducing the wall thickness too much and still maintain good frame clearance. Down side is, it's likely to clash with the 2-1 I had on and would definitely clash with the stock exhaust, oh well, my header is cracked again anyway so I guess this means I finally have to go with a full-on low-slung dakar style exhaust system
Then there is the reservoir size, if you extend the 950 shock, you have to move the reservoir piton closer to the top thus leaving little or no room for leakage. Again not good for a long distance adventure bike. The work around here is to find a longer reservoir, this also increases oil volume and helps cooling etc. The Husaberg shock has a nice long reservoir so I'll try to maintain that, if not the KTM dirt bike reservoir will suffice.
Final thing is spring. I'm going for a 140 but a slightly longer spring to prevent coil bind at max travel even though the stocker would just about do it.
I'm almost there and what I have now is thus:
- KTM Dirt Bike Upper body
- Husaberg 2-piece long reservoir / piston
- Husaberg Supermoto Upper tube with coarse threads for faster pre-load adjustment
- Husaberg Enduro lower mount with long 18mm shaft/rod
- KTM 950 bushings and spacers upper and lower
- Longer 140 spring (orange )
The result, full travel 320mm shock with 950 spring and valving. More oil capacity for better cooling and good longevity.
A little modification required to the right hand size panel to allow low speed and high speed damping adjustment and bobs your uncle.
Now, where was I with the engine
Sorry if i didnt get this. Was is it ever done? Im really keen to sort some real suspension for this bike.
Regards
Mikael
KTM 950(1190) Adv-s, Soon to be Project 1190
KTM 530 EXC-R 08
LocuL is offline   Reply With Quote
Old 12-10-2010, 05:16 PM   #1565
Pyndon OP
Pyndon's Avatar
Oddometer: 2,546
Regards
Mikael
All done, problem is I need to get the GPR exhaust modified so that the swing arm can move to the new position. GPR is only made for the 'S' model, not for 'Super S'!
Will get around to it one day.
Lyndon Poskitt Racing
Currently racing my way around the world at: www.facebook.com/LyndonPoskittRacing
Blogging at: www.racestoplaces.com
My Dakar Rally Experience
and blog www.LyndonPoskittRacing.com
My KTM 950 Story
Pyndon is offline   Reply With Quote
Old 12-11-2010, 10:31 PM   #1566
mtb_man
Unfettered
Oddometer: 171
Pyn, would the 'Super S' be a easier fit (i.e no need to modify pipes) with the stock cans (or a 2-1)?
04 KTM 950 ADV
08 KTM RC8
Gone but not forgotten:
06 KTM Super Duke,
05 Kawasaki ZX636, 05 Suzuki DR650
When you are great, candor is often perceived as arrogance.
mtb_man is offline   Reply With Quote
Old 12-12-2010, 08:36 AM   #1567
Pyndon OP
Pyndon's Avatar
Oddometer: 2,546
I think so, I think you'd get enough rise with the standard header. The problem is where the GPR comes out from underneath the swinger to the side, only has about 1mm clearance on the 'S' models at full extension and raising the suspenders 60mm means I need about another 20mm at this point.
My KTM 950 Story
Old 12-12-2010, 02:39 PM   #1568
mousitsas
mousitsas's Avatar
Oddometer: 2,913
Originally Posted by Yascher View Post
Hi Pindon,
As far as I understand non of the stock or aftermarket 2-2, 2-1 exhausts systems are aiming at equal header lengths....is there a specific reason for that from your point of view...or maybe I'm missing something in the way engine delivers with each cylinder being happy in a different rpm range, rather than 2 being stuck to one narrow range of optimum performance and therefore reducing bike versatility?
I think the reason for that is the non symmetrical firing order of a V2. The system is 2-1-2. At the junction there is an exchange of pressure waves. The two cylinders face different exhaust pressure phases (due to the uneven timing), hence the unequal lengths.
mousitsas screwed with this post 12-12-2010 at 02:48 PM
mousitsas is online now   Reply With Quote
Old 12-12-2010, 03:06 PM   #1569
ADVJake
***** dweller
ADVJake's Avatar
Oddometer: 4,341
300mm/320mm 950?
Lets see some photos of the stretched suspenders on the bike!
"And some guy said, let there be filtering, and we filtered and we saw that it was good, and hours became minutes..."
ADVJake is offline   Reply With Quote
Old 01-19-2011, 02:59 PM   #1570
LocuL
Gnarly Infantry
LocuL's Avatar
Oddometer: 1,335
Super S writeup is needed...
please
KTM 530 EXC-R 08
Old 06-21-2011, 10:21 PM   #1571
JonnyM_XRR
The guy on the dirt bike
Oddometer: 17
wow...
just read this thread from start to finish. amazing work... thanks for the time you put into this. i learned a ton.
_J
Bike-less.... for the moment. (dreaming for a KTM 950adv)
The History....
XR650R -- gone, with identity crisis, slicks or knobs?
YZ426f -- gone, to supermoto land.
JonnyM_XRR is offline   Reply With Quote
Old 06-21-2011, 11:08 PM   #1572
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
There is something I should mention here.
It seems you have eliminated the safety switch that prevents you to start your bike in gear with the clutch pulled in. This feature stops operating when the clutch lever is worn from the swivel pin so you are forced to replace your clutch lever before it brakes.
Then, riding home from work today 78,100 milles on the clock and the clutch lever decides to give up the ghost too. No fall, just riding along using the clutch as normal. The swivel pin has warn the lever until it was so weak it broke.
You could diagnose lever failure when it is wobling too much or extend its life if you fit two small bearings at the edges of the swivel pins.
Cheers.
gefr is online now   Reply With Quote
Old 06-22-2011, 10:44 AM   #1573
Pyndon OP
Pyndon's Avatar
Oddometer: 2,546
Cheers.
It's more fun doing it this way, and it also makes it more interesting for the reader too.
At 100,000miles you guys are in for a treat. I have a full history logged of everything I have ever done to the bike from oil changes to engine rebuilds with details of everything replaced and why. I will publish at 100,000miles so keep watching
The way it's going that's an ETA of 12 months although I did manage 2,400 miles last week
My KTM 950 Story
Old 06-22-2011, 11:02 AM   #1574
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,012
Pardon me.
I didn't think of your respectful audience. I was only thinking you could have the failure at some remote place... far away... between hostile aborigins... and life sucking heatwave...
Old 06-22-2011, 11:36 AM   #1575
Deadly99
Fast and Far
Deadly99's Avatar
Oddometer: 10,039
My fancy FPRacing lever just did the same thing on the way home from work last night. It wasn't a cheap lever either
Roaming Rally 2015
GRAVEL TRAVEL CANADA - Canada's source for overland routes
Tales From The Bivouac Rally Print Publications
Deadly99 is offline   Reply With Quote
Times are GMT -7.   It's 01:24 PM.
